Re: 440 head gaskets [Re: 68CoronetRT] #1049853
08/16/11 10:42 AM
08/16/11 10:42 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
78 cc on the combustion chambers which I believe means they were only cleaned up not milled. Mopar Muscle article says the 915 heads were 78.5 cc stock. My stock 906s were about 88 cc IIRC.
The mopar muscle article is WRONG , The 915's I have are 81ccand the few sets of never cut 906's I have done or had done have never been less than 90 cc , some as high as 92cc.
Get a pair of dial calipers and measure the thickness of the head bolt boss under the exhaust ports this will give you an idea how much they have been cut, factory heads seems to be 1.000 .
Re: 440 head gaskets [Re: Mr.Yuck] #1049854
08/17/11 08:13 PM
08/17/11 08:13 PM
maryland
buck440 Offline
buck440  Offline
maryland
Re: 440 head gaskets [Re: 68CoronetRT] #1049855
08/17/11 09:09 PM
08/17/11 09:09 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
I ran the felpro blue many a time at 13:1 with the 517 head, same way, no problems. Nitrous didnt exist and that was the most advanced gasket available.
Re: 440 head gaskets [Re: Mike Swann] #1049856
08/17/11 09:14 PM
08/17/11 09:14 PM
IN
ahy Offline
ahy  Offline
IN
I believe the Felpro perma-torque would do great in your application. From memory it is .038-.039 which should be perfect for quench. Iron head, iron block moderate CR and 5 bolts per cylinder. Very easy to seal.
Re: 440 head gaskets [Re: JohnRR] #1049857
08/18/11 02:21 PM
08/18/11 02:21 PM
Arizona
68CoronetRT Offline OP
Arizona
Boss measures 1.000 - 1.003"
When CCing a chamber do you try to keep the fluid level to the head surface or allow it to "baloon" upward?
With the heads perfectly level I filled the chambers so the water did not extend above the head surface - this gave me the 78 measurement. If I allowed it to protrude above the head surface but not break over the edge of the chamber it was closer to 81 CCs.
I would think it needs to stay level with the surface myself but not sure about correct procedure.
Re: 440 head gaskets [Re: 68CoronetRT] #1049858
08/18/11 02:48 PM
08/18/11 02:48 PM
Longview, Texas
marvo451 Offline
marvo451  Offline
Longview, Texas
You need a piece of plexiglas greased and sealed to the head surface. Drill a small hole in the plexiglas and fill until the chamber is just full and all air has escaped. Tilting the head some helps accomplish this.
Re: 440 head gaskets [Re: marvo451] #1049859
08/20/11 09:10 AM
08/20/11 09:10 AM
JohnRR Offline
JohnRR  Offline
78cc with a 1.000 reading , that's interesting...
Re: 440 head gaskets [Re: marvo451] #1049860
08/20/11 10:39 AM
08/20/11 10:39 AM
Arizona
Arizona
When I get a chance I'll try it this way.
Thanks.
Re: 440 head gaskets [Re: 68CoronetRT] #1049861
08/20/11 10:47 AM
08/20/11 10:47 AM
Get-X Offline
Get-X  Offline
It will vary a lot depending on the valve job and the valve head. Put a set of valves in that have a flat head replacing the OE dished head valves and you'll see different cc values.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: 440 head gaskets [Re: Get-X] #1049862
08/20/11 02:00 PM
08/20/11 02:00 PM
Arizona
Arizona
These already have the 2.14/1.81 valves with hardened seats installed so the surface is flat.
I'll need to use the plexiglass method to be sure of my results either way.
Re: 440 head gaskets [Re: 68CoronetRT] #1049863
08/20/11 05:57 PM
08/20/11 05:57 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
A set of 452s I have measured 4ccs less with just a valve change.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 440 head gaskets [Re: Von] #1049864
08/20/11 07:56 PM
08/20/11 07:56 PM
Arizona
Arizona
Okay, I used the plexiglass method on two different chambers and the result was 74cc. Did this three times on each chamber with only one reading at 74 1/2 cc so it was very consistent. Apparently I was letting the water balloon up over the head surface last time when my results were 78 cc.
Measured the boss under the exhaust port on the second head and it too came in at 1.000-1.002"
Re: 440 head gaskets [Re: 68CoronetRT] #1049865
08/21/11 12:23 PM
08/21/11 12:23 PM
JohnRR Offline
JohnRR  Offline
What are you using to put the liquid into the chamber ?
Re: 440 head gaskets [Re: JohnRR] #1049866
08/21/11 07:55 PM
08/21/11 07:55 PM
Arizona
Arizona
A 12cc hypodermic needle. Slow but with the plexiglass it was easy to see when full.
I know its not the ideal way but its all I have hence the reason I did it 3 times in each chamber.
Re: 440 head gaskets [Re: 68CoronetRT] #1049867
08/23/11 09:43 AM
08/23/11 09:43 AM
JohnRR Offline
JohnRR  Offline
Did you use a yardstick to measure the head bolt boss also ? , laugh , it was a joke
Something is not right to me , your 2 numbers do not jive.
Re: 440 head gaskets [Re: JohnRR] #1049868
08/23/11 11:39 AM
08/23/11 11:39 AM
Arizona
Arizona
I know it sounds silly but hey you use what you have on hand.
As for the bosses I used micrometers so I am certain on those measurements.
Also, I sent a request to the original owner of the heads who had the valves replaced to find out if they cc'd them at that time.
I post the numbers if he sends them.
Re: 440 head gaskets [Re: 68CoronetRT] #1049869
08/23/11 12:00 PM
08/23/11 12:00 PM
JohnRR Offline
JohnRR  Offline
i'll have to go a remeasure the boss on my 915's now ... I measured the chambers with the Summit burret kit so I know it's real close .
