340 Stroker kits #1058199
08/20/11 10:01 PM
08/20/11 10:01 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
Since the cruising season is almost over, I am going to have my 71 340 rebuilt and after reading some posts on here I've decided to stroke it. It's a 71 motor that's already .40 over. What I'm looking for is the best stroker kits that are available out there.What I mean by best is what the best for your money. thanks.
Re: 340 Stroker kits [Re: Shatar4] #1058200
08/21/11 04:34 PM
08/21/11 04:34 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
Over 300 views and no replies. Interesting!
Re: 340 Stroker kits [Re: Shatar4] #1058201
08/21/11 05:01 PM
08/21/11 05:01 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
What are you going to do with it? Not everyone has the same needs/wants. What works for one guy in a street only low rpm combo will come apart like a dollar watch at 7000rpm. In my world kits don't work out well.
"Just a Bracket car dressed up like a streetcar"
Re: 340 Stroker kits [Re: Shatar4] #1058202
08/21/11 05:04 PM
08/21/11 05:04 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I have been thinking about one too, the past few years...gonna have to go with a brand name stuff...or even a company from the engine challenge in one of the mopar mags....
Re: 340 Stroker kits [Re: AARCONV] #1058203
08/21/11 05:09 PM
08/21/11 05:09 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
Street use only, no strip. Will hit the gas once in a while but not for a quarter mile. Just a respectable street motor.
Re: 340 Stroker kits [Re: Shatar4] #1058204
08/21/11 05:43 PM
08/21/11 05:43 PM
NY NY
3
340duster340 Offline
NY NY
if thats the case a stock 340 is respectable enough...if money is not an issue than i guess stroke away.
money is probably better spent on a good set of heads.
Re: 340 Stroker kits [Re: Shatar4] #1058205
08/21/11 05:43 PM
08/21/11 05:43 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
better off paying a few hundred more for the better stuff, my machinist likes the K1 4.125 crank with the chevy size rods, he also likes to try to get away with a .020 bore on 340's if he can.
Re: 340 Stroker kits [Re: Shatar4] #1058206
08/21/11 05:47 PM
08/21/11 05:47 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Sorry I can't help to much with that. I would say remember stroker motors add alot of cubic inches so if you don't increase head flow it will add more low end torque but not rpm as well.
Also talk to who ever is going to do the machine work about balancing, some kits do not internal balance well. Get their take on what you want to do before you spend money. just my
Re: 340 Stroker kits [Re: Just-a-dart] #1058207
08/21/11 06:29 PM
08/21/11 06:29 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I bought several K1 assemblies from both Todd (Competition Wedge) and Dan (performance Only). Both are Moparts members and you can't go wrong dealing with either one. They will take the time to find out what your goals are and help you reach them.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: 340 Stroker kits [Re: Shatar4] #1058208
08/21/11 07:02 PM
08/21/11 07:02 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Call Brian H at IMM if you want a Scat forged crank with I beam rods and Icon pistons...this is a well proven combo and more than you need for the street. A cast crank will hold up beautifully too. Forged or cast this is a well machined and great assembly for the buck.
BPE, sells the same cranks as K1 and now complete assemblies I believe. This will cost a bit more, but the BPE crank is a good piece and again the same thing as a k1.
Member DJVCuda is building I believe a 430 based on this setup. There is a thread on it.
These are my two choices and what I am roughly willing to spend when I do this for the street.
Re: 340 Stroker kits [Re: POS Dakota] #1058209
08/21/11 08:22 PM
08/21/11 08:22 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The scat cast crank kits are good value for thier money on a street motor.
Shater, you need more specifics and constrants of what you are looking for in the end. That is why you haven't got many responses. And not very detailed responses.
What are you constraints on:
Headers/manifolds
intake
carb
compression
idle characteristics/exhaust note
vacuum
desired HP range
Just off the top of my head.
Here's a 408 stroker with Scat kit, smooth cam, ebrock head, TTI headers that made ~480HP/500TQ: https://board.moparts.org/ubbthreads/show...part=1&vc=1
That should be a sweet street motor. I run a nearly identical setup in a 416 with a slightly hotter 274S cam and a cast crank Scat kit from IMM.
Re: 340 Stroker kits [Re: Shatar4] #1058210
08/21/11 09:25 PM
08/21/11 09:25 PM
Ottawa, ontario
dd340 Offline
dd340  Offline
Ottawa, ontario
Aren't .040 over 340 stroker pistons hard to find? I remember looking for them once and it seemed like the off the shelf pistons didn't go over a 4.070 bore. That's fine with a 360 but that limits a 340 to a 0.30 over bore. Maybe things have changed recently though.
Re: 340 Stroker kits [Re: autoxcuda] #1058211
08/22/11 10:27 PM
08/22/11 10:27 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
That is what I run cause mine is a street car. Just don't buy it balanced from Scat they do a terible job. Get a good local shop to balance it.
Re: 340 Stroker kits [Re: 69Cuda340S] #1058212
08/22/11 11:21 PM
08/22/11 11:21 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I bought mine balanced from Scat. Brian at IMM has had them checked and they were fine. Mine seems fine.
Re: 340 Stroker kits [Re: autoxcuda] #1058213
08/23/11 10:32 AM
08/23/11 10:32 AM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
It may have been posted before but who is IMM?
Re: 340 Stroker kits [Re: Shatar4] #1058214
08/23/11 10:45 AM
08/23/11 10:45 AM
SoCal
Brian Hafliger Offline
SoCal
IMM Engines! www.immengines.com I'm a member on here.
Thanks guys, glad your happy with everything!!
Brian
Brian Hafliger
Re: 340 Stroker kits [Re: 69Cuda340S] #1058215
08/23/11 11:24 AM
08/23/11 11:24 AM
crlush Offline
crlush  Offline
balance it yourself
Re: 340 Stroker kits [Re: Shatar4] #1058216
08/23/11 11:28 AM
08/23/11 11:28 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Add them up - for the parts I got and the condition / quality - the best bang for the buck was BPE - Rod's cranks are cheaper then anyone out there - he combines that with a compstar rod, and his own pistons and for my 4.125" stroker it was hands down the winner, Other places were up to a grand more for what I was getting in the rotating assembly.
I'd contact Rod Bloomer ( BPE on here ) and get a quote. - you will be impressed.
Re: 340 Stroker kits [Re: DJVCuda] #1058217
08/23/11 11:51 AM
08/23/11 11:51 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I already mentioned you princess!
I am probably going to do an assembly from Rod next. The parts are really nice stuff for a step up over the typical....when I need it.
Re: 340 Stroker kits [Re: Shatar4] #1058218
08/23/11 11:50 PM
08/23/11 11:50 PM
fiddlerfingers Offline
Seeing you are from SE Michigan then I would recomend Mike Liston at MRL Performance in Jackson MI. He was in the enguine build off for Mopar Mag last year and can build you a awesome stroker... My 340 was done by mike last year and turned 502 HP at 5600 RPM and 510 FT Torque. He is also a member here and if you contact him he can help you find what you are looking for at a good price. Stay away from Muscle Motors...
