Re: Design me a 3G Hemi bracket engine
[Re: sixpackgut]
#1057131
09/30/11 12:53 AM
09/30/11 12:53 AM
Posts: 2,864 IN
Irun5snd8th
IN
I only know of one car running that Jesel setup and its a Super Stocker that was at Indy. He was running 9.70's at 3400 lbs and scratching his head at why he couldnt outrun Barton. I think you are right Gut to go your route. Too many of them stockers buzzing to 8500 to think you need some kind of crazy spring.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: MattW]
#1057133
09/30/11 12:40 PM
09/30/11 12:40 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I cut a pushrod in half, measured the wall at .060, called smith bros and asked them what they thought about the stock 7 and 8 inch 5/16ths 60 wall pushrods with 330lb spring pressure and they said they should hold up just fine. stock pushrods are 55 cents a piece
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1057135
09/30/11 08:44 PM
09/30/11 08:44 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
just got an email on the 6.4 heads
http://gotogroupbuy.com/1905/Group-Buy-Deal-Dodge-Challenger-64L-Cylinder-Heads-Discount-Sale.aspx
Are those the prefered heads to get?
Are those heads a great deal at $800?
IDK. i got my eagles for $450 for 2. i'm not sure if that $800 is for 1 or 2. if 2 then its probably a really good deal
It better be for two or you are getting hosed.
it's for 2 heads. is it a good deal for 2? i see the eagles are up to $460 a head now
Yup thants a good deal but how much for shipping? Got mine for 1000.00 taxes in and shipping from a dealer. Go this today hopefully it is a 6.4 production crank.
[Re: MattW]
#1057136
10/02/11 06:12 PM
10/02/11 06:12 PM
Posts: 288 IL. Jerseyville
jg309
IL. Jerseyville
hey matt i don't know if this something you'd be looking for, but seen it thought you'd like to see for yourself, go to www.xvmotorsports.com, see if this intake can help you, just let if it dose or dosen't
[Re: jg309]
#1057137
10/02/11 06:36 PM
10/02/11 06:36 PM
MattW
Ontario Canada
I already looked into that. I believe the production truck intake is a better piece. The intake runners turn too sharply to take advantage if the straight shot intake port.
Now if xv would cast that intake like a tunnel ram then they would have something. I think the reason they cast it that way is so it would fit older muscle cars without hood modifications.
Thanks for the info.
[Re: MattW]
#1057138
10/03/11 10:13 AM
10/03/11 10:13 AM
Posts: 2,864 IN
Irun5snd8th
IN
I agree with Matt on the intake. Only appears to be one good race intake at this point.
[Re: Irun5snd8th]
#1057139
10/09/11 06:00 PM
10/09/11 06:00 PM
sixpackgut
Charleston
any difference in balancers on these engines?
the 5.7 balancer i have isnt keywayed
[Re: sixpackgut]
#1057140
10/09/11 08:32 PM
10/09/11 08:32 PM
MattW
Ontario Canada
I think they are all like that, pressed on. Not certain though. Hows the build coming?
[Re: sixpackgut]
#1057142
10/10/11 03:39 PM
10/10/11 03:39 PM
Posts: 2,864 IN
Irun5snd8th
IN
So in the spirit of the thread; what is your combination?
[Re: Irun5snd8th]
#1057143
10/10/11 03:55 PM
10/10/11 03:55 PM
sixpackgut
Charleston
bought a 426 from a wrecked car that had a novi on it. put eagle heads that i did some porting on. more work on exhaust side. backcut on the valves. the cam comes in at a whopping .549 lift with 208 [Email]duration@50.[/Email] the stock replacment valve springs that i posted earlier. tti 2" headers and a hot heads intake for a 392 that was modded to fit a G3. the intake lid is a single Dom application but i suspect it may give me fuel dist problems but for what i was just able to buy a carb for i figured i could make money on it anyway so i will give it a try. k1 crank and rods, JE pistons
[Re: sixpackgut]
#1057144
10/11/11 01:19 AM
10/11/11 01:19 AM
Posts: 2,864 IN
Irun5snd8th
IN
Sounds interesting. Will be anxious to see what it does for you.
[Re: jg309]
#1057146
10/13/11 10:49 PM
10/13/11 10:49 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
5.7 bore= 3.91 Stroke 3.58 6.1 bore=4.055 stroke 3.58
I have been gathering parts. Here are some deals I scored.
5.7 core - 250$ 6.1 forged crank 150$ to my door Eagle heads- 500-675 depending where you buy.
Still need: Drag pack intake-750$ Cam/lifters/pushrods-? Rods-thinking having the crank turned down to drag pack size 2.100 rod Pistons-Not sure yet?
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
[Re: jg309]
#1057148
10/14/11 07:56 PM
10/14/11 07:56 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
I have some questions... *What timing chain/gear set is being used? *Are the stock valves holding up in a race application? *What valve spring is being used? *Any preference to the MSD or the FAST ignition set-up? *What about the stock crank pulley/dampner..no keyway..should a better dampner be installed with a keyway..?? *Oil pan availability for 5.7 for dirt track use? Just a few for now,,,I KNOW I will have more later...
If you like drag racing, support your local track.
