Re: Dual throttle springs [Re: scratchnfotraction] #1046481
08/03/11 11:52 PM
08/03/11 11:52 PM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
My cars see occasional track time -- they won't pass tech without dual springs. So, yes -- dual springs here.
Re: Dual throttle springs [Re: Hotwheelsjr] #1046482
08/04/11 12:14 AM
08/04/11 12:14 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I saw a 4 sec 1/8th mile car break loose, get back on it (dumb), then found the trees at the end of the shutdown area.
Use two springs.
I want my fair share
Re: Dual throttle springs [Re: SomeCarGuy] #1046483
08/04/11 09:02 AM
08/04/11 09:02 AM
wisconsin
1BAD68 Offline OP
1BAD68  Offline OP
wisconsin
I played around with some different springs and after finding a good combo and turning the spring bracket 90 degree's, I was able to get a nice feel to the pedal.
Re: Dual throttle springs [Re: 1BAD68] #1046484
08/04/11 09:07 AM
08/04/11 09:07 AM
Florida STAYcation
IcorkSOAK Offline
Financed his waterbed
IcorkSOAK  Offline
Florida STAYcation
... come to think about it .. the last NEW set I bought was at NAPA. I have seen a single large spring be way-more "pressure" than a properly comboed-together set.
Re: Dual throttle springs [Re: 1BAD68] #1046485
08/05/11 10:26 PM
08/05/11 10:26 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Just grab some springs from a junker. It's hard to find the right combo from those assorted packs of springs.
Your present set up will be easy to press the pedal but hard as you reach the floor. That's the problem with running short springs.
For a more consistent feel from tip in to full throttle, you need 2 long weak springs.
Re: Dual throttle springs [Re: Magnum] #1046486
08/06/11 06:30 AM
08/06/11 06:30 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Quick Fuel makes a dual return spring kit too.
