Page 12 of 31 1 2 10 11 12 13 14 30 31
Re: Design me a 3G Hemi bracket engine [Re: sixpackgut] #1057129
09/29/11 11:01 PM
09/29/11 11:01 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
just got an email on the 6.4 heads
http://gotogroupbuy.com/1905/Group-Buy-Deal-Dodge-Challenger-64L-Cylinder-Heads-Discount-Sale.aspx
Are those the prefered heads to get?
Are those heads a great deal at $800?
Re: Design me a 3G Hemi bracket engine [Re: HEMIDARTS] #1057130
09/29/11 11:13 PM
09/29/11 11:13 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
IDK. i got my eagles for $450 for 2. i'm not sure if that $800 is for 1 or 2. if 2 then its probably a really good deal
Re: Design me a 3G Hemi bracket engine [Re: sixpackgut] #1057131
09/30/11 12:53 AM
09/30/11 12:53 AM
IN
Irun5snd8th Offline OP
IN
I only know of one car running that Jesel setup and its a Super Stocker that was at Indy. He was running 9.70's at 3400 lbs and scratching his head at why he couldnt outrun Barton.
I think you are right Gut to go your route. Too many of them stockers buzzing to 8500 to think you need some kind of crazy spring.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Design me a 3G Hemi bracket engine [Re: sixpackgut] #1057132
09/30/11 08:30 AM
09/30/11 08:30 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
It better be for two or you are getting hosed.
Re: Design me a 3G Hemi bracket engine [Re: MattW] #1057133
09/30/11 12:40 PM
09/30/11 12:40 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
I cut a pushrod in half, measured the wall at .060, called smith bros and asked them what they thought about the stock 7 and 8 inch 5/16ths 60 wall pushrods with 330lb spring pressure and they said they should hold up just fine. stock pushrods are 55 cents a piece
Re: Design me a 3G Hemi bracket engine [Re: MattW] #1057134
09/30/11 01:12 PM
09/30/11 01:12 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
it's for 2 heads. is it a good deal for 2? i see the eagles are up to $460 a head now
Re: Design me a 3G Hemi bracket engine [Re: sixpackgut] #1057135
09/30/11 08:44 PM
09/30/11 08:44 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Yup thants a good deal but how much for shipping?
Got mine for 1000.00 taxes in and shipping from a dealer.
Go this today hopefully it is a 6.4 production crank.
Re: Design me a 3G Hemi bracket engine [Re: MattW] #1057136
10/02/11 06:12 PM
10/02/11 06:12 PM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
hey matt i don't know if this something you'd be looking for, but seen it thought you'd like to see for yourself, go to www.xvmotorsports.com, see if this intake can help you, just let if it dose or dosen't
Re: Design me a 3G Hemi bracket engine [Re: jg309] #1057137
10/02/11 06:36 PM
10/02/11 06:36 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I already looked into that.
I believe the production truck intake is a better piece.
The intake runners turn too sharply to take advantage if the straight shot intake port.
Now if xv would cast that intake like a tunnel ram then they would have something.
I think the reason they cast it that way is so it would fit older muscle cars without hood modifications.
Thanks for the info.
Re: Design me a 3G Hemi bracket engine [Re: MattW] #1057138
10/03/11 10:13 AM
10/03/11 10:13 AM
IN
IN
I agree with Matt on the intake. Only appears to be one good race intake at this point.
Re: Design me a 3G Hemi bracket engine [Re: Irun5snd8th] #1057139
10/09/11 06:00 PM
10/09/11 06:00 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
any difference in balancers on these engines?
the 5.7 balancer i have isnt keywayed
Re: Design me a 3G Hemi bracket engine [Re: sixpackgut] #1057140
10/09/11 08:32 PM
10/09/11 08:32 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I think they are all like that, pressed on. Not certain though.
Hows the build coming?
Re: Design me a 3G Hemi bracket engine [Re: MattW] #1057141
10/09/11 08:45 PM
10/09/11 08:45 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
its basically all together. doing some porting on the intake. just because. picked up a dominator for a song and a dance so I'm going to try the intake with a Dom before i make a change to dual quads.
i'm in need of a converter and maybe a VB for the trans. think it has a reverse VB in my SB trans i have and i cant use that with a slap stick
Re: Design me a 3G Hemi bracket engine [Re: sixpackgut] #1057142
10/10/11 03:39 PM
10/10/11 03:39 PM
IN
IN
So in the spirit of the thread; what is your combination?
Re: Design me a 3G Hemi bracket engine [Re: Irun5snd8th] #1057143
10/10/11 03:55 PM
10/10/11 03:55 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
bought a 426 from a wrecked car that had a novi on it. put eagle heads that i did some porting on. more work on exhaust side. backcut on the valves. the cam comes in at a whopping .549 lift with 208 [Email]duration@50.[/Email] the stock replacment valve springs that i posted earlier. tti 2" headers and a hot heads intake for a 392 that was modded to fit a G3. the intake lid is a single Dom application but i suspect it may give me fuel dist problems but for what i was just able to buy a carb for i figured i could make money on it anyway so i will give it a try. k1 crank and rods, JE pistons
Re: Design me a 3G Hemi bracket engine [Re: sixpackgut] #1057144
10/11/11 01:19 AM
10/11/11 01:19 AM
IN
IN
Sounds interesting. Will be anxious to see what it does for you.
Re: Design me a 3G Hemi bracket engine [Re: Irun5snd8th] #1057145
10/13/11 09:34 PM
10/13/11 09:34 PM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
hy guys whats the standard bore on these engines,thanks
Re: Design me a 3G Hemi bracket engine [Re: jg309] #1057146
10/13/11 10:49 PM
10/13/11 10:49 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
5.7 bore= 3.91 Stroke 3.58
6.1 bore=4.055 stroke 3.58
I have been gathering parts. Here are some deals I scored.
5.7 core - 250$
6.1 forged crank 150$ to my door
Eagle heads- 500-675 depending where you buy.
Still need:
Drag pack intake-750$
Cam/lifters/pushrods-?
Rods-thinking having the crank turned down to drag pack size 2.100 rod
Pistons-Not sure yet?
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: Design me a 3G Hemi bracket engine [Re: wldtm] #1057147
10/14/11 06:45 AM
10/14/11 06:45 AM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
witm were do you find the eagle heads, also you mite conseader of set grinding your crank & going with a set of 1.85 or 1.88 rods, you can get a set of real good rods on e-bay, if you need any help with this let me know,there was a set of lentzs 1.88 x 6.2 that didnt sell for $90.00 + $13 freight 2 days ago, i run these in my 850 hp circle track r3/w9 engine,also putting them in our new xr2 397 were building,later my freind
Re: Design me a 3G Hemi bracket engine [Re: jg309] #1057148
10/14/11 07:56 PM
10/14/11 07:56 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I have some questions...
*What timing chain/gear set is being used?
*Are the stock valves holding up in a race application?
*What valve spring is being used?
*Any preference to the MSD or the FAST ignition set-up?
*What about the stock crank pulley/dampner..no keyway..should a better dampner be installed with a keyway..??
*Oil pan availability for 5.7 for dirt track use?
Just a few for now,,,I KNOW I will have more later...
If you like drag racing, support your local track.
