Re: How Fast with Indy EZ heads?
[Re: sixpackgut]
#1052458
08/17/11 09:51 AM
08/17/11 09:51 AM
Posts: 6,295 U.S.
moparniac
U.S.
Jeff takes a stock ez head and cncs them to 308 port volume an still uses stock rocker gear! The ez1 is the same as standard ez head just the ports start out max wedge size... Any more than that you go to the 325s which is the only ez head that takes offset rocker... I did have a baby cam in my chally at 248/254 @ 50 but it worked good...
Mopar Performance
[Re: max_maniac]
#1052463
08/17/11 12:56 PM
08/17/11 12:56 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
440+.030 CNC by mch scott brown flat tappet cam indy cross ram 10.32@129mph @3620 with driver.
JAKES AUTOMOTIVE
[Re: tboomer]
#1052468
08/18/11 09:36 AM
08/18/11 09:36 AM
Posts: 10,119 MN
JERICOGTX
MN
