Re: 426 Hemi Swap 69 Cuda
[Re: MattW]
#1058849
08/21/11 09:15 PM
08/21/11 09:15 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
Ed Debevec's (715-267-7141) has complete pre fabbed A-body K-members. Mega Parts might have them to, but not listed on website. Then use the new A-body TTI headers. This is much easier and cheaper to do now that ever. Once TTI stepped up to the plate and made headers, then the K-member guys can make K-members to fit.
[Re: 3ddart]
#1058858
08/22/11 01:53 PM
08/22/11 01:53 PM
Posts: 641 Bergen County NJ
NoJoke
Bergen County NJ
if you go motor plate look in the mopar action magazine archives for the aricles steve maginate did about putting a 440 stage v hemi in his 67 dart. he use a poly bushing on 1 side of the motor plate so the motor could move a little. his is a street car. also i really like the paint on you cuda! dave
Hi Dave thanks its the original air brush paint from 1973 and I had the white redone about 4 yrs ago.. I will look for that artical you said. This car is a street driven car as well...
[Re: BloFish]
#1058860
08/22/11 10:32 PM
08/22/11 10:32 PM
NoJoke
Bergen County NJ
Would love to see this in the projects section so we all can keep up with your project
Yes I will.... The Cuda will be next inline to get done after the 65 Belvedere 1 car is done. So looks like I might just wait till the fall to do this project since im doing chassis work as well to the Cuda... Ill make sure I have plenty of pictures...
[Re: Troy]
#1058863
08/23/11 08:23 PM
08/23/11 08:23 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
Once you get the engine in there are a few things that you should do to make things clear. Steering column tube needs to be shortened by a couple inches so it clears the head. I don't remember the exact amount but you can see in the pictures the amount is no more than a few inches. Here is a shot before....
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#1058864
08/23/11 08:25 PM
08/23/11 08:25 PM
Troy
West Coast, CA
Here is a shot after it was cut down...
[Re: Troy]
#1058865
08/23/11 08:30 PM
08/23/11 08:30 PM
Troy
West Coast, CA
Brake system....You need an offset the master cylinder to make room for the valve cover. I used the bracket that you can get through either Mancini Racing or any Mopar Performance dealer. I made the lines myself saving a few bucks along the way.
[Re: Troy]
#1058866
08/23/11 08:45 PM
08/23/11 08:45 PM
Troy
West Coast, CA
OK, back to the headers. The headers are a 2 1/8 with a 3 1/2 collector. First of these are not a full tilt race header. They were never meant to be a full tilt race header....They are a kick a$$ street header that would work on a 700hp+ engine. If you want a race header....buy a race header. If you want a good bracket header....buy these headers. If you going SS/AH racing.....don't buy these headers.
OK so with that out of the way here are some pictures..
[Re: Troy]
#1058868
08/23/11 08:48 PM
08/23/11 08:48 PM
Troy
West Coast, CA
This is very cool. The TTI exhaust system bolts up to it with no problem at all!!
[Re: Troy]
#1058869
08/23/11 08:49 PM
08/23/11 08:49 PM
Troy
West Coast, CA
Steering linkage photos...
[Re: Troy]
#1058871
08/23/11 08:52 PM
08/23/11 08:52 PM
Troy
West Coast, CA
These headers where ment to run manual steering. I don't believe PS will work but not 100% sure on that.
[Re: Troy]
#1058872
08/23/11 08:57 PM
08/23/11 08:57 PM
Troy
West Coast, CA
That should do it for now. I'm getting the car back from the body shop by this weekend and the fist big step is to get the engine and trans in. Once it is in I will post up some more pictures.
[Re: NoJoke]
#1058874
08/24/11 03:06 AM
08/24/11 03:06 AM
Troy
West Coast, CA
....yes, give Sam a call. He told me that he was going to change one tube and they should work perfectly on a four speed.
[Re: Troy]
#1058875
08/24/11 04:23 AM
08/24/11 04:23 AM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
are the TTI set up for the K-fame shims, or can you run them without?
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: 68 HEMI GTS]
#1058876
08/24/11 08:39 PM
08/24/11 08:39 PM
Troy
West Coast, CA
Yes, the headers are set up for the 1/2" shims.
[Re: Troy]
#1058877
08/24/11 08:54 PM
08/24/11 08:54 PM
Troy
West Coast, CA
Here are a few more pictures. This is the K member that I built but you can buy one from Al Debevec (715) 267 7141. He had a REAL GOOD price for the K member, mounts and spacers.
[Re: Troy]
#1058879
08/24/11 08:58 PM
08/24/11 08:58 PM
Troy
West Coast, CA
picture of the body. I just took these about three hours ago. I should have it home it two to three days!!!
