Re: My car fall on its face at the 1000 ft? long
[Re: topside]
#1047956
08/06/11 09:34 PM
08/06/11 09:34 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Cab, I think you're about right on the secs/gal; I seem to recall that 20 secs/gal is good for a low-10-sec car. Fig, take a really good look at your spark plugs & check your float settings, and if there's any rubber hose in the system, make sure there aren't any internal cuts that can create a flap inside the hose that reduces the amount of fuel it can flow. If you're running a stock pickup, make sure the fuel isn't pulling away from it; on my Roadrunner, I added a length of suitable hose that lays on the bottom and extends rearward a bit inside the tank. My Duster uses a sump.
He's right on those numbers BUT those are a VERY GENERAL number... weight of the car comes into play... it takes more power to move a 3500# car to low 10s VS a 2500# car to the same... more power requires more fuel ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1047957
08/06/11 10:13 PM
08/06/11 10:13 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
Lots of variables in this hot rodding business Lots of gremlins also ![](/ubbthreads/images/graemlins/rant.gif)
[Re: fig426]
#1047958
08/06/11 10:17 PM
08/06/11 10:17 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
1 gallon in 45 seconds from the blue pump. Picked up a Holley 150 black pump today. It's flow rate is pretty good, came with a new regulator, and it's alcohol compatible if I ever decide to change over. Looking like rain for tomorrow so hopefully if it's dry Wednesday night I'll bring it up to Island for a few passes. http://www.holley.com/12-150.asp
45 seconds...
That can't be good.. ![](/ubbthreads/images/graemlins/tsk.gif)
Chris.. ![](/ubbthreads/images/graemlins/shock.gif)
[Re: Chris'sBarracuda]
#1047959
08/07/11 12:26 PM
08/07/11 12:26 PM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
Island is rained out today. Gonna have to wait until Wednesday.
Chris from New Jersey
[Re: fig426]
#1047960
08/07/11 05:08 PM
08/07/11 05:08 PM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
do you have a fuel pressure gauge that you can see .Shoud be dropping at that point at losing HP . Fuel line, fuel filter bet is the issue as others have said . ![](/ubbthreads/images/graemlins/Twocents.gif)
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
[Re: fig426]
#1047962
08/07/11 06:52 PM
08/07/11 06:52 PM
Posts: 9,654 Southern by Choice
Shoozy
I have a foot fetish
Southern by Choice
How long for the black pump to pump a gallon?
Old, tired, and sometimes broke down. Me, not my car...
[Re: fig426]
#1047972
08/08/11 06:51 PM
08/08/11 06:51 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
I see, I thought you where comparing a 140 GPH free flow black pump to a 110 GPH blue pump. I would still check it.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Rapid340]
#1047973
08/08/11 10:56 PM
08/08/11 10:56 PM
Posts: 903 Saskatchewan, Canada
cudabin
Just to be sure, did you check the valve springs? I know you said it pulled strong in 1st and second, but I would check seat pressure and open pressure to be sure... ![](/ubbthreads/images/graemlins/scope.gif) I used to run 9.55 at 138 with nothing but a single Blue pump... ![](/ubbthreads/images/graemlins/shruggy.gif) Good luck, Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: fig426]
#1047975
08/11/11 12:28 AM
08/11/11 12:28 AM
MR_P_BODY
Made 2 passes tonight with the new fuel pump. First one redlighted -.437. 12.01 at 118mph. Total mess of a start but it pulled strong throughout. Second run. 60 foot 1.705 . .1 slower than last week. 330' 4.844. 1/8 7.424 at 95.56mph. 1000' 9.647. 1/4 11.531 at 119.41mph. I did a bad burnout and spun 1st and second. Pulled strong through the lights at about 6400rpm. Have some other things to sort out, like me being the driver , but I think it should go into the high 10's. Also it runs like turds after I go through the traps. Seems like now it's loaded up with fuel. I'll play with the fuel pressure, maybe a return line. Thanks again to all of you for the help.
Good to hear it pulls all the way... set the pressure, set the floats and most likely you will have to do some jetting ![](/ubbthreads/images/graemlins/wave.gif)
