Re: Lets hear your stupid fast small block combo's [Re: fishy340] #1053504
08/16/11 10:12 PM
08/16/11 10:12 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
indy heads 72 360 std block 4 inch stroke pro comp junk h beams probe fl tops ft 259/265@050 and a shot of gas full steel 4 door with truck battery,tow bar etc runs a glide 2900 stall aspirated with 26/10 and 3.89 gears with driver weight is 3550 lbs and it ran 143 mph last meeting moroso says 800 hp not shore if thats right ,its never been dynoed
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Lets hear your stupid fast small block combo's [Re: JesseR] #1053505
08/17/11 12:07 AM
08/17/11 12:07 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
It would have been nice to have had more time down there to see how fast we both could have gone, thats the only bad thing about index racing, we spent all of our time trying to dial our cars in
I threw everything I had in the trunk starting with the two chunks of solid steel weighing 150 lbs. I tried to get the kids to jump in but they were not cool with that. Pulled timing, shifted early, you name it I done it and still would have ran 5.80 if I had held it thru the end. That 6.0 crap was hard enough then put the Rockingham air into the picture and a tree I couldn't find and I was screwed. A set of fresh valve springs and that baby wanted to run, I'm telling Ya.
Leon
Re: Lets hear your stupid fast small block combo's [Re: Leon441] #1053506
08/17/11 08:47 AM
08/17/11 08:47 AM
mid Ga.
W5Dart378 Offline
W5Dart378  Offline
mid Ga.
My current combo is a 427" X block with W9s, one nitrous solenoid 2x083 nos jets, 2speed, and 8 3/4. Best is in the signature, went 3 5.33s at 133 in 100+ degrees a couple weeks ago,@ 3000#. Found an issue with the nitrous solenoid, goal is teens in October.
69 340 swinger streetcar 8.13 1/8th w/1.90 60ft w/ 3.55s 69 422W9 Dart stock suspension,5.27 on 275/60s,single bar plate
Re: Lets hear your stupid fast small block combo's [Re: W5Dart378] #1053507
08/17/11 11:14 AM
08/17/11 11:14 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
a lot of tuff factory small blocks well done , keep em coming
Re: Lets hear your stupid fast small block combo's [Re: Ian] #1053508
08/17/11 03:49 PM
08/17/11 03:49 PM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
mine definately not stupid fast. We built it originally in 1981 or '82 with technology from then.
Stock items- 340 std. bore block, crank, rods, pistons, small valve heads, std valves & springs.
727 trans with reverse shift pattern.
Aftermarket items- unknown converter flashes to 4600 rpm, .509 Mopar cam, Holley Strip Dominator, 750 DP carb, MSD ign. narrowed 8 3/4 rear, 12 pt. cage, fiberglass hood, 28x8 slicks with steel wheels, street tires on front with 14" Cragars, Gabriel (LOL) shocks, 4.56 gear, S/S springs. We've changed shocks to QA1, Welds & M/T tires all the way around. Haven't run it yet with any changes we've made.
Performance- 2700 DA showed an 11.95 @ 111 mph.
Launch @ 3500, shift @ 6200-6500, cross the line @ 6500, have twisted it to 7200, still pulling.
Actual numbers are- 60' 1.68, 1/8- 7.71 @ 90 mph, 1/4- 12.19 @ 109 off the throttle at the line.
At local track S/P is 0-7.75 1/8 mile, Pro 0-8.99 1/8 mile, Sportsman 12.00 & up 1/4 mile. So I guess I could run any of the 3, not that I'd be competetive.
It's a 1973 Duster & it's not stupid fast, but I enjoy it & we do little things to make it quicker.
Re: Lets hear your stupid fast small block combo's [Re: aquamist60] #1053509
08/17/11 04:31 PM
08/17/11 04:31 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
aquamist60, I think that's a respectable time for sure. The post is for stock factory blocks. Some of the others post their over the counter aftermarket blocks to show the big hp numbers. Stupid fast in a production stock oem block to me is a block out of a car not out of the race catalog. Keeping a factory block together with big heads and stuff would be a hard task to make live any length of time. Mopar has came a long ways since the 80's in tech.
