Re: Is my car still that fast ? [Re: 383man] #1058002
08/21/11 04:54 PM
08/21/11 04:54 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Ron, I don't know if you'll be a full second fatser but it's gonna run 10's easy. Hope you have fun with it. Can't wait to get back to the track and run this thing. Its hard to keep my foot off the go pedal.
Coming soon!!!!
Re: Is my car still that fast ? [Re: 383man] #1058003
08/21/11 05:26 PM
08/21/11 05:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
For me its ALWAYS been how a car launches off the line
be it street or the strip... once I shift to second it
all sorta gets slow.... I sure would like to get into
something like a PS just for the launch... a 1.19 60'
is a GOOOOD feeling but I want more but I dont think
that will EVER happen
Re: Is my car still that fast ? [Re: MR_P_BODY] #1058004
08/21/11 09:27 PM
08/21/11 09:27 PM
Cab_Burge Online work
Cab_Burge  Online Work
Ron, I feel your pain, you do get use to some cars and the sensation of speed, I have been experiminting with parts on my Duster this year, found that I needed .120 needles in seats in all the Holley carbs. regardless of which rated CFM and type, 4150 0r 4500, 850 or 1050 CFM and in between. Last month I took the car to Woodburn for the Mopar race,I ran it some on Friday afternoons test and tune with the 850 Holley DP and 400-2 intake, it ran a little slower with the bigger needle and seat than the month before over there but the wideban showed it to be pig rich. I switch intakes and carbs. to a 1050 Dominator and a 400-3 intake, the car ran 10.40s at 126 MPH with the 850 and picked up to 10.03 at 133.45 MPH, I didn't feel that it picked up that much It did pull a lot better on the other end, ended up it had one .110 needles and seat in the rear float bowl and a .120 in the front when i got it home(the wideban showed it to be arginall lean) I forgot to check both before using it:o I ran it at Madras(1/8 mile) at the last race with the new .120 needle and seat in the rear and it picked up from 6.80 at 101 MPH to 6.48 at 105.7 MPH, no other changes I didn't feel that change either
Re: Is my car still that fast ? [Re: Cab_Burge] #1058005
08/21/11 09:39 PM
08/21/11 09:39 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Well I'll soon (I hope, with work the way it is) see what a solid roller will do for my junk. Got the motor pretty much buttoned up today and it's sitting on the dyno. Have to finish installing the tunnelram, reset the carbs, finish hooking everything up and load the motor. I'm hoping it'll break 700hp. Dave
