Page 26 of 31 1 2 24 25 26 27 28 30 31
Re: Design me a late model Hemi bracket engine [Re: 1badx] #1057409
02/06/12 08:26 PM
02/06/12 08:26 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
How hard would it be to modify the OEM throttle body to be cable driven?
That certainly is an option and I have seen engine dyno shops do this. With option #2 that would be up to the installer of the system. I do have a 5.7 OEM throttle body for sale for $50 if you want to buy it, crack it open and give it a try?
Hot Rod did this about 4 yrs ago with a factory crate engine with factory ECM.
They poped open the cover and mig welded the Dyno throttle to it.
They didnt seem to have any problems but it is Hot Rod.
U have a PM
Re: Design me a late model Hemi bracket engine [Re: wldtm] #1057410
02/06/12 09:24 PM
02/06/12 09:24 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Chrysler sells their connectors in a pigtail form, currently not just the connector and terminals. This is one reason Painless said they were not interested in doing an factory efi swap.
Thanks for that info. Anybody have a connection at Chrysler I can contact for good prices on the pigtails?
Re: Design me a late model Hemi bracket engine [Re: 1badx] #1057411
02/06/12 10:10 PM
02/06/12 10:10 PM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
rember guys ritter will have some of his new drag pack intakes @ the indy show in march
Re: Design me a late model Hemi bracket engine [Re: jg309] #1057412
02/07/12 01:36 AM
02/07/12 01:36 AM
Canada
onig Offline
onig  Offline
Canada
While reading this thread I was wondering if anybody had looked into the megasquirt controller to do the job.
Just a thought.
69 Dart
Re: Design me a late model Hemi bracket engine [Re: 1badx] #1057413
02/07/12 01:00 PM
02/07/12 01:00 PM
Tulsa oklahoma USA
2
2734bbl Offline
2734bbl  Offline
Tulsa oklahoma USA
I've got 2 complete 05 5.7 cores, both with rod knock. I'm just sponging up info to put one together. My plan is to go with a basically stock motor first time around and get the car sorted out then go big later.
Re: Design me a late model Hemi bracket engine [Re: 2734bbl] #1057414
02/07/12 07:58 PM
02/07/12 07:58 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
It really depends on what level of labor you are willing to put in to the build. If you can handle some basic cylinder head porting do a little bit of research and grab a die grinder and some bits and rolls. You can make the 5.7 heads flow almost as much as stock 6.1's. If you haven't ported heads before then just buy a set of either 6.1's (they may be pricey) or a set of Apache's ($650 last time I checked). I can make some cam recommendations as well depending on your requirements. Order a set of TTI headers, decide if your going carb or fuel injection and finish the build from there.
5.7's are beastly engines!
BTW - I have spare rods, pistons and cranks for sale in the classifieds if you want to use stock rotating parts.
Re: Design me a late model Hemi bracket engine [Re: onig] #1057415
02/07/12 08:11 PM
02/07/12 08:11 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
I've got a 5.7 Turbo motor in the works. Will be MegaSquirted...just like my 440 was.
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Design me a late model Hemi bracket engine [Re: Dave_S] #1057416
02/07/12 08:31 PM
02/07/12 08:31 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
That makes two of us! (and I suspect there are more similar combo's lurking out there )
5.7, 6.1 crank, forged rods and pistons, 6.1 CNC heads, 6.1 intake and a rear mount PT94 running a MS3.
Re: Design me a late model Hemi bracket engine [Re: 1badx] #1057417
02/07/12 08:44 PM
02/07/12 08:44 PM
Dave_S Offline
Dave_S  Offline
Is yours going into the GTX?
Will it be street driven?...what comp.ratio you go with?
Mine will go into the Dart, strip only with a front mounted 88
Dave Stillie
'73 Swinger
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Design me a late model Hemi bracket engine [Re: Dave_S] #1057418
02/07/12 08:52 PM
02/07/12 08:52 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Yes, it's going in the GTX. It will be primarily a street driven/street class raced vehicle (like it is now). There is a cool event in the area called "The Flashlight Drags" that we sponsor. They advertise it as "Street racing without the jail time " To be competitive in the "Big Dawg" class you need to be able to run high 8's or low 9's in street trim in the 1/4.
Re: Design me a late model Hemi bracket engine [Re: 1badx] #1057419
02/07/12 09:43 PM
02/07/12 09:43 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Lets say I want to build a bracket motor out of one of these next year, where can I look at after market rods, pistons, and crank? Does anyone make an aluminum rod for them? Forged crank? Forged blower pistons? Mechanical cam? I run a nostalgia series, and been thinking of running 6-71 blown race motor on E85 with mechanical injection.
All the ads I look at say crank rods and pistons, but, since hardly any specifiy forged, I assume they are cast junk...And not worth my time or money. I don't want a stock replacement time bomb either. Just looking for some links that have more info than your basic BS that I keep reading over and over....And why do I need a reluctor wheel on the crank, I am thinking I don't, but figured I would ask?
Re: Design me a late model Hemi bracket engine [Re: Dragula] #1057420
02/07/12 11:08 PM
02/07/12 11:08 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
I am a dealer for PWR racing engines who specialize in the Gen III Hemi's. I can get you either stock 6.1 forged, Callies, Manley or SCAT cranks as well as rods and pistons. Yes, you can get forced induction pistons or a complete rotating assembly in all the common strokes.
I guess you can make your own crank trigger but why?
Re: Design me a late model Hemi bracket engine *DELETED* [Re: 1badx] #1057421
02/08/12 08:03 AM
02/08/12 08:03 AM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
Post deleted by jg309
Re: Design me a late model Hemi bracket engine [Re: jg309] #1057422
02/22/12 08:47 PM
02/22/12 08:47 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
In keeping with this thread, found out the Fiat WAS selling a complete 6.4 PRODUCTION HEMI 5037400AA which was superseded by 5037400AF.
Retails for 6237.00 But has a NS5 code attached to it
Man wish I would of known this sooner.Matt
Re: Design me a late model Hemi bracket engine [Re: MattW] #1057423
02/22/12 08:59 PM
02/22/12 08:59 PM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
talked to kent a while a go said he thought he'd have 2-3 intakes for the indy show, so if interested look him up at the show,don't know were he'll be russ took his usual spot away from him,he also told me he's going to have one of his new alum. small blocks there allso,thats about it later my freinds
Re: Design me a late model Hemi bracket engine [Re: jg309] #1057424
02/22/12 09:14 PM
02/22/12 09:14 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Aluminum LA or G3 blocks
Re: Design me a late model Hemi bracket engine [Re: MattW] #1057425
02/22/12 11:04 PM
02/22/12 11:04 PM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
NS5 ?? OK, I'll bite...for those of us (maybe just me)that don't know, what exactly does this mean? I know the NS is not sold/serviced
Re: Design me a late model Hemi bracket engine [Re: cagebob1] #1057426
02/23/12 09:24 AM
02/23/12 09:24 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I don't know thought somebody would?
Re: Design me a late model Hemi bracket engine [Re: MattW] #1057427
02/23/12 05:57 PM
02/23/12 05:57 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
NS5 means "Serviced In Component Parts"
So, production/service doesn't want to sell it.
And that means MP needs to try harder to sell it!
Rich H.
Esse Quam Videri
Re: Design me a late model Hemi bracket engine [Re: ZIPPY] #1057428
02/23/12 07:08 PM
02/23/12 07:08 PM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
matt its a la block