Re: Lets hear your stupid fast small block combo's [Re: Mopar-Al] #1053510
08/17/11 04:37 PM
08/17/11 04:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I posted my STOCK block
Re: Lets hear your stupid fast small block combo's [Re: MR_P_BODY] #1053511
08/17/11 04:55 PM
08/17/11 04:55 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
My STUPID FAST small block is my .18cc nitro burning 15000+ rpm running R/C car.
its 4x4 and it will do 50+mph
Kasey
Re: Lets hear your stupid fast small block combo's [Re: Moparnut426] #1053512
08/17/11 05:15 PM
08/17/11 05:15 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
My brother Dean's 70' Dart, ALL steel, full interior, street driven daily.....w/stock 360 block, crank, rods, heads, 6-71 2 750s, pumpgas, went 10.81 on it's maiden voyage at E-Town in the heat, with a cam "issue".........in 1984.
That was a fun street car and pretty fast for it's day.
Re: Lets hear your stupid fast small block combo's [Re: jim sciortino] #1053513
08/17/11 08:45 PM
08/17/11 08:45 PM
Saskatchewan (SK)
79410aspenrt Offline
Saskatchewan (SK)
9.20's in a 86 Charger and 9.40's in a 92 Daytona. same 360 in my Aspen R/t runs 11.50's.
Charger and Daytona were 2300 and 2400 lbs, my R/T is at 3800lbs.
Re: Lets hear your stupid fast small block combo's [Re: 79410aspenrt] #1053514
08/17/11 08:53 PM
08/17/11 08:53 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
No way Stupid fast, but you said stock block.
68 Cuda Notchback Full interior, bench seat gauges, carpet all steel except hood, roll bar, pump gas
96 Magnum Block
10.8:1 compression
Scat 4" crank
Eagle Rods
Wiseco forged dished pistons
Bullet hydraulic roller 252, 256 @ .050 .555 and .565 lift
Magnum Edelbrock heads, Stage II by RyanJ (SDSS)
Mopar Magnum M-1 port matched
998 torqueflite 4000 stall Lenny converter, CRT manual valve body
4.11 8 3/4 SS leafs, comp shocks up front
10.86 at 122
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Lets hear your stupid fast small block combo's [Re: 79410aspenrt] #1053515
08/17/11 08:55 PM
08/17/11 08:55 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
Stock 360 block, stock rods, stock crank, KB pistons, 11.7-1 pump gas, e-heads, solid cam, m-1 single plane intake, 950hp carb.
3200# barracuda
11.20 @ 121
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp
1985 Harley Sportster Bobber
2006 Ram 2500 sport - The Cudahlr
Re: Lets hear your stupid fast small block combo's [Re: The Sphinx] #1053516
08/17/11 09:33 PM
08/17/11 09:33 PM
Maryland, USA
Raymond Offline
Raymond  Offline
Maryland, USA
394 x block w5 heads 2700 lbs. single turbo
9.30 qtr.175 mph 1.88 60 ft 20 lbs.boost.
8.60 qtr.160 mph 1.36 60 ft 14 lbs boost
Re: Lets hear your stupid fast small block combo's [Re: Raymond] #1053517
08/17/11 10:10 PM
08/17/11 10:10 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
You got that right less boost and less mph it went faster?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Lets hear your stupid fast small block combo's [Re: 1967dartgt] #1053518
08/17/11 10:34 PM
08/17/11 10:34 PM
Louisville, MS
Dustedu Offline
Dustedu  Offline
Louisville, MS
Not stupid fast but......
Stock 68' 340 block
W5's
396"
Pump gas
9.80's 1/4
Has been 5.60's this year in the heat on 200 shot and c-16
On 275 m/t radials
Re: Lets hear your stupid fast small block combo's [Re: Dustedu] #1053519
08/18/11 11:51 AM
08/18/11 11:51 AM
Ma
Voluster Offline
Voluster  Offline
Ma
Also Not Stupid fast but Goes good for a street car
Stock 71 340 block
416 cubes
had eddy heads on it
Solid cam
M1 950 pro systems carb
1 3/4 headers
10 to 1 compression
Went 10.96 at 121 on pump gas at 3480 lbs
9.88 at 136 1.37 60ft 275 drag raidals with a 150 shot on a monte smith cross bar plate
Now the motor has indy cnc 360-2's on it indy intake and TTI w2 1 7/8ths headers
Haven't made it to the track yet with the new top end
Any guesses on what it should run now?
