Page 17 of 31 1 2 15 16 17 18 19 30 31
Re: Design me a 3G Hemi bracket engine [Re: Irun5snd8th] #1057229
11/04/11 06:25 PM
11/04/11 06:25 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Wondered about this,,,,planning on a belt driven 3 stage pump on my build....power steering/fuel/engine oil.
If you like drag racing, support your local track.
Re: Design me a 3G Hemi bracket engine [Re: CHAPPER] #1057230
11/04/11 07:26 PM
11/04/11 07:26 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Good thought since the similarity to LS engines is so great.
My question is: Assuming that were true, then why would the middle rods have the issue?
Wouldn't a cavitation issue show up either in the main bearings, or the rods furthest from the oil pump first?
Not trying to start anything, but it's been explained/described to me the windowed examples usually have mains still in good condition, and the remaining rods are still good as well, but the center rods wanted to get out of the block. At least that's where the mystery originated on my end.
Rich H.
Esse Quam Videri
Re: Design me a 3G Hemi bracket engine [Re: ZIPPY] #1057231
11/04/11 08:43 PM
11/04/11 08:43 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Think of the LA engine like I previous stated but I would like to know "At what RPM"
I don't know if I am right but it make sense
Re: Design me a 3G Hemi bracket engine [Re: Irun5snd8th] #1057232
11/04/11 10:43 PM
11/04/11 10:43 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
So how is the build coming along?
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Design me a 3G Hemi bracket engine [Re: MattW] #1057233
11/04/11 11:05 PM
11/04/11 11:05 PM
MN
hemidup Offline
hemidup  Offline
MN
sixpackgut.....Post up the pic's of your header collectors
Jerry Williams.
Re: Design me a 3G Hemi bracket engine [Re: hemidup] #1057234
11/05/11 12:31 AM
11/05/11 12:31 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Re: Design me a 3G Hemi bracket engine [Re: sixpackgut] #1057235
11/05/11 03:54 PM
11/05/11 03:54 PM
MN
hemidup Offline
hemidup  Offline
MN
Thanks Ray. So does anyone see what I'm seeing? I brought this up with Kevin Helms once I looked at his header design on Teuton's windowed 6.1 block at the Nat's.
Jerry Williams.
Re: Design me a 3G Hemi bracket engine [Re: hemidup] #1057236
11/05/11 04:58 PM
11/05/11 04:58 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
R U saying that the header design is responsible for the widowed 6.1 block?
Or R U saying U don't like the design of the header.
Re: Design me a 3G Hemi bracket engine [Re: hemidup] #1057237
11/05/11 05:02 PM
11/05/11 05:02 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
No, but I'm hoping you'll tell us what it is you see.
Re: Design me a 3G Hemi bracket engine [Re: STEFF] #1057238
11/07/11 12:08 PM
11/07/11 12:08 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Jerry? please let us know what your seeing
Re: Design me a 3G Hemi bracket engine [Re: hemidup] #1057239
11/07/11 12:52 PM
11/07/11 12:52 PM
Mesa, AZ
Bill_T Online content
Bill_T  Online Content
Mesa, AZ
I will take a WAG. Is that an O2 sensor bung on the side? It does not seem like it would get as good of a read on the outside two pipes. In fact, flow is almost directed past it on the outside - it is too close to the merge point?
Re: Design me a 3G Hemi bracket engine [Re: Bill_T] #1057240
11/07/11 01:17 PM
11/07/11 01:17 PM
IN
Irun5snd8th Offline OP
IN
The response I got was to main bearing issues rather than the rods being tossed.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Design me a 3G Hemi bracket engine [Re: Bill_T] #1057241
11/08/11 02:15 AM
11/08/11 02:15 AM
MN
hemidup Offline
hemidup  Offline
MN
Thank you very much for your observation and reply. Whats a WAG?
Jerry Williams.
Re: Design me a 3G Hemi bracket engine [Re: sixpackgut] #1057242
11/08/11 02:24 AM
11/08/11 02:24 AM
MN
hemidup Offline
hemidup  Offline
MN
Give me a call at the shop. Probably sometime next week. I've been at the hospital with my wife for the past week. Since your not building a SE or SS motor, I'll talk to you about my theories.
Jerry Williams.
Re: Design me a 3G Hemi bracket engine [Re: hemidup] #1057243
11/08/11 09:46 PM
11/08/11 09:46 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
i need help. Again!
so the oil filter wont screw off so i guess i need to run a relocation kit, or jack up the motor every time i change the oil
so the question is, what is the thread size on the hemi engines? does anyone recommend a good value on a oil filter reloction kit?
Re: Design me a 3G Hemi bracket engine [Re: sixpackgut] #1057244
11/08/11 10:28 PM
11/08/11 10:28 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Do you have the filter adapter that points the filter to the front,,or no adapter that puts the filter straight down?? The thread on the block, without the adapter, is 18mmx1.5.
Re: Design me a 3G Hemi bracket engine [Re: CHAPPER] #1057245
11/08/11 10:35 PM
11/08/11 10:35 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
do those adapters come on new cars? i have the filter pointing straight down
Re: Design me a 3G Hemi bracket engine [Re: sixpackgut] #1057246
11/08/11 10:47 PM
11/08/11 10:47 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
The core engine I am working with, came out of an '06 truck...it had an adapter that pointed the filter toward the front. I also feel that the filter area may be of some concern contributing to the afore mentioned bearing problems...LOTS of small passages and restrictive angles involved in the castings. I am eliminating these with an external oil pump system that will feed into the hole right above the filter..with some minor mods to the original feed hole in the block, and a remote filter set-up.
Re: Design me a 3G Hemi bracket engine [Re: CHAPPER] #1057247
11/08/11 11:47 PM
11/08/11 11:47 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
i have an 06 truck 5.7 out in the shop that doesnt have that adapter. also, i screwed one of my big block oil filters on the 5.7 so i dont think its an 18mm thread but maybe i'm wrong
Re: Design me a 3G Hemi bracket engine [Re: sixpackgut] #1057248
11/09/11 12:14 AM
11/09/11 12:14 AM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
looks like this.
use to be about 30$.
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
