Re: jag fan clutch [Re: ademon] #1052904
08/18/11 02:56 PM
08/18/11 02:56 PM
Norway
General 68 Offline
General 68  Offline
Norway
So am i the only one that thinks the jag fans are "weak" meaning they don't spin the fan quite fast enough when hot?
On the street my 440 runs a little hotter with the Jag fan clutch than it did with a old non-thermal clutch. Stuck in traffic on a hot day the Jag fan clutch still keeps the temperature at a healthy level - the old clutch didn't.
I would have liked the Jag clutch to spin the fan a little faster, but as long as it cool the motor on a hot day I'm fine - less drag than the severe duty units.
Re: jag fan clutch [Re: ademon] #1052905
08/18/11 03:18 PM
08/18/11 03:18 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
...a fan with a pitch of 2 1/2" or more should be used with a severe duty clutch..the jag is "heavy Duty"
..i think the original 7 blade mopar fan had a pitch of 2 1/4" but can't remember.
..the mopar performance 5 blade has a 2 1/2" pitch but might be ok.
Re: jag fan clutch [Re: can.al] #1052906
08/18/11 03:21 PM
08/18/11 03:21 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Take a look at this chart:
http://www.haydenauto.com/upload/HaydenAuto/Documents/Cat_Imperial/2007-imperial-fan-clutches.pdf
Find the original part number for your (or something similar) application. make a note of the measurements. If you need a shorter fan, play in the charts until you find one that fits your measurements.
- Stu Harmon
Re: jag fan clutch [Re: feets] #1052907
08/18/11 03:54 PM
08/18/11 03:54 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I see the jag uses a smaller plastic fan!! this is the answer to the slower fan speed with our metal large dia fans.
Re: jag fan clutch [Re: ademon] #1052908
08/18/11 04:47 PM
08/18/11 04:47 PM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
I used the Jag fan. Came w/ bushing. Kept the 383 cool. No shroud. I noticed it seemed to need several seconds to even out when cold. I could hear a difference at first start for about 20 seconds or so.
Worked really good. I got mine from NAPA. Ran a 7 blade OEM fan blade with it. Not sure what from or pitch.
I want my fair share
Re: jag fan clutch [Re: General 68] #1052909
08/18/11 07:26 PM
08/18/11 07:26 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I tried to use the hayden jag clutch on one project...It fit OK but it just did'nt seem to work like it should have...Thought I got a bad one and had it replaced...Same deal, the temp was high and it never seemed to "lock up" like it should have...Ended up yanking it and using a fixed blade on that project...
Re: jag fan clutch [Re: screamindriver] #1052910
08/18/11 09:25 PM
08/18/11 09:25 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
i have one on my bb duster with the 7 blade hayden fan blade it works good, but could use a shroud. it cant sit there and idle all day long when its 100 but it does fine even in stop and go traffic in the dead of summer.
Re: jag fan clutch [Re: JAMESDART] #1052911
09/16/14 10:35 PM
09/16/14 10:35 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Anyone have any experience with this Jag clutch regarding higher RPM's? 6-7000? I'm worried about it coming apart?
Re: jag fan clutch [Re: brads70] #1052912
09/16/14 11:04 PM
09/16/14 11:04 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
My posts are the "Anonymous" user in this thread (long story).
I've had my car out and about some and done quite a few 6000 rpm burnouts. So far so good. Keeps the temp right at 180° with no shroud.
My motor is pretty mild and I made sure the radiator was gone through before I installed it.
It's a Hayden Heavy Duty unit and I have no reservations about beating on it!
Re: jag fan clutch [Re: brads70] #1052913
09/17/14 12:05 AM
09/17/14 12:05 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I've run it in my car for 3 years now or so. It's a 416 stroker. But I can get it up to 6000 at the end the straight at Willow Springs. I'm sure when my instructor drove it he got more revs out of it. I've got the rev limiter at 6400 and I know I've hit that in 1st gear just to see if it worked.
