Re: Need to go faster
[Re: fishy340]
#1058935
08/23/11 11:17 AM
08/23/11 11:17 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Yes u can do it with a .073 jet in a plate (Wilson I like), and 9 degrees out, with a stock block. I have done it many times. But realize you are running a gerenade with the pin pulled out. It will take that punishment but not alot. It takes alot to set up a proper nitrous system, 2nd fuel system, micro switch, timing retard, c16 feul, not just a 500 dollar kit.
hey Brad how come 340's can handle it..but 440's blow apart at 600hp after a few passes?
Don't know, my stock block lived up too a 350hp shot!! That was on two stages a .056 and .082 jet... 82 off the line and the 56 .85 seconds into the run stacked on top.
Brett Miller W9 cnc'd heads STR Chassis fabraction
