BUSHED LIFTER BORES IN STOCK BLOCK.............
#1056053
08/18/11 11:41 AM
08/18/11 11:41 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Is it worth it and how much does it cost? Too early to call Pettis and I`m off to work..........thankxxx Thankxxx guys just got in from helping a friend prep/paint a house and it`s NOT FUN in this desert heat that`s for sure. So, how do they/me pre-check em to see where their at? This is one of those deals that can escalate quickly money wise......next thing I`m gettin different heads etc. I`ll ask Jason what`s up and go from there cos $$$`s tight, I`m moving(again)and just want my 9.78 et then I`m cool for a long time............no, really.
Re: BUSHED LIFTER BORES IN STOCK BLOCK.............
[Re: Thumperdart]
#1056054
08/18/11 01:05 PM
08/18/11 01:05 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Hey thumper, Mine were $500.00 installed, They say it makes the lifter alignment true. Mike
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: Thumperdart]
#1056056
08/18/11 01:51 PM
08/18/11 01:51 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Depends on the cam you are running, very mild and you will probably never notice the differance, even a dyno would have a hard time telling the differance, if you are running a big cam you will probably notice more differance, if you are running a very agressive flat tappet with mopar specific lobes I would conside it a must have. A lifter bore a degree or two out can keep the lifter from rotateing or cause the lobe to hit the side of the lifter, either way can flatten a lobe real quick. If you are reuseing a cam and lifters that was already in the engine it could also cause the lobes to go flat as they were broken in already with the wrong angles and now being corrected could cause more issues, sort of like mixing up the lifters.
[Re: HotRodDave]
#1056057
08/18/11 02:14 PM
08/18/11 02:14 PM
Posts: 20,631 in a cattle trailer down by th...
Guitar Jones
My opinion is as Dave kind of said, depends on your block. If they are already real close then there isn't going to be much difference. If they are off a significant amount you may see gains but probably slight.
I've run a big Hughes flat tappet in 2 different blocks with the same lifters and never had a problem, others have.
BTW I've never yet bushed lifters in any of my engines but I haven't built a lot of them like a performance machine shop would, just my own personal engines.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#1056058
08/18/11 02:23 PM
08/18/11 02:23 PM
Think about it this way...Run a roller, forget it. Run a flat tappet and sure..it will make a few HP maybe 10 or so--and prevent lifter / cam wear problems but...the added cost could cover a rollers expense. Many of the old blocks we have available have lifter bores that are worn to the point that flat tappet success is a crapshoot--too loose on the lifter bore and you get trouble--throw a roller in and who cares--it will run great, no issues except maybe a little oil pressure loss but no big deal--no worse than needle bearing rockers etc. I only do it if I need to repair a valuable block. Run a roller and forget about the bushings. It cost alot because it is a big job and takes more time than you might imagine.
[Re: ]
#1056059
08/18/11 04:06 PM
08/18/11 04:06 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Dom, If you want your cam timing to be exactly the same from cylinder to cylinder it needs to be done in a stock block. They are all over the place. I won't put a motor together for performance without bushing the lifter bores be it a flat tappet or roller. Everyone wants their pistons @ the same deck height, rods the same length and the stroke on the crank equalized not to mention having all the cam lobes the same. So think about the 16 different angles the lifters are are seeing in relation to the cam. More power than most would think but JMO and
[Re: Thumperdart]
#1056061
08/18/11 05:28 PM
08/18/11 05:28 PM
BradH
This is one of those mods that seem to cause a lot of polarity in opinions. Ya' got the "Not worth the money!" side and the "Don't build a race engine without 'em!" crew. My justification for having my 452 block bushed was because a wiped cam incident resulted in so much junk getting 'tween the lifters and the bores that the bores were scored. In this case, it was done to "fix" the lifter bores during the subsequent rebuild. My 451 block does not have bushed bores, partly because I don't know that it needs 'em and partly because there aren't any local shops to my knowledge that are equipped to even do the job. If it had already been done as part of those CNC'd block prep jobs, great. But having it done now as another expense during a regular freshen-up job seems harder to justify, at least IMO.
[Re: Thumperdart]
#1056063
08/18/11 07:51 PM
08/18/11 07:51 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
Jason did my 527 block before we moved here, the 518 street motor is not bushed. The 518 made 775 HP on Oregon pump gas with the same carb that the 527 made 845 HP on race gas, both with the same set of ported Indy 440-1 heads I have piched a roller lifter out(the old bracket Duster) when a valve spring broke and bent the pushrod, oil pressure went to zero, the 527 motor broke a Smith Bros pushrod on the dyno testing and both lifters came out, no oil pressure loss
[Re: dartman366]
#1056065
08/18/11 11:02 PM
08/18/11 11:02 PM
Posts: 2,091 Delray beach, Florida
Performance Only
i just bushed a brand new R-3 block for a customer. one bank was really good regarding angle and location of the bores. as i recall, all of them on that bank were within .005" of the bluprint spec. that's actually pretty good. the problem started on the opposite side when we found the whole bank was bored at 57 degree's instead of 59 degree's. i'm not even sure how that could happen. i had to order extra thick bushings to be able to correct it though. when it comes to stock blocks, i've had some that were "okay" for the most part and others that were way out of whack in every regard. one thing i can tell you though, correcting bores that are off in angle, or just plain worn out is definately worth horsepower, probably more than you might think. we also routinely see blocks that have the cylinders bored at all kinds of different angles other than the 45 degree's they're supposed to be. these new CNC block machines like what we use show up all of the previously commited machining sins. i think any time you can correct the geometry of cylinders and lifter bores, among other things, your going to make more power and have a longer lasting and more reliable engine.
machine shop owner and engine builder
[Re: Performance Only]
#1056066
08/19/11 12:17 AM
08/19/11 12:17 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Correcting the lifter bore with bronze bushings should be part of the blueprinting process and the labor to do so is paid.Too many people "cheap out" thinking it's not needed.I'll also add that the CNC machine is the way to go.Sure some of the machine shops still use the old style fixture that has worked for years but,,,,,,,,,,,,the CNC machine is the way to go
[Re: Thumperdart]
#1056067
08/19/11 12:44 AM
08/19/11 12:44 AM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
Never done it and managed to make big, reliable hp. But this was always with a B or RB platform which had excellent VT geometry to start with.
8.30's @3400 lbs
[Re: Cab_Burge]
#1056072
08/19/11 10:32 AM
08/19/11 10:32 AM
Posts: 8,165 Left Coast
BobR
Left Coast
IMO that's is the only real reason to do this assuming the stock bores aren't worn out.
