Re: Density alt, vapor press, or water grains???????? [Re: WILD BILL] #1060224
08/24/11 12:37 PM
08/24/11 12:37 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
The old stand-by was a sling psychrometer which is just two thermometers. One has a small sock on it that you keep damp,then you twirl the unit around in the air,look at the wet bulb vs dry bulb temperature and look up the result on a chart that will give you a vapor pressure number.
I have a copy of the chart if it will help you,but after using the psychrometer and a digital relative humidity gauge I can tell you thet don't always match up the way they should.
Keith
Re: Density alt, vapor press, or water grains???????? [Re: WILD BILL] #1060225
08/24/11 12:47 PM
08/24/11 12:47 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Density alt, vapor press, or water grains???????? [Re: pittsburghracer] #1060226
08/24/11 09:31 PM
08/24/11 09:31 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Bill I send my air box back in and had VP put in it because they said it was better to dial the Jr with.. they was right..
