Re: 727 help with 900 # torque
[Re: joshking440]
#1049496
08/09/11 10:42 AM
08/09/11 10:42 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I had a A&A 727 in my 3700lb, 3.50 geared turbo car. I payed about $4500 for it. The trans was built with the good input and output shafts, billet drum, 5 gear steel front planet etc.... The car was regularly street driven and beat on constantly. 7 years and hundreds of passes of low 9s/ a few high 8s. Had to have it fixed once. I exploded the dif and twisted up the driveshaft. That bent the output shaft housing and rear bearing retainer ring in the trans. Cant really blame the trans for that. At that output level I wouldnt have any issue with running a 727, especially with a 4.10 gear, as long as you get good shafts. I definitely would not have a trans built by someone with no confidence in it though. Go to A&A you wont be disappointed.
[Re: JohnRR]
#1049497
08/09/11 10:46 AM
08/09/11 10:46 AM
Posts: 8,165 Left Coast
BobR
Left Coast
Not the answer the OP is probably looking for, but at that level of power, 900 ft/lbs, ditch the 727 grenade and move to a PowerGlide or prepped Turbo 400.
At 900 ft/lbs you should be able to accelerate just fine without the added gear reduction.
You don't think a powerglide or a turbo 400 won't blow up ?
Cummins powered rams putting out over 1500 ft/lbs use a 727 based OD trans and don't blow up when built properly .
My 3000 pound Outlaw car makes twice that much torque and our Mike's glide has never broken.
[Re: BobR]
#1049499
08/09/11 11:11 AM
08/09/11 11:11 AM
Posts: 75,126 A Banana Republic near you.
JohnRR
I left out these 1500# Cummins trucks are 4x4's that weigh in at 7000lbs.
A 727 isn't right for every application but it will handle 900#, most people go to the GM based trans more because of cost than anything else .
[Re: John_Kunkel]
#1049503
08/10/11 09:30 AM
08/10/11 09:30 AM
JohnRR
But how often are they freshened up...just about any trans can be built to last a couple of runs/pulls.
That I can't answer but I know it's more than a couple pulls/runs.
[Re: John_Kunkel]
#1049504
08/10/11 11:40 AM
08/10/11 11:40 AM
Posts: 99 USA
BB Dart 69
USA
I have a Cummins at 975ft/lbs (125,OOO miles)30 pounds of boost when i leave locked in 4x4 at almost 8000lbs Trans was done at hts here in MICHIGAN. dAILY DRIVER,tow anything, They wont last to funny ![](/ubbthreads/images/graemlins/blush.gif)
