Page 2 of 3 1 2 3
Re: How Fast with Indy EZ heads? [Re: Jacob Pitt] #1052456
08/16/11 12:08 PM
08/16/11 12:08 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
[Email]5.95@114[/Email] at 3300lbs footbraking with a 499" on race gas. They are the EZ-1's cnc ported by Modern. The cam is to small for the motor but seems to work well. The car is at the chassis shop now getting a backhalf done to it then I can up the cam and switch to e-85.
that car boogies. what gear in your car? are they the big EZ heads or stock rocker type?
Re: How Fast with Indy EZ heads? [Re: sixpackgut] #1052457
08/17/11 10:18 AM
08/17/11 10:18 AM
tboomer Offline
tboomer  Offline
Re: How Fast with Indy EZ heads? [Re: sixpackgut] #1052458
08/17/11 10:51 AM
08/17/11 10:51 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Jeff takes a stock ez head and cncs them to 308 port volume an still uses stock rocker gear! The ez1 is the same as standard ez head just the ports start out max wedge size... Any more than that you go to the 325s which is the only ez head that takes offset rocker... I did have a baby cam in my chally at 248/254 @ 50 but it worked good...
Mopar Performance
Re: How Fast with Indy EZ heads? [Re: sixpackgut] #1052459
08/17/11 11:23 AM
08/17/11 11:23 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
It has a 4.30 gear in it and the EZ heads run the standard location Harland Sharps. The cam is something like a .636 lift solid roller wide lobe seperation. I don't have the card in front of me but once I get more tire under the car I'll be looking for somemore power.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: How Fast with Indy EZ heads? [Re: Jacob Pitt] #1052460
08/17/11 11:28 AM
08/17/11 11:28 AM
tboomer Offline
tboomer  Offline
I would say that is pretty impressive!!
Re: How Fast with Indy EZ heads? [Re: tboomer] #1052461
08/17/11 11:40 AM
08/17/11 11:40 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Your HP computed from your vehicle MPH is 797.77 flywheel HP
Re: How Fast with Indy EZ heads? [Re: dannysbee] #1052462
08/17/11 12:14 PM
08/17/11 12:14 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
It's not that the cross ram will not make any HP just not as much as a good single plane. Sell the cross ram to someone that needs it for a nostalgia super stock if its modified or to someone doing a restoration if is unmodified. The cross ram intake will bring enough to buy a good single plane and a new carburetor.
On my 64 car that weighed in @ 3150 lbs the EZ heads with MW port and an oe cross ram on a 493 ci I did get a best of 9.98 but most times it ran 10.10 to 10.15 in the 1/4.
Russ
Re: How Fast with Indy EZ heads? [Re: max_maniac] #1052463
08/17/11 01:56 PM
08/17/11 01:56 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
440+.030 CNC by mch scott brown flat tappet cam indy cross ram 10.32@129mph @3620 with driver.
JAKES AUTOMOTIVE
Re: How Fast with Indy EZ heads? [Re: JAKE68] #1052464
08/17/11 05:12 PM
08/17/11 05:12 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
499 low deck, Scott Brown flat tappet cam, AED 1000cfm/4150 carb, INDY intake, 2" Hooker Headers. Car weighs 3600lbs with driver, and has run 10.teens at 131mph.
Re: How Fast with Indy EZ heads? [Re: JERICOGTX] #1052465
08/17/11 06:05 PM
08/17/11 06:05 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
Is this your car?
67' charger 499 RB 10.57 at 127
Re: How Fast with Indy EZ heads? [Re: dragram440] #1052466
08/17/11 09:19 PM
08/17/11 09:19 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Matt, no it's a friend of mine. Heads were done by Dwayne Porter. Made 715hp on the dyno. Pretty much the same combo as mine, but I have SR heads.
Re: How Fast with Indy EZ heads? [Re: JERICOGTX] #1052467
08/18/11 09:00 AM
08/18/11 09:00 AM
tboomer Offline
tboomer  Offline
Jeff...What does Mike have for compression ratio?
Re: How Fast with Indy EZ heads? [Re: tboomer] #1052468
08/18/11 10:36 AM
08/18/11 10:36 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Just shy of 13:1.
Re: How Fast with Indy EZ heads? [Re: JERICOGTX] #1052469
08/18/11 10:45 AM
08/18/11 10:45 AM
tboomer Offline
tboomer  Offline
Thanks,Jeff!! Makes me want to get new heads so this thing of mine can get some air thru it!! Dang!! I want to go a 10.10 before I am done!!
Re: How Fast with Indy EZ heads? [Re: tboomer] #1052470
08/18/11 10:53 AM
08/18/11 10:53 AM
MD
JACK1440 Offline
JACK1440  Offline
MD
so far 10.01 @ 136. car weighs 3400 with me in it. compuflow ported ez-1's on a 500".
Re: How Fast with Indy EZ heads? [Re: JACK1440] #1052471
08/18/11 10:54 AM
08/18/11 10:54 AM
tboomer Offline
tboomer  Offline
Looks great!!
Re: How Fast with Indy EZ heads? [Re: tboomer] #1052472
08/18/11 10:59 AM
08/18/11 10:59 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
jACK1440, would like to see more pics of that car
Re: How Fast with Indy EZ heads? [Re: tboomer] #1052473
08/18/11 10:59 AM
08/18/11 10:59 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Some fast combos with these heads. Looks like with porting we would be in the 9's with our pump gas combo...What is the main difference between these and say the 440-1's, the port height?
Re: How Fast with Indy EZ heads? [Re: Dragula] #1052474
08/18/11 11:06 AM
08/18/11 11:06 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
use stock rockers except for the big EZ heads than their similar to -1s
Re: How Fast with Indy EZ heads? [Re: sixpackgut] #1052475
08/18/11 11:13 AM
08/18/11 11:13 AM
tboomer Offline
tboomer  Offline
I also presume that everyone using these heads are using the MW ports?
Page 2 of 3 1 2 3
