Page 6 of 31 1 2 4 5 6 7 8 30 31
Re: Design me a 3G Hemi bracket engine [Re: STEFF] #1057009
09/09/11 09:43 PM
09/09/11 09:43 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
Eric..
first off i have not read this entire post. so it may have beem mentioned already... Tony Bischoff at BES racing ingines in sunman indiana is your man. he DOMINATED the 2010 engine masters with the type of engine you are looking for, he has worked with MANY venders on parts and R&D. HE HAS THE OIL PROBLEM FIGURED OUT and nobody can match is ability to design a cam for these engines,his reputation speaks for itself. he is the best PERIOD....
Re: Design me a 3G Hemi bracket engine [Re: mcat4321] #1057010
09/09/11 09:53 PM
09/09/11 09:53 PM
Get-X Offline
Get-X  Offline
Eric..
QFT! BES engines make the power no matter what engine it is they build.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Design me a 3G Hemi bracket engine [Re: Get-X] #1057011
09/09/11 11:00 PM
09/09/11 11:00 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Eric..
X2
He has something that is working for him.
Matt
Re: Design me a 3G Hemi bracket engine [Re: MattW] #1057012
09/09/11 11:37 PM
09/09/11 11:37 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Just subscribing
Alan Jones
Re: Design me a 3G Hemi bracket engine [Re: LA360] #1057013
09/10/11 12:22 AM
09/10/11 12:22 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Was ther ever a build-up article about the BES hemi that won the contest?
Re: Design me a 3G Hemi bracket engine [Re: HotRodDave] #1057014
09/10/11 12:46 AM
09/10/11 12:46 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Re: Design me a 3G Hemi bracket engine [Re: goldmember] #1057015
09/10/11 09:26 AM
09/10/11 09:26 AM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
http://www.popularhotrodding.com/tech/1103phr_bes_417ci_gen_iii_hemi/index.html
i just read the article...
can you imagine the power he would have made if he had got the cam where he wanted it..
i personally know Tony, he has been building my families engines for years. i know most all employees past and present. the whole crew are deffinately the heavy hitters in the gen.III field
and you WILL NOT get better customer service anywhere
Re: Design me a 3G Hemi bracket engine [Re: mcat4321] #1057016
09/10/11 03:56 PM
09/10/11 03:56 PM
MN
hemidup Offline
hemidup  Offline
MN
The BES engine also used the older 5.7 Hemi heads. Take a look at the picture of the chamber and you'll see the quench pads. 5.7 Eagle heads don't have those. Also with our dyno testing our older 5.7 ported head made 30 hp/20 tq more than our ported 6.1's. Too many guy's get lost about cfm flow numbers and forget about port velocity.
I also agree with Zippy about CCV. I just picked up a set of those very rare 6.1 aluminum valve covers and plan to tig up some breathers on them. Just trying to figure out a design to put a baffle in them. I'm too cheap to buy the aftermarket taller one's. lol
Also, if there were oiling issues with the way these Gen III Hemi's are oiled, you would see the # 7/8 rods being taken out. Most failures are with the #5/6 and I have only seen 1 failure with the #3/4 and that was on Teuton's last weekend. I have my own theories as to why the center rod bearings are affected and after some more research, hopefully I can post up the fact's.
Jerry Williams.
Re: Design me a 3G Hemi bracket engine [Re: mcat4321] #1057017
09/10/11 05:18 PM
09/10/11 05:18 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
The problem is the 6500 rpm shutoff for emc. If that was changed to 7000rpm(and no valvetrain/oiling issues pop up) with some tweaking I'd think the HP would pick up nicely. I wonder why I haven't found any EMC competitors running the needed(for a wide powerband!LOL) spread LSA'S. I don't need an answer to that question,just
Re: Design me a 3G Hemi bracket engine [Re: goldmember] #1057018
09/10/11 08:12 PM
09/10/11 08:12 PM
MN
hemidup Offline
hemidup  Offline
MN
Look closely at the Jessel lifter. They drilled a hole in the side of the lifter and pumped it up through the lifter galley instead of using the factory top oiling system through the rockershaft. Luckily they put a 6500 rpm limit during the engine competition cause most of us Mopar nut's know that a conventional hydralic lifter is done at 5800 rpm. I don't think the Jessel system could withstand 8500 rpm.
Comments are welcomed.
Jerry Williams.
