Header extensions #1052574
08/14/11 09:37 AM
08/14/11 09:37 AM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
How long before you add hangers. Mine are 23" long. Don't want to crack a header tube.
Re: Header extensions [Re: Todd] #1052575
08/14/11 09:45 AM
08/14/11 09:45 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Those are pretty long to get peak torque, should be
in the 16"-18" total length in most cases... depends
on how they are attached but most of the time I dont
put a hanger on them... if you have a long straight
section on the primary before the collector then thats
a long moment arm and then yes I would put a hanger on
Re: Header extensions [Re: MR_P_BODY] #1052576
08/14/11 10:08 AM
08/14/11 10:08 AM
Ohio
Todd Offline OP
Todd  Offline OP
Ohio
If I remember you said the collector needed to be in multiples of 18" The total is 32" from the end of the primary tubes. I would have made then 18" but the crossmember wouldnt alow it. As for a bracket adding one horizonally off the side?
Re: Header extensions [Re: Todd] #1052577
08/14/11 10:14 AM
08/14/11 10:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes its a multiples thing... 18,36,72 and so on...
with what you have there, yes I would run a hanger...
looks good
