Re: Mopar Muscle article
[Re: can.al]
#1049733
08/12/11 10:58 PM
08/12/11 10:58 PM
70duster340
...why do you want to remove it?
It's not that I want to remove it, I just wanted to know if the possibility exists that the car will perform as well if not better without the ballast resistor. ![](/ubbthreads/images/graemlins/coool.gif)
[Re: furious70]
#1049734
08/13/11 12:08 AM
08/13/11 12:08 AM
Posts: 10,241 Someplace you aren't
SomeCarGuy
I've never read a study on how long an OEM coil and ecu will run on 12v but it's indisputable that they were designed to run on 9v to provide better starting characteristics. Run any electrical device with more volts than it was designed for and it will work, how long would come down to how much of a safety factor was built into the original design.
![](/ubbthreads/images/graemlins/spank.gif) We're aren't and never were talking about running a 9 volt coil on 12 volts. ![](/ubbthreads/images/graemlins/rolleyes.gif)
[Re: 70duster340]
#1049735
08/13/11 12:10 AM
08/13/11 12:10 AM
SomeCarGuy
It absolutely will run better, it's questionable if you will notice though IMO. The MA blurb said it will run better. Burning up the ECU is the only consideration. Empirical evidence shows it won't.
