Clutch fan or flex fan on your modified muscle car?
#1049000
08/08/11 02:56 AM
08/08/11 02:56 AM
Posts: 5,270 Missouri
MY340
Missouri
Which do you prefer for cooling on your non-stock muscle car? I switched to a Flex-o-lite flex fan after having some 90 degree+ hot weather cooling issues. My clutch fan wasn't doing the job anymore and now the engine temp is running 20 degrees cooler in the hot weather. I'm sure it was going bad or just worn out.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
Re: Clutch fan or flex fan on your modified muscle car?
[Re: DAYCLONA]
#1049004
08/08/11 08:20 AM
08/08/11 08:20 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
I run heavy duty Stainless flexs.Mine has been on at least 15 years with stock 65 rad and shroud.440 runs 180 all day even in the 90s and racing also.Rocky
Chrysler Firepower
[Re: MY340]
#1049006
08/08/11 08:46 AM
08/08/11 08:46 AM
Posts: 5,912 Athens, Greece
Pyper70
Athens, Greece
After I saw the flex fan come loose and shear away from the shaft on my friends El Camino and damage the underside of his hood, his heaterbox hoses and gouge other parts of the block....The idea of putting one of those in my engine bay went out the window. If the hood was open someone would have been seriously injured....This was back in 1999...and the quality of those cheap fans ain't gettin any better. I used the shroud, the 7-blade with the thermo clutch along with a pusher fan, no problems.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: MY340]
#1049007
08/08/11 10:32 AM
08/08/11 10:32 AM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
7 blade steel clutch fan and schroud...only combo that cooled My 498 stroker. Dumped the flex fan.
[Re: bigsbigelow]
#1049010
08/08/11 11:35 AM
08/08/11 11:35 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I hate flex fans as I always seem to cut my fingers on them. I don't like clutch fans either because when they go it's by by radiator. I have used one of these on my last 3 440 cars. They work great and are very light. (and cheap)
http://www.summitracing.com/parts/SUM-G4948/?rtype=10
How do these perform in a street car that sees some idle time in traffic?
no issues. I always run a shroud. All 3 cars stayed at 180* or below. I think my old 67 got up to 190 a few time but as soon as you start to move it would drop. I drove this car to the track and raced all day and it didn't get above 180...
[Re: Mr.Yuck]
#1049011
08/08/11 11:41 AM
08/08/11 11:41 AM
Posts: 30,537 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
I am not a FAN at all of the clutch unit .... I have seen tooo many lock-up or fall-apart then shoot-through the rad or the hood. FLEX furr me. Sharp edges ? ... the OEM Chrysler parts don't have this prob.
[Re: Mr.Yuck]
#1049012
08/08/11 11:47 AM
08/08/11 11:47 AM
Posts: 1,564 St. Clair Shores, Michigan
bigsbigelow
Sounds like I may try one out. I am looking for a lighter alternative to my H.D. Stainless flex fan. I do not run a shroud and my car only creeps to about 190ish in traffic so I think my system is good. Like said, I just want a lighter fan.
[Re: Mr.Yuck]
#1049014
08/08/11 01:45 PM
08/08/11 01:45 PM
bigsbigelow
get a shroud! P.S. you'll need a spacer. I think mines a 1" or 1.5"
I currently run a spacer. The fan is about 5/8" of an inch from the radiator.
[Re: 62maxwgn]
#1049016
08/08/11 05:32 PM
08/08/11 05:32 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
[Re: can.al]
#1049019
08/08/11 08:10 PM
08/08/11 08:10 PM
Posts: 4,588 St. John's Newfoundland
440newport
who have tried the performance 5 blade clutch ..i have heard it works excellent?
The MP fan package is the same as a 80's 5th avenue/Diplomat fan. I replaced the solid 7 blade fan with one in my Mirada and it solved my overheating in traffic problem.
