Re: Eddy single 4 intake for 5.7 ??
[Re: HotRodDave]
#1057904
08/20/11 09:52 PM
08/20/11 09:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The sales volume thing is BS because eddy does make the dual quad one with a more complicated casting and less people are gonna use it than they would a single 4. I am not oposed to paying more than a chevy guy for similar parts but this is out in left field even for mopar. Heck even the mopar single 4 not drag-pak intake is $1000 that is FOUR times the price of the chevy one not just double even
Well I guess you can get out your tig welder and make one
[Re: MattW]
#1057905
08/20/11 10:31 PM
08/20/11 10:31 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Instead of complaining, there's market opportunity, make the investment and develop, manufacture & sell an affordable intake.
my attempt
LOL If the runners line up use a block of wood. Plus you get the thermo break.LOL
I will be flowing the Apache heads in the near future same flow bench as before. Matt
close
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: HotRodDave]
#1057906
08/21/11 02:48 AM
08/21/11 02:48 AM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
So aparently Indy makes one that is the cheapest, they call it a "Mod-Man" and it comes with removable tops to put whatever carb I want on it, any one ever use one of those? How do they do with fuel distribution at lower engine speeds on a stockish 5.7 engine?
[Re: HotRodDave]
#1057907
08/21/11 09:21 AM
08/21/11 09:21 AM
sixpackgut
Charleston
i have a PM sent to TR Waters asking if he has already has a design to adapt an early hemi intake to the GEN 3 engines. i believe he does and if so you can run this intake
[Re: sixpackgut]
#1057908
08/21/11 10:31 AM
08/21/11 10:31 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
my attempt
OK I'm confused, what intake is that for? P7?
[Re: TrWaters]
#1057912
08/21/11 01:16 PM
08/21/11 01:16 PM
HotRodDave
Kalispell Mt.
SO that is interesting I guess it brings up the question how much is that dual plane intake? Who makes it? and how much are the red spacer thingies?
[Re: TrWaters]
#1057917
08/21/11 03:00 PM
08/21/11 03:00 PM
Posts: 2,128 sweden
sshemi
sweden
Are those parts avaliable and for sale? I really like the front cover with the dist.
[Re: TrWaters]
#1057918
08/21/11 04:12 PM
08/21/11 04:12 PM
MattW
Ontario Canada
Jerry, Just an observation, but seems the gen3 hemi likes those long intake runners. I'll stick to my old stuff.
Easiest way to explain it is to flow an exhaust port with a generic header on it even with cold air the temp rise in the header a the first bend is remarkable. That why Dyno headers usually product more. Truck intake and 6.1 are great for EFI but would run poor if the mixture had to go throught it. That is why the jiggle juice doesn't work so well with those intakes. IMO a composite intake like the dragpack intake with different heights would work well. the more i research this the more I am leaning to EFI. U can pick an 09 to present composite intake from dodge for 214.00.
Matt
[Re: sshemi]
#1057919
08/21/11 04:43 PM
08/21/11 04:43 PM
Posts: 2,129 Vermont
TrWaters
Vermont
It was all just a personal experiment. Way too costly to produce.....or reproduce....just to say you have a distributor. Cheaper to buy an intake and carb, add the MSD ignition box and go.
I am not sure what my buddy is using for electronics in this car. It is a 671 BDS with EFI.
