Re: Video of my first time to the track 71 Valiant 416 4spd
[Re: MIKES_DUSTER]
#1046489
08/03/11 11:57 AM
08/03/11 11:57 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Also great numbers, It looks from the tape that the car is launching soft, sounds like your slow on letting the clutch out , but the number is there on the 60 foot. It didn't look at the launch that there was any spin. Good job on gear changes ![](/ubbthreads/images/graemlins/drive.gif)
[Re: rowin4]
#1046490
08/03/11 12:18 PM
08/03/11 12:18 PM
Posts: 151 Canada BC
Steve Barton
Canada BC
Also great numbers, It looks from the tape that the car is launching soft, sounds like your slow on letting the clutch out , but the number is there on the 60 foot. It didn't look at the launch that there was any spin. Good job on gear changes ![](/ubbthreads/images/graemlins/thumbs.gif)
I have a Advanced adjustable clutch in it, set a 4 turns, thats hi for the track, I will be putting it at 3 turns. I am not side steping the clutch on launch. there does not seem to be any suspension change at all. Coil over front and rear Ladder bars Varishocks single adj
big step from my best @ 1.6 60' 11.5 1/4 mile and 118 mph
[Re: sshemi]
#1046492
08/03/11 01:21 PM
08/03/11 01:21 PM
Steve Barton
Canada BC
good driving ![](/ubbthreads/images/graemlins/thumbs.gif)
Whats the recipee for the tranny?
Its a 833 aluminum case Liberty gears, super pro shifted ( face plated ).
[Re: MR_P_BODY]
#1046494
08/03/11 02:54 PM
08/03/11 02:54 PM
Steve Barton
Canada BC
Looks good.... what are you doing letting off the gas on the shifts.... beat on that bad boy ![](/ubbthreads/images/graemlins/grin.gif) time to start testing different launch and shift RPMs
Ya looking forward to tuning up my driving skills and playing with shift points. I did not have my two stage hooked up so I was just guessing on my launches, don't even no what rpm I was at.Did you look at the suspension, it did not seem to change at all. no drop on the ass end and no lift on the front ?
[Re: Steve Barton]
#1046495
08/03/11 03:02 PM
08/03/11 03:02 PM
Posts: 52,972 Romeo MI
MR_P_BODY
A little lift in the front and almost zero lift in the rear... whats the rear suspension and what shocks all the way around ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Steve Barton]
#1046496
08/03/11 03:06 PM
08/03/11 03:06 PM
Posts: 2,128 sweden
sshemi
sweden
Just a little lift in front but i guess you could blame the soft start for that
[Re: Steve Barton]
#1046498
08/03/11 03:09 PM
08/03/11 03:09 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
Here is a vid, I ran a 1.43 60' 6.58 1/8th 107.8 mph I only got 3 passes back to back and no adjustments between passes. I thought I was spinning in first and sec but it does not look like it in the vid, what do you think do you think there is more in it yet. http://www.youtube.com/watch?v=OBDowLilWOw&feature=player_embedded
Is that at thunder mountian a.k.a. Hoakie hill in Kelowna?? If it is, what is the elevation? I hear its way up there! ![](/ubbthreads/images/graemlins/thumbs.gif)
-Kenny
[Re: MR_P_BODY]
#1046501
08/03/11 06:12 PM
08/03/11 06:12 PM
Steve Barton
Canada BC
Ladder bar rear, with coil over, single adj Varishocks all around, rear springs are 250 lbs front springs are 350 lbs. rear shocks were set at #4 front #1
[Re: StrokerAspen]
#1046502
08/03/11 06:16 PM
08/03/11 06:16 PM
Steve Barton
Canada BC
-Kenny
No this is on Vancouver Island in Port McNeil at the airport 1/8 mile. I will be racing in PortAlberni this weekend 1/4mile. also at the airport.
[Re: MR_P_BODY]
#1046504
08/03/11 06:35 PM
08/03/11 06:35 PM
Steve Barton
Canada BC
Are you mistaken on the rear springs... at that weight spring it would be topped out sitting there... you have shock settings of #4 and #1..... out of how many
Ya I would say you were write on the rear springs # 0n the spring is 12-110 so I'm guessing 110 lbs. Fronts are marked 350lbs, both f,r shocks have 17 clicks. On the front if I go any hirer than #2 it is rock hard both directions.
[Re: Steve Barton]
#1046505
08/03/11 06:42 PM
08/03/11 06:42 PM
MR_P_BODY
MUCH more like it on the springs... I think you need to pick up the RPM to plant the tire better and do the other things suggested.... for instance... on my car I CANT leave at idle... I'd be all over both lanes but if I launch at revs it plants and I get a 1.19 60' ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1046506
08/03/11 07:31 PM
08/03/11 07:31 PM
Steve Barton
Canada BC
thanks for every thing Mr P Body I will have my two stage rev limiter hooked up for the weekend so I will start my launch a 5000 rpm and go from there, plus I will keep the pedal to the metal on my shifts. I will let you all no how it works out next week.
