Pictures of Mini-tubbed 67-69 Darts #1057776
08/19/11 11:47 PM
08/19/11 11:47 PM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
Like to see how you guys have yours setup and what tires you run? Whats the biggest drag radial without rubbing or cutting. Just mini tubbing?
Re: Pictures of Mini-tubbed 67-69 Darts [Re: DaKuda] #1057777
08/20/11 04:35 AM
08/20/11 04:35 AM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Not mini tubbed. I run the Hoosier 275/60/15 Drag Radial. I have the offset leaf spring mounts.
Re: Pictures of Mini-tubbed 67-69 Darts [Re: DaKuda] #1057778
08/20/11 05:29 AM
08/20/11 05:29 AM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
275/60/15 on 7inch steel wheel, Narrowed c body rear,springs on
frame rail. Mike
Re: Pictures of Mini-tubbed 67-69 Darts [Re: mkdart] #1057779
08/20/11 05:54 AM
08/20/11 05:54 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
325/50
Re: Pictures of Mini-tubbed 67-69 Darts [Re: justinp61] #1057780
08/20/11 05:56 AM
08/20/11 05:56 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Another.
Re: Pictures of Mini-tubbed 67-69 Darts [Re: justinp61] #1057781
08/20/11 07:17 AM
08/20/11 07:17 AM
Lees Summit, MO
BrianT Offline
BrianT  Offline
Lees Summit, MO
Mines the same as Justin's. Mini tubbed, springs moved in, narrowed Dana. 325/50s on 15x10 wheels. I trimmed the the inner fender back about 1/4 inch and also ground down the seam where the tub meets the frame. Careful measurements and everything fit fine, but that is the biggest you can go without back halfing it.
And yeah, I know my tires are on backwards!!!
1970 Duster 340 clone
Re: Pictures of Mini-tubbed 67-69 Darts [Re: DaKuda] #1057782
08/20/11 03:34 PM
08/20/11 03:34 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Here are a couple of pics of my junk. I ran m/t 325/50 drag radials on it at first, but for me the bias et streets or hoosier qtp are more consistant when the track is funky. Now 29x13.5x15 QTPs (11" tread)
"Just a Bracket car dressed up like a streetcar"
Re: Pictures of Mini-tubbed 67-69 Darts [Re: Just-a-dart] #1057783
08/20/11 10:09 PM
08/20/11 10:09 PM
Richmond , Virginia
BEEQUIK Offline
BEEQUIK  Offline
Richmond , Virginia
30x13.50 et streets on 10 inch rims...
Re: Pictures of Mini-tubbed 67-69 Darts [Re: BEEQUIK] #1057784
08/20/11 11:06 PM
08/20/11 11:06 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
A long tine ago... about 10-15 years to be more exact... before radials. 10.5x30 M/T ET Streets. Springs moved in to the frame rails and opening stretched a little in the front.
Re: Pictures of Mini-tubbed 67-69 Darts [Re: Bigcube] #1057785
08/20/11 11:12 PM
08/20/11 11:12 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Eventually I built a belly pan to cover the gaping hole
Re: Pictures of Mini-tubbed 67-69 Darts [Re: Twin Turbo Mower] #1057786
08/20/11 11:36 PM
08/20/11 11:36 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
68. Mini tubbed. Dana 60. 325-50 MTs
codfish