Re: Design me a 3G Hemi bracket engine [Re: hemidup] #1057019
09/10/11 08:40 PM
09/10/11 08:40 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Are the lifters used by BES in this build hyd or solid/hybrid lifters? I never suggested 8500rpm,but think the reason that combo only hit 700hp is because it was built for that,not that it couldn't pick up above 6500rpm IF the valvetrain works there. It would likely require a new camshaft to raise the peak hp rpm,but that goes with the territory as I'd think the heads,induction,etc are not done @6500rpm. Does that make sense?
Re: Design me a 3G Hemi bracket engine [Re: goldmember] #1057020
09/10/11 09:07 PM
09/10/11 09:07 PM
LA360 Offline
LA360  Offline
I think that engines peak power was over the 6500 limit, comments made in the article refer to wanting to run a lobe separation narrower than the 108 used, but no cores are readily available.
"Unfortunately, for the contest, the tightest lobe separation cam core we could get was 108. We would have liked to get a cam even tighter than that, so we only tried one cam. I suspect there could be more score there. To make a cam like we wanted, we would have had to buy a core out of round stock, and it's about a six-week wait period and about a thousand dollars." BES said
Read more: http://www.popularhotrodding.com/tech/1103phr_bes_417ci_gen_iii_hemi/viewall.html#ixzz1Xb8f2fjx
Alan Jones
Re: Design me a 3G Hemi bracket engine [Re: LA360] #1057021
09/10/11 09:29 PM
09/10/11 09:29 PM
MN
hemidup Offline
hemidup  Offline
MN
LSM can grind you a custom round camshaft in a couple day's for around $550.
Jerry Williams.
Re: Design me a 3G Hemi bracket engine [Re: hemidup] #1057022
09/10/11 09:30 PM
09/10/11 09:30 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Did anyone notice that they outfitted the 5.7 heads with 2.19 diameter intake valves?
Re: Design me a 3G Hemi bracket engine [Re: hemidup] #1057023
09/10/11 09:54 PM
09/10/11 09:54 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I could be wrong but the article shows a 5.7 eagle chamber head and they stated a late model head
Re: Design me a 3G Hemi bracket engine [Re: STEFF] #1057024
09/10/11 10:00 PM
09/10/11 10:00 PM
LA360 Offline
LA360  Offline
They certainly weren't without their issues getting them in there, must have been worth the effort getting them in there though.
Alan Jones
Re: Design me a 3G Hemi bracket engine [Re: MattW] #1057025
09/10/11 11:45 PM
09/10/11 11:45 PM
MN
hemidup Offline
hemidup  Offline
MN
Check it out. See the quench pads?
http://www.popularhotrodding.com/tech/1103phr_bes_417ci_gen_iii_hemi/photo_12.html
Jerry Williams.
Re: Design me a 3G Hemi bracket engine [Re: hemidup] #1057026
09/10/11 11:56 PM
09/10/11 11:56 PM
MN
hemidup Offline
hemidup  Offline
MN
Here's a pic of the very first set of closed chambered Gen III Hemi heads we did back in 2006.
Jerry Williams.
Re: Design me a 3G Hemi bracket engine [Re: hemidup] #1057027
09/11/11 12:23 AM
09/11/11 12:23 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have two sets of 5.7 heads 03 and 04 and both have the open chamber heads-not like the ones in your pic or the magazine article, the Eagles are the "late model" and "closed chamber" head unless you mill your own. That brings a couple question to my mind, how much can you safely mill the early heads? Can you mill them to closed? I guess you can if you had them in 06 Lastly I know the Eagle head is supposed to bump an early 5.7 close to 12 to one, are they just a bolt on or do they nee something changed to do that?
BTW The apatche head on the 392 is closed chamber and the 6.1 heads are open chamber.
Re: Design me a 3G Hemi bracket engine [Re: HotRodDave] #1057028
09/11/11 04:49 AM
09/11/11 04:49 AM
MN
hemidup Offline
hemidup  Offline
MN
The 5.7 heads that I have are a one off design. I welded up the chamber's and then milled them .025". Custom Ferrea 2.08" int/1.62 valve's with .308" valve stem diameter, custom bronze valve guides and hand ported personally. Exhaust to intake ratio's at mid lift are in the mid to upper 70's with port velocities at 345 fps. Won't see those type of #'s with either the 6.1, Eagle or Apache head's ported or not. BES must have came up with the same conclusion that I had.
Jerry Williams.
