Page 22 of 55 1 2 20 21 22 23 24 54 55
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061453
10/14/12 10:53 PM
10/14/12 10:53 PM
Delray beach, Florida
P
Performance Only Offline
P
just a couple more.
machine shop owner and engine builder
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061454
10/14/12 10:58 PM
10/14/12 10:58 PM
P
P
Lers put some lifters in and check for proper rotation. Notice the lifters are marked with a red dot to indicate the amount of rotation per revolution.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061455
10/14/12 10:59 PM
10/14/12 10:59 PM
P
P
after one camshaft revolution they all rotate.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061456
10/14/12 11:01 PM
10/14/12 11:01 PM
P
P
Lets put some heads on and check for pushrod length,
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061457
10/14/12 11:04 PM
10/14/12 11:04 PM
P
P
Final torque of mains and rods, verify rod side clearance and crank end play.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061458
10/14/12 11:08 PM
10/14/12 11:08 PM
P
P
Last one for now. more to follow tomorrow.
i found the water pump doesn't sit flush to the housing. the flange on the pump is too tall and needs a little work to make it fit. no problem, i'll handle that and post a few more pictures as things progress.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061459
10/15/12 11:42 AM
10/15/12 11:42 AM
P
P
Here's a few more progress pic's
the water pump wouldn't sit inside the timing cover properly. I ended up chamfering the flange on the water pump (which was too tall to begine with) and then taking .100 off of it on the belt sander.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061460
10/15/12 11:44 AM
10/15/12 11:44 AM
P
P
Here's a picture of the flange. It was too tall and too squared off. That seems to be a common problem on some of the4 aftermarket pumps.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061461
10/15/12 11:46 AM
10/15/12 11:46 AM
P
P
here's a couple pictures of the valve covers. basically they looked pretty good on them outside, but the inside was still caked with what i'll just describe as "undesireable" material.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061462
10/15/12 11:48 AM
10/15/12 11:48 AM
P
P
Here's the "after" pisture. they got hand washed and put through a jet wash cycle to make sure they were completely clean.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061463
10/15/12 11:51 AM
10/15/12 11:51 AM
P
P
Basically I ended up doing the same thing with the intake manifold. I didn't want to take any chances with it since it was a used piece. It's all clean now inside and out.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061464
10/15/12 11:53 AM
10/15/12 11:53 AM
P
P
CC'ing the chambers to verify size and true compression ratio.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061465
10/15/12 11:56 AM
10/15/12 11:56 AM
P
P
here's the result.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061466
10/15/12 12:14 PM
10/15/12 12:14 PM
P
P
Time to do a little mock-up of the intake, etc.
all looks good.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061467
10/15/12 01:04 PM
10/15/12 01:04 PM
Tampa
DusterDave Offline OP
Tampa
Looks great, Dan!!
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061468
10/15/12 03:39 PM
10/15/12 03:39 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
dats purdy !!
I am truckless..
Re: MY JEEP BUILD THREAD [Re: 340SHORTY] #1061469
10/15/12 04:52 PM
10/15/12 04:52 PM
scratchnfotraction Offline
about the mis-match on water pump,is that a LA timing cover with a magnum water pump?
I know the LA t-cover will swap over to the magnum block and vis-versa. the last gasket set I had I noticed the t-cover gasket was the same for both blocks. 1 bolt hole is different location.IIRC
water pump gasket was 2 different styles and looked like they would not swap.
so would a little machine work be the fix for mixing the LA/magnum WP and t-covers?
Re: MY JEEP BUILD THREAD [Re: scratchnfotraction] #1061470
10/15/12 06:13 PM
10/15/12 06:13 PM
Tampa
Tampa
Mike, the timing cover came off of a 1983 318. The water pump is an aftermarket piece for pre-magnum engines. It's made by PRW.
Re: MY JEEP BUILD THREAD [Re: Performance Only] #1061471
10/15/12 06:21 PM
10/15/12 06:21 PM
Tampa
Tampa
time to install the timing chain and degree that .900 lift roller,
Dang it, Dan!! We agreed to keep those top secret cam specs just between us!!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061472
10/15/12 07:51 PM
10/15/12 07:51 PM
P
P
Golly Gee whiz Dave, it's not like i told them about the 320/ 320 duration at .050, Oops, darn it. Now look what you make me do.
