Re: Pump Gas w/ 10% Ethanol
[Re: HotRodDave]
#1058542
08/26/11 11:43 PM
08/26/11 11:43 PM
Posts: 759 10,000 lakes and a swamp
aduster340
super street
super street
Haven't raced with it but every thing else is just the same. I have run up to 85% ethanol (not in flex fuel cars)and the biggest differance is the exhaust smells way better.
I'm waiting to get pulled over and be given a Breathalyzer test, because you can sure smell that alcohol! The only thing I dislike about E85 is the different seasonal blends that means 15-30% crap gas depending on the calendar, wish I could buy E100 at the pump..
[Re: goldduster318]
#1058545
08/27/11 03:26 PM
08/27/11 03:26 PM
Posts: 4,041 michigan woods
imfixinmopars426
michigan woods
I used to live in an area that didn't have it...moved to an area that did.
What I noticed: 1) Fuel goes bad a lot faster...Use Sta-Bil if you don't drive much 2) Had to re-tune the carb a bit, especially the idle mixture screws and choke setting 3) Gas mileage is about 10-15% worse 4) The car floods very easily when shut off hot from fuel boil off.
The stuff is crap...it creates even more havoc with my vintage lawn equipment...within one year it made the 37 year old gas tank in my lawn mower fail at the seam.
couldnt have said it better! ITS CRAP! ![](/ubbthreads/images/graemlins/fart.gif)
[Re: imfixinmopars426]
#1058546
08/27/11 05:30 PM
08/27/11 05:30 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I pulled a 96 stratus out of the woods the other day that had been sitting with 10% ethanol since 09 and the gas smelld new and the car started and ran perfect at the first touch of the key. Also my lawn mower started on the first pull this spring after sitting for 6 months with e-10 in the tank ![](/ubbthreads/images/graemlins/thumbs.gif) Never touched the carb on my 68 cuda switching from e-0 to e-85, not even a idle mix or speed adjust and the car never missed a beat (thermoquad). If your MPG dropped 10-15% something else is wrong, no way in hell that e-10 did that, I know it makes slightly less energy but if you lost 10% that means the ethanol did not burn at all, rum is ethanol and water and it burns so... something else is wrong with your car causeing your idleing problems and loss of MPG, you can't figure it out so blame it on the ethanol ![](/ubbthreads/images/graemlins/thumbs.gif) Alcohol causes great cooling when it evaporates and will vapor lock less than gasoline. Gasoline has many different chemicals in it and they all vapoize at different levals, some of them boil much lower than ethanol. Also a news flash for you, cars had vapor lock issues long before ethanol was put in the gas, even the old leaded gas would vapor lock, it was a constant battle for 100 years till all the cars had EFI. Ethanol is not anything like Methanol, all the symptoms people describe are Methanol problems not Ethanol.
[Re: HYPER8oSoNic]
#1058548
08/27/11 07:49 PM
08/27/11 07:49 PM
aduster340
super street
super street
I wonder if there is a DIFFERENCE in the octane level, between the "corn" type ethanol and the "sugar cane" type ethanol. Might be a bargaining issue for the U.S. if we decided to go with MORE of this "clean fuel" type technology in the racing world. Only problem is we don't produce as much sugar cane in U.S. (save for Hawaii and "shared" provinces), compared to corn (grain). ![](/ubbthreads/images/graemlins/Twocents.gif)
They grow cane sugar in Texas, Florida and Louisiana also. Ethanol can be made from lots of things. POET is building plants in Iowa and South Dakota that uses corn stover which is the non-food stuff that gets spit out of the combine, stalks, cobs etc. Industrial hemp would be the ultimate answer, it doesn't need cultivation, herbicides or pesticides and grows on marginal land. But that will never happen. ![](/ubbthreads/images/graemlins/down.gif)
[Re: HotRodDave]
#1058549
08/27/11 07:57 PM
08/27/11 07:57 PM
aduster340
super street
super street
Yeah I was a little worried about that (untreated ) E10 in my tank and my car had been sitting in the garage for 29 months. Old wives tales or urban myths?
