Re: Lets hear your stupid fast small block combo's
[Re: Leon441]
#1053506
08/17/11 08:47 AM
08/17/11 08:47 AM
Posts: 489 mid Ga.
W5Dart378
mid Ga.
My current combo is a 427" X block with W9s, one nitrous solenoid 2x083 nos jets, 2speed, and 8 3/4. Best is in the signature, went 3 5.33s at 133 in 100+ degrees a couple weeks ago,@ 3000#. Found an issue with the nitrous solenoid, goal is teens in October.
69 340 swinger streetcar 8.13 1/8th w/1.90 60ft w/ 3.55s
69 422W9 Dart stock suspension,5.27 on 275/60s,single bar plate
[Re: Ian]
#1053508
08/17/11 03:49 PM
08/17/11 03:49 PM
Posts: 248 Ohio
aquamist60
Ohio
mine definately not stupid fast. We built it originally in 1981 or '82 with technology from then. Stock items- 340 std. bore block, crank, rods, pistons, small valve heads, std valves & springs. 727 trans with reverse shift pattern.
Aftermarket items- unknown converter flashes to 4600 rpm, .509 Mopar cam, Holley Strip Dominator, 750 DP carb, MSD ign. narrowed 8 3/4 rear, 12 pt. cage, fiberglass hood, 28x8 slicks with steel wheels, street tires on front with 14" Cragars, Gabriel (LOL) shocks, 4.56 gear, S/S springs. We've changed shocks to QA1, Welds & M/T tires all the way around. Haven't run it yet with any changes we've made.
Performance- 2700 DA showed an 11.95 @ 111 mph. Launch @ 3500, shift @ 6200-6500, cross the line @ 6500, have twisted it to 7200, still pulling. Actual numbers are- 60' 1.68, 1/8- 7.71 @ 90 mph, 1/4- 12.19 @ 109 off the throttle at the line.
At local track S/P is 0-7.75 1/8 mile, Pro 0-8.99 1/8 mile, Sportsman 12.00 & up 1/4 mile. So I guess I could run any of the 3, not that I'd be competetive.
It's a 1973 Duster & it's not stupid fast, but I enjoy it & we do little things to make it quicker.
[Re: Mopar-Al]
#1053510
08/17/11 04:37 PM
08/17/11 04:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
aquamist60, I think that's a respectable time for sure. The post is for stock factory blocks. Some of the others post their over the counter aftermarket blocks to show the big hp numbers. Stupid fast in a production stock oem block to me is a block out of a car not out of the race catalog. Keeping a factory block together with big heads and stuff would be a hard task to make live any length of time. Mopar has came a long ways since the 80's in tech.
I posted my STOCK block ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Moparnut426]
#1053512
08/17/11 05:15 PM
08/17/11 05:15 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
My brother Dean's 70' Dart, ALL steel, full interior, street driven daily.....w/stock 360 block, crank, rods, heads, 6-71 2 750s, pumpgas, went 10.81 on it's maiden voyage at E-Town in the heat, with a cam "issue".........in 1984.
That was a fun street car and pretty fast for it's day.
[Re: jim sciortino]
#1053513
08/17/11 08:45 PM
08/17/11 08:45 PM
Posts: 251 Saskatchewan (SK)
79410aspenrt
Saskatchewan (SK)
9.20's in a 86 Charger and 9.40's in a 92 Daytona. same 360 in my Aspen R/t runs 11.50's. Charger and Daytona were 2300 and 2400 lbs, my R/T is at 3800lbs. ![](/ubbthreads/images/graemlins/sawzall-smiley.gif)
[Re: 79410aspenrt]
#1053514
08/17/11 08:53 PM
08/17/11 08:53 PM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
No way Stupid fast, but you said stock block.
68 Cuda Notchback Full interior, bench seat gauges, carpet all steel except hood, roll bar, pump gas
96 Magnum Block 10.8:1 compression Scat 4" crank Eagle Rods Wiseco forged dished pistons Bullet hydraulic roller 252, 256 @ .050 .555 and .565 lift Magnum Edelbrock heads, Stage II by RyanJ (SDSS) Mopar Magnum M-1 port matched 998 torqueflite 4000 stall Lenny converter, CRT manual valve body 4.11 8 3/4 SS leafs, comp shocks up front
10.86 at 122
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: 79410aspenrt]
#1053515
08/17/11 08:55 PM
08/17/11 08:55 PM
Posts: 465 Oconomowoc, WI.
Cudahlr
Oconomowoc, WI.
Stock 360 block, stock rods, stock crank, KB pistons, 11.7-1 pump gas, e-heads, solid cam, m-1 single plane intake, 950hp carb.
3200# barracuda 11.20 @ 121
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp 1985 Harley Sportster Bobber 2006 Ram 2500 sport - The Cudahlr
