Page 5 of 55 1 2 3 4 5 6 7 54 55
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061113
10/14/11 03:30 PM
10/14/11 03:30 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Yea, I think you happen to have the cheapest Mopar stroker a guy could build! LOL I about crapped when I saw the pistons were that cheap! The ones for the 408 are about $427 a set. One thing though, I'm assuming you can press fit the piston pins that come with those floated Icon pistons? I'm pretty sure you can but I'd make sure somehow. Allways glad to spend someone else's money!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061114
10/14/11 06:36 PM
10/14/11 06:36 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
You can hog those magnum heads out some for sure. This is the best pic I could find at the moment. There is a large restriction in the bowl below the valve seat. You can see this comparison on the 2 Magnum intake valves pictured. On a well ported Magnum intake throat, a golf ball will snugly fit all the way in the port and sit on top the valve guide, where it will not even closely set that deep on a stock port. Don't mess with the short radius that much, but the other 3 walls of the port should pretty much go straight down from the valve seat, eliminating the bottle neck.
That's some great porting advice, and I really do appreciate it, but my goal (for this application) is making good low end torque, not big HP numbers. I'm looking to make around 300 HP, which will be plenty for the Jeep, and from what I've read, the stock heads are supposed to support up to around 400 HP.
Well, looking at your Duster, I suppose it was kind of goofy to try and suggest porting ideas to you anyway!
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061115
10/14/11 06:55 PM
10/14/11 06:55 PM
Lehigh Acres, Florida
rickstershemi Offline
Just Throwing this out there... Right now Mancini has the Eagle SIR rods in the pressed pin version only, for $130 a set...
Edit: Oh yeah they're in the "overstocked" section.
I just looked. Holy Christ, that's cheap! Guess I'm buying a set of rods tonight too! My wife is gonna kill you all!!!!!!
Scat Cast Crank, SIR Rods, Icon Forged Pistons = one very economical stroker....!!!!!! Should be perfect for what your planning
Who do you have in mind for the machine work & balancing....??????
Rickster
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061116
10/14/11 09:17 PM
10/14/11 09:17 PM
Tampa
DusterDave Offline OP
Tampa
Rickster
I'm familiar with big blocks and Hemi, but not so familiar with smallblock parts interchangeability. Before I place the order, does the 340 style crank fit the 318? I'm pretty sure it does, but I want to make sure.
http://www.cnc-motorsports.com/product.asp?ProdID=28133&CtgID=28131
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061117
10/14/11 10:28 PM
10/14/11 10:28 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
273/318/340 all shared the same stroke and bearing sizes. 340's had heavier counterweights to work with heavier rods. They can be mixed and matched, but you should probably have a mixed cubic inch assembly balanced to make sure there are not vibrations. Magnums also used different rods (smaller at the wrist pin, lighter pistons) than LA's, to that's another reason to balance if you are mixing Magnum and LA.
Re: MY JEEP BUILD THREAD [Re: GO_Fish] #1061118
10/14/11 11:33 PM
10/14/11 11:33 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
I agree, balancing is a must. I also agree on the 318/340 crank interchange. Matter of fact I used a 318-3 crank in a 340 once. I'm certainly not a small block guru but I have been studying some small block stuff for awhile!
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061119
10/14/11 11:44 PM
10/14/11 11:44 PM
Tampa
Tampa
Rickster
I'd love to have Dan at Performance Only do the machine work and balancing. I hear good and bad things about every one of the machine shops in my area, which makes me uneasy about going to any of them. If Dan does the work, I know I can sleep nights knowing that everything is spot on. The only downside is, its a hell of a long ride to bring the parts down to his shop.
Alright, the Eagle SIR rods and Scat crank have been ordered. That was some money originally earmarked to go towards the gear change and lockers for my Dana 44's, so that part of the project got set back a few weeks, but the upside is, the engine program got pushed forward.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061120
10/15/11 08:03 AM
10/15/11 08:03 AM
Rickster
I'm sure Dan would do a great job....I use "Mike Thompson Racing Engines" out of Naples (you see his stuff at all the race tracks in florida) and he's a racer himself. If you need anything holler
Rickster
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061121
10/15/11 11:33 AM
10/15/11 11:33 AM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Almost makes me wish I had a 318 to build one! This would be great for my sons 82. I do have a 318 but its an NOS Long Block, so I dont wanna bore it. LOL
Re: MY JEEP BUILD THREAD [Re: Jwilli500] #1061122
10/15/11 02:33 PM
10/15/11 02:33 PM
IMO you'd be better off starting with a 360 block....just makes sense to me if you don't have a block alraeady
Rickster
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061123
10/18/11 10:21 PM
10/18/11 10:21 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Dave if you are looking for someone local,give Kevin at Auto Performance Engines in Arburndale a call he does impeccable work and does quit a few mopars,even has a in house dyno.
For the most part he is a 1 man shop and does every thing him self in house except crank grinding.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: MY JEEP BUILD THREAD [Re: dusturbd340W5] #1061124
10/19/11 09:52 PM
10/19/11 09:52 PM
Tampa
Tampa
Thanks for the info. I've decided to go with Dan at Performance Only. I complained to Dan about the long distance I'd have to travel to bring my parts to him, and Dan was kind enough to offer to relocate his machine shop business to Tampa, just to build my stroker 318. Now THAT'S what I call customer service!!!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061125
10/23/11 11:21 AM
10/23/11 11:21 AM
Tampa
Tampa
Rusty and rotted back end of the frame has been cut off. The rest of the frame goes to the sandblaster shop tomorrow.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061126
10/24/11 01:47 PM
10/24/11 01:47 PM
Tampa
Tampa
Today, the brown Santa dropped off some bottom end parts for my 390.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061127
10/24/11 02:51 PM
10/24/11 02:51 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Good Santa.
Careful, your character's showing!
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061128
10/24/11 06:33 PM
10/24/11 06:33 PM
Cool Beans
Rickster
Re: MY JEEP BUILD THREAD [Re: rickstershemi] #1061129
10/24/11 09:49 PM
10/24/11 09:49 PM
Tampa
Tampa
I got two things done today. Dropped off the frame at the sandblaster's, and installed the replacement driver's side floor pan. I have two small cancer areas that need metal replacement, they are where the main hoop of the stock rollbar bolted to.
Re: MY JEEP BUILD THREAD [Re: DusterDave] #1061130
10/31/11 08:59 AM
10/31/11 08:59 AM
mopar346 Offline
mopar346  Offline
Dave,
I ran across these on the Jeep forum and didn't knwo if they would help with frame dimensions, so I thought I woudl share.
Good luck and keep up the post.
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061131
10/31/11 08:59 AM
10/31/11 08:59 AM
mopar346 Offline
mopar346  Offline
And another.
Re: MY JEEP BUILD THREAD [Re: mopar346] #1061132
10/31/11 04:16 PM
10/31/11 04:16 PM
Tampa
Tampa
Dave,
Thanks, but those don't look like my YJ frame.
