Page 1 of 4 1 2 3 4
engine assembly labor #1055013
08/17/11 08:54 PM
08/17/11 08:54 PM
WI.
Scotts71chall Offline OP
WI.
A very high quality engine machine shop wants $799 to assemble a Hemi short block, labor only!
Its a 572" world iron block. Includes fit cam but not deg. it.
Seems high $$$ to me?
They do alot of big inch mopar work including making there own BIG billet blocks & billet heads.
What ya think of that price, should I say some thing about it being to high?
I kind of really want them to do it instead of shipping it some where.
Re: engine assembly labor [Re: Scotts71chall] #1055014
08/17/11 08:58 PM
08/17/11 08:58 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
short block thats kinda steep,long block is around 800 or 900 beans with my engine builder
Re: engine assembly labor [Re: fishy340] #1055015
08/17/11 09:23 PM
08/17/11 09:23 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
If they do real good work and do it right it`s not to much . Because that`s the life of a motor but that`s just me some times you get what you pay for. GOOD LUCK
Re: engine assembly labor [Re: Scotts71chall] #1055016
08/17/11 09:25 PM
08/17/11 09:25 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
The cam BETTER BE degreed-in for 800 clams !
Re: engine assembly labor [Re: Scotts71chall] #1055017
08/17/11 10:41 PM
08/17/11 10:41 PM
Delray beach, Florida
P
Performance Only Offline
P
that's a little more than we charge, but it's not out of line for the work involved if it's done right. i would expect all critical dimensions are checked and documented. rings are file fit, etc. etc. who is supplying the parts for the build? sometimes that figures in to the cost of assembly as well.
engine assembly is usually one of those things that many people feel they can do themselves, and some can. in fact a lot of people can bolt parts together and the engine will run. now, how long it'll run and how well it'll run may be a different story altogether.
machine shop owner and engine builder
Re: engine assembly labor [Re: dOrk !] #1055018
08/17/11 10:51 PM
08/17/11 10:51 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I would suggest you take the time and do it yourself. Buy the necessary tools (installers, all measuring equipment, grinding and tapping, files, picks, a few good how-to books, sealants, lubes, etc.) and now you have everything the next time you do it. And in that one time you have learned all the knowledge that the spendy 'big-time' shop knows and then applies. I don't know. I'm sorry but I think you get my point. The only way you'd know for sure is to do it successfully yourself. Hypothetically, if you sold it, the buyer is likely to pay you more for the big-name assembled engine. IMO it's even worth something IF you mention the shops name in vanity once you've patronised them.
Re: engine assembly labor [Re: Performance Only] #1055019
08/17/11 10:53 PM
08/17/11 10:53 PM
NC
440Jim Offline
440Jim  Offline
NC
The price is not everything.
Ask about what will be checked and documented. Correction of out of tolerance items should be expected to be more money. But then you will know what you are getting for the money. It is not just bolting it together, if done right.
Re: engine assembly labor [Re: 440Jim] #1055020
08/17/11 11:48 PM
08/17/11 11:48 PM
P
P
Jim, that's absolutely the point i was trying to make. you don't pay a professional to "just bolt it together". you pay them to do the job completely and correctly.
Re: engine assembly labor [Re: Performance Only] #1055021
08/18/11 01:15 AM
08/18/11 01:15 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Read the thread about a thrust cap here and it will help explain why an engine isn't just 'bolted together"....
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=6782383
Re: engine assembly labor [Re: RodStRace] #1055022
08/18/11 03:10 AM
08/18/11 03:10 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
The owner/instructor of the school I went to charged 1000 bucks for assembly of a long block. This was assembly and adjustment for anything that isn't in specification for the application the engine will be used for. Make sure they specify whether or not it's just assembly or if it includes adjustments at that cost.
Re: engine assembly labor [Re: dodgeboy11] #1055023
08/18/11 04:05 AM
08/18/11 04:05 AM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
How far and extensive does the "adjustment" phase go ?