Not sure how you got away with not jetting up or using bigger injectors for the E85, 30% is the general rule of thumb. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: kilroy]
#1058553
08/28/11 02:26 PM
08/28/11 02:26 PM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
... Anyway, it's subsidized. I don't expect others to help pay for my fuel.
Non ethanol gas is subsidized, so is food, so is the cotton in clothes, etc.... Bad line. At least the ethanol subsidizing stays in the farmers hands (whether you agree with that or not is another post).
How is 'Non ethanol gas subsidized'???
[Re: Pacnorthcuda]
#1058554
08/28/11 02:32 PM
08/28/11 02:32 PM
Challenger 1
Cincinnati, Ohio
exactly...how is it?
I think hotroddave grows corn...E10 is bad for everyone except the farmers and there suppliers. It sucks bad, E10. I could go on and on about the troubles it has caused. I sell gasoline for a living.
[Re: Challenger 1]
#1058555
08/28/11 03:07 PM
08/28/11 03:07 PM
Posts: 4,463 Michigan
MarkZ
Worthy
Worthy
I read through this entire post and I'm wondering if each different region's blend of seasonal gasoline in the US is the cause for some people's success stories, and others problem stories.
I personally have never had an issue with E10 sitting in the Fifth Avenue over the winter. Most years it'll sit for at least six months.
[Re: Challenger 1]
#1058556
08/28/11 03:25 PM
08/28/11 03:25 PM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
PROGRAM SUBSIDIES
Government support of US petroleum producers does not end with tax breaks. Program subsidies that support the extraction, production, and use of petroleum and petroleum fuel products total $38 to $114.6 billion each year. The largest portion of this total is federal, state, and local governments' $36 to $112 billion worth of spending on the transportation infrastructure, such as the construction, maintenance, and repair of roads and bridges. Other program subsidies include funding of research and development ($200 to $220 million), export financing subsidies ($308.5 to $311.9 million), support from the Army Corps of Engineers ($253.2 to $270 million), the Department of Interior's Oil Resources Management Programs ($97 to $227 million), and government expenditures on regulatory oversight, pollution cleanup, and liability costs ($1.1 to $1.6 billion).
http://www.progress.org/2003/energy22.htm
I dont know about hotrod dave, but Im not a farmer.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
[Re: PowerWagonDude]
#1058558
08/28/11 05:28 PM
08/28/11 05:28 PM
HotRodDave
Kalispell Mt.
I have not grown any corn (or any other crop of any sort)since I was 9 and all of those turned grey and you could not eat them ![](/ubbthreads/images/graemlins/puke.gif) I don't really know a whole lot about all the politics about it, just a few semi scientific experiments of my own, I got tired of hearing all the hype from both sides and tried some stuff for my self and it was very eye opening ![](/ubbthreads/images/graemlins/shock.gif) All that is happeing in the engine is it is running lean(gasoline engines can run lean also but they tend to melt things unlike ethanol). My theories as to why it seems to barely affect MPG in a non-flex fuel vehicle is the increased throttle angle required must be reduceing pumping losses and recovering some of the lost efficency. Also since alcohol has extra oxygen stuck to every molecule it is probably resulting in a more complete burn during the power stroke again gaining back some of the lost efficency, same principle as better atomization of gasoline, more is burned where it is usefull instead of the exhaust system. I do wish that we would quit paying farmers NOT to grow stuff, quit paying oil companys to research stuff they should pay for themselfs, quit paying ethanol subsidies. I don't think either should get subsidies, no one subsedizes my buisness. If a company can not stand on their own than they should close up shop. Ethanol can stand on it's own just like in other countries and they should do it here with out government help ![](/ubbthreads/images/graemlins/Twocents.gif)
