Re: 71 Duster 340 4spd resto, from ruster to duster!
[Re: ScottSmith_Harms]
#1055550
10/07/11 05:19 PM
10/07/11 05:19 PM
Posts: 1,177 Woodbridge
Tommy The Chryco
Woodbridge
that is the cleaniest rear end I've ever seen, way too smooth
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
[Re: NV69B7RR]
#1055553
10/07/11 09:28 PM
10/07/11 09:28 PM
Posts: 6,005 Reno, Nevada
NV69B7RR
Reno, Nevada
The rear end is so smooth from all the rubbing and scrubbing with steel wool and dawn soap. I was surprised with all the markings that showed up condisering the only one that could be seen faintly was the "A". Probably doesn't hurt that the car spent a lot of its life in San Diego & 15yrs under a canvas tarp too. I'm guessing the orange and black markings denote 391 gears? I have a chart I can dig up about that. I never realized the diff and rear were assembled the same day though (9/14/70). The orig owner swears the trans is the original one it came with and it was never rebuilt, although he say he went through quite a few clutches! The VIN is all messed up on it, although 6bblgt was able to make out the VIN 115059 I knew it was messed up when I bought it and but its not a deal breaker for me, the car is what it is. Its going back in that way, and won't get restamped
[Re: NV69B7RR]
#1055556
10/07/11 09:44 PM
10/07/11 09:44 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Based on that I'd guess it's your original trans. It's not likely that someone hunted down a replacment with the right assembly date back when that car was on the road Post a nice clear pic of your engine stamping as well as your body stampings if you have them (or just e-mail them to me if you prefer) I can probably offer you some further info on the trans stamping if you do. *Also, can you post a pic of the date codes on your Rallye wheels? (dates are stamped right near the valve stem holes) Do they all have the same dates or not?