Re: engine assembly labor [Re: dOrk !] #1055024
08/18/11 07:25 AM
08/18/11 07:25 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
MY machinist assembled my last short block.He also did all the machine work.Bored and plate honed it,turned polished crank,resized rods and installed new ARP bolts,drilled 1/2 inch pickup and opened up oil passages,balanced, blueprint,deck block and square,supplied a few parts, file fit rings,clearanced it,turned flywheel degreed cam and some more stuff.My total bill was under $1300.He also did the build for my sons 360 that he built.That was about 14 years ago.So it would be more now.He is one of those guys that you just trust to get it right and know that it is.Been a one man shop for 30 years plus.That and he has more work than he can handle.Most repeat customers.Rocky
Chrysler Firepower
Re: engine assembly labor [Re: Scotts71chall] #1055025
08/18/11 08:53 AM
08/18/11 08:53 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I'll "assemble" it for $250.
I'll "build it to spec" for $800.
Re: engine assembly labor [Re: Commando1] #1055026
08/18/11 10:13 AM
08/18/11 10:13 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Have they done the machining as well or is this to check, correct and assemble someone else's work?
An example is the guy who did mine. He has a flat rate for all the machine work and a "ballpark" for assembly. That way, if it takes longer than usual to get machine to tolerance he can make it up on "assembly". I have no problem paying to have it done right.
Re: engine assembly labor [Re: Scotts71chall] #1055027
08/18/11 10:26 AM
08/18/11 10:26 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That's fair, don't complain unless you know what to check for.
Knowledge is power and $$. I bet you would have to spend $500 bucks to buy the tools needed.
Re: engine assembly labor [Re: Challenger 1] #1055028
08/18/11 10:46 AM
08/18/11 10:46 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
and about $100,000 buying the machinery to correct some of the items that might need to be corrected...
Re: engine assembly labor [Re: Stanton] #1055029
08/18/11 11:19 AM
08/18/11 11:19 AM
WI.
WI.
I am supplying after market block,crank,rods.
His price includes fitting rings, cam.
His prices on machine work seem about in line with other high end shops and parts prices seem good.
If I were to drive it to a good shop that people recommend on here, the road trips would be about $300 so ill take that into consideration.
Maybe ill ask him if i buy more parts from him, will the labor price drop.
Re: engine assembly labor [Re: Scotts71chall] #1055030
08/18/11 12:17 PM
08/18/11 12:17 PM
organ
maximum entropy Offline
organ
the price is what ever the market will bear. is he busy? does he have a waiting list? good reputation? personally, i couldn't imagine installing a cam but not degreeing it. mocking up a new combination takes a lot of time to do properly. 799.00 is cheap, imo, if they're really doing it right.
Re: engine assembly labor [Re: maximum entropy] #1055031
08/18/11 12:24 PM
08/18/11 12:24 PM
wellington ohio
68-scatpack-rt Offline
In thin ice
In thin ice
wellington ohio
pay him the extra dough and have the cam "degreed". why build a high dollar engine and skip this step?
our local shop (very well respected high performance shop in business for 40 plus years) charges 75 per hour. i would think he'd have 10 hours in cleaning, prep and assembly.
unions....the folks who brought you the weekend!
Re: engine assembly labor [Re: Scotts71chall] #1055032
08/18/11 01:11 PM
08/18/11 01:11 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
You want this guy to do the work, so you must trust him, BUT, you want him to negotiate his price for his years of experience, and 100,000s + dollars of machinery and so forth. Why should he? He gave you a price, that he feels he NEEDS to make to do the job. He has overhead, anticipated " trouble" with parts ( I dont care who you are, unless you've done this, you dont understand how many things you need to fix during assembly) and other wages and bills to pay. As mentioned above, at $75.00 an hour, and 10 hours labor ( which it can very easily go over), he is being fair. You dont like his price, but it is what he needs to make.
Would you like to go to work today and have your boss ask you to take a lesser wage, because he " thinks" you are getting paid too much, and he'd like to save some money this week and pay you a little less ? He likes you and everything, but hey, he's trying to crunch some numbers for corporate. Each job you do he wants to negotiate a better hourly wage from you. Do you go to the grocery store, and start negotiating for a better price on apples and fruit? You get what I am saying. I dont know why it is, that engine shops are considered scoundrels and thieves if they actually charge for about 75% of the actual time they put into a build, and most usuallly go above and beyond, and give way more than they charge, and are expected to be " on call" 7 days a week for free. I could go on and on...
Pay them man, get the job done right, and trust the shop to supply you with a well built engine.
Thats what you ultimatley want right or you'd be doing it yourself ?
My
RIP Monte Smith
Page 1 of 4 1 2 3 4
