Re: Design me a 3G Hemi bracket engine
[Re: MattW]
#1057070
09/20/11 11:28 AM
09/20/11 11:28 AM
Posts: 2,864 IN
Irun5snd8th
IN
I will be talking to the Sheradon guys as well this weekend. Any more information I will post.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: ZIPPY]
#1057072
09/20/11 12:09 PM
09/20/11 12:09 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Are all the G3 hemi head gaskets made the same and are they bigger for the 6.1 and 6.4?
all different part numbers and all different bores.
Is one better than the others or same make different sizes? Thanks again
[Re: 540challenger]
#1057075
09/20/11 01:17 PM
09/20/11 01:17 PM
MattW
Ontario Canada
They're all mls, they're all good
Thanks Zippy for comign through with more answer for us. I know your a busy man beat i remember once you mention about writing a book on the 3 gen Hemi's. If you or someone else got on out I think it would be a greater seller. There is a ton of information out there but no one has pieced it all together.
Chrylser changes parts like they change underware! By the time Zippy gets the book done all the parts will be discontinued LOL
Zippy I think you should get a website going and charge to subcribe to it. I personally would become a member ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: MattW]
#1057076
09/20/11 01:31 PM
09/20/11 01:31 PM
Posts: 11,690 W. Kentucky
justinp61
W. Kentucky
This a great thread, reminds me of some of the discussions back when I joined Moparts ![](/ubbthreads/images/graemlins/thumbs.gif) . I've been thinking about a gen 3 stroker for my Dart for a while. I'd like to make around 650 hp on pump gas. What year 6.1 engine should I look for? Would the 6.1 be a better base than a 5.7? Are you guys running stock lifters? Does anyone have a good proven (parts list) combo to work off of?
[Re: MattW]
#1057077
09/20/11 01:42 PM
09/20/11 01:42 PM
Posts: 2,826 NY usa
540challenger
NY usa
Not so much the parts numbers but parts interchange, aftermarket parts, computer systems, Now that website idea might be somthing doable easier to update hmmmmm
[Re: justinp61]
#1057078
09/20/11 07:23 PM
09/20/11 07:23 PM
Posts: 3,354 ohio
HEMIDARTS
ohio
This a great thread, reminds me of some of the discussions back when I joined Moparts .
My Dart is begging me to put a 3rd gen HEMI in it.
Thank you to everyone who has been shareing all of this knowledge!! ![](/ubbthreads/images/graemlins/bow.gif)
So what is the best way to go about it, with a 5.7 or start with a 6.1? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: HEMIDARTS]
#1057079
09/20/11 08:16 PM
09/20/11 08:16 PM
MattW
Ontario Canada
5.7 are more plentiful to find. 6.1 bigger bore. Both will get the job done. I am trying to find out if a production 6.4 crankshaft will fit in a 2003-2008 5.7 and 6.1 block.
[Re: jg309]
#1057081
09/21/11 10:16 AM
09/21/11 10:16 AM
MattW
Ontario Canada
talked to my freind in ny yesterday,said he was going to talk to chunker @ mancine, said things looked promising for him casting the drag pac intake,i ask how much he thought they cost he thouht about $500/$550, he also if he dose these will be able to use a 4500 carb as well,just a update i'll keep you posted on progress
I would take one.
[Re: MattW]
#1057082
09/21/11 10:21 AM
09/21/11 10:21 AM
Posts: 2,864 IN
Irun5snd8th
IN
It will be too late for me. If I pull the trigger on my deal its gonna start being put together before Christmas. Certainly there is some momentum starting in this market though.
[Re: Irun5snd8th]
#1057083
09/21/11 11:42 AM
09/21/11 11:42 AM
Posts: 12,440 Kalispell Mt.
HotRodDave
Kalispell Mt.
Is the 5.7 cast crank and 6.1 forged? If yes, can the 6.1 drop right in to a 5.7? Also I hear that the eagle head bolted directly to a 04 5.7 will give you 12 to one compression, is it a dirrect bolt on or will pistons hit the head?
[Re: HotRodDave]
#1057084
09/21/11 12:13 PM
09/21/11 12:13 PM
MattW
Ontario Canada
Is the 5.7 cast crank and 6.1 forged? If yes, can the 6.1 drop right in to a 5.7? Also I hear that the eagle head bolted directly to a 04 5.7 will give you 12 to one compression, is it a dirrect bolt on or will pistons hit the head? [/ quote] Yes Yes Yes Yes No the piston will not hit the head.
[Re: HotRodDave]
#1057085
09/21/11 12:27 PM
09/21/11 12:27 PM
Posts: 17,939 S.E. Michigan
ZIPPY
S.E. Michigan
Yes Yes Careful head gasket selection required, the piston does not hit the head but some adjustment of CR is possible
BTW I saw your other thread about intake manifolds, and chose to not reply for a variety of reasons...mostly the ranting.
Now that things have cooled off, in the interest of helping out:
Edelbrock already designed, engineered, prototyped, and dyno tested a very nice 1x4 dual plane manifold, way back in 2006. It's been done for years now.
I've seen the prototypes first hand, and they look awesome.
If anyone really wants it, call Edelbrock on a regular basis, tell them they need to pay for their own tooling instead of expecting someone else (guess who) to GIVE them tooling for free. 'just make the thing and sell it'.
Rich H.
Esse Quam Videri
[Re: MattW]
#1057086
09/21/11 12:44 PM
09/21/11 12:44 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I would take one.
Me too
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: MattW]
#1057087
09/21/11 08:09 PM
09/21/11 08:09 PM
MattW
Ontario Canada
Just got this from LX forum where I posted this question to the SRT Engineering people
The crank will physically fit..yes...however you'll crash valves without a reduction in valve lift. The Tone Rings have been changed...yes they are interchangeable...make sure you change your crank sensor too if you do that. ![](/ubbthreads/images/graemlins/beer.gif)
