Re: Will a 3000lb electric wench
[Re: Aspen7695]
#1048235
08/06/11 07:29 PM
08/06/11 07:29 PM
Posts: 5,992 Anoka County, MN
Leigh
Anoka County, MN
I use a 3000lb Superwinch to pull my 3250lb Duster on my open trailer. No problem at all.
Raul
Now on a more serious note, I have the same winch, and no problems at all.
[Re: Bob_Coomer]
#1048236
08/06/11 07:30 PM
08/06/11 07:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
My ATV had a small wench which was 1500 maybe 2000 lbs rated. It pulled my Dakota onto a flat bed open trailer a few times... No problems... if a 3000 wench cant do this, its JUNK.. I would avoid the cheaper harbor freight type wench's.
Sorry... I've been using the cheap Harbor freight ones for years.... I did just buy a new one because the clutch is starting to slip..... cant see buying a big dollar Warn when it sits MOST of the time ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Bob_Coomer]
#1048238
08/06/11 07:57 PM
08/06/11 07:57 PM
MR_P_BODY
Only reason I say this is cause my Father-In-Laws wench on his Yamaha Rhino is J.U.N.K wont even pull a ATV stuck in a mud hole the other day... It's hardly 6 months old..
I use to pull my car in backwards all the time with the cheapo HF unit but now I drive it in... that cheapo lasted 8 years using it all the time... maybe he got a bad one ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Bob_Coomer]
#1048239
08/06/11 08:38 PM
08/06/11 08:38 PM
Leigh
Anoka County, MN
Yep, sure sounds like the wench I'm stuck with. My Super WINCH on the other hand, works hard, when asked.
[Re: BloFish]
#1048240
08/06/11 10:26 PM
08/06/11 10:26 PM
Posts: 43,347 Bend,OR USA
Cab_Burge
Does anyone want to go out on a limb and recommend a winch
I've had and used the 2500 lb Super Winches, 3500 lbs and 4500 lb. Super Winches in trailers, like most thing it is way better to have the bigger one I have a freind who bought one of the Harbor Freight 2500 or 3000 lb winches(I can't remerber which ) it work twice and quit pulling his 1964 Dodge 330 two door bracket car into his Pace 24 ft enclosed trailer with the noraml dove tail floor and door As Fred said, the 2500 lb winch would almost come to a complete stop pulling my old bracket Duster(3150 lbs with me in it, 2870 lbs without me ) into my Pace trailer with the normal dove tail floor, the 4500 lb one doesn't slow down at all ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) One of my old booses ask me to rescue his 1967 Ford 3/4 ton pick up truck(empty) when it broke down out of town, the 3500 lb winch in that trailer struggle to pull his truck into my trailer Warn winches are very good also, according to all the off roaders around here ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: Mopar-Al]
#1048245
08/07/11 12:15 AM
08/07/11 12:15 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Alyerpal and REHBERGER can wad their cars up, tear the wheels clean off of them...... ![](/ubbthreads/images/graemlins/biggrin.gif) and still get the car back in the trailer! I have one of the Harbor Freight 3k winches...... see Freds story about taking a nap while getting the car back in the trailer.
[Re: RATTRAP]
#1048247
08/07/11 12:56 AM
08/07/11 12:56 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Will a 3000lb electric wench Pull my 3400lb car onto a trailer?? What lb rating is the avarage every one uses
Yes, it will! I used the elcheapo $49.00 1500# winch from harbor freight for a few years, Like MrPBody did.
I only had to tow the 3000# race car onto the trailor once. But I used it many times to tow other heavier vehicals onto the same trailor at heavier weights, 4500+ or so.
The old El Cheapo $49.00 1500# winch from Harbor freight worked pretty good.
My newer El Cheapo $89.00 3000# winch from Harbor freight is a train wreck. The cable as it unspools binds up like you wouldnt believe. That was never a problem with the 1500# winch.
You get what you pay for! Winch cable speed is also a serious consideration.
As far as wenches, They need love too! ![](/ubbthreads/images/graemlins/beer.gif)
Dont we all get along?? Wrench and Wenches! ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Sport440]
#1048248
08/07/11 11:07 AM
08/07/11 11:07 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
My cheap Harbor Freight 3000 lb winch not only pulls my dragster in but lets it out of the trailer. It may not be a high $$$ warn but still gets the job done. ![](/ubbthreads/images/graemlins/thumbs.gif) Sport440,you need to keep tension on most winches as they unspool. Hopes this helps solve your problem.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#1048249
08/07/11 12:44 PM
08/07/11 12:44 PM
Posts: 196 out front
jerrya
Comin to a Labor Day Telethon
out front
If you use a snatch block, (another pulley to double line the cable) it will double what you can pull.
Man does not plan to fail... he fails to plan
[Re: RATTRAP]
#1048250
08/07/11 02:39 PM
08/07/11 02:39 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I use a 3000# superwinch all the time for my car/trailer. Most of the problems I have seen others have are wiring or battery related (they cheap out and undersize)
"Just a Bracket car dressed up like a streetcar"
[Re: jerrya]
#1048251
08/07/11 02:41 PM
08/07/11 02:41 PM
MR_P_BODY
And at the same time it doubles the time to pull the same distance..... but it will pull double the weight ![](/ubbthreads/images/graemlins/wave.gif)
[Re: coronetville]
#1048253
08/07/11 05:30 PM
08/07/11 05:30 PM
Posts: 653 Fort Worth, TX
Dago Red
Fort Worth, TX
A 3000 lb wench is like a motor scooter: useful and fun, but just don't let your friends see you riding it....
If You Can't Be Good, At Least Be Colorful
