Re: Dual throttle springs
[Re: topside]
#1046467
08/03/11 01:20 PM
08/03/11 01:20 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Years ago when I was a wee boy I used one spring and it broke while I was showing off going in reverse. The brakes would not stop the car. I totaled a Toronado and a wall and broke my leg, in the process. My brother was on top of the car and got tossed when I hit the wall. Coulda been worse if some one were standing in the way. Not a shining moment. Use two springs.
I have mechanical Aptitude. I can screw up anything.
[Re: 1BAD68]
#1046469
08/03/11 01:25 PM
08/03/11 01:25 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
How many of you are using two throttle return springs? I hammer my gas pedal frequently and wonder when my single spring will break and destroy my engine. Tried using two springs but it made the pedal stiff and jerky when just driving normal.
Try two slightly weaker springs.
[Re: bobs66440]
#1046471
08/03/11 02:02 PM
08/03/11 02:02 PM
Posts: 30,465 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
x 2 ... it is has been a while since I bought a set but the pair I got a while ago did not increase pressure much at all. And they separately returned the throttle back fine.
[Re: bobs66440]
#1046473
08/03/11 02:18 PM
08/03/11 02:18 PM
Posts: 277 Cincinnati, Ohio
chargincharles
Cincinnati, Ohio
Or use the 'srong' spring you already have and go to the local Autozone, Advanced, Etc. In the HELP! section they carry a universal sping that is cut-to-fit. Make it the 'weak spring'
I have the Locar set-up. My 'Primary' spring is on the carb, but the 'seconday' or back-up is on the lever arm of the Transmission. So it is hidden. Still does the job though.
Just my pennies, CC.
[Re: chargincharles]
#1046474
08/03/11 02:43 PM
08/03/11 02:43 PM
Posts: 6,097 Valencia, España
NachoRT74
Valencia, España
I still have my FACTORY spring, and DAMN!! THAN THING IS STIFF SO STIFF THAT MY KNEE GET HURTS, specially traveling in the country... maybe metal its somehow cristalized. Got a new one to replace it but engine is not build yet
[Re: Mopar_Country]
#1046478
08/03/11 06:48 PM
08/03/11 06:48 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Two light springs, one slightly stronger than the other and pulling from the opposite direction and on the opposite side of the throttle shaft, can help offset a throttle cable and a single spring's constant pull and wear on the throttle shaft bushings.
When properly sized and located, they help counter each others tendency to pull the throttle shaft into the bushing.
Some carbs have a return spring built into the throtle shaft.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#1046480
08/03/11 11:05 PM
08/03/11 11:05 PM
Posts: 15,487 Florida
scratchnfotraction
100%
