Re: Race converter recomendations
[Re: '72CudaRacer]
#1046342
08/03/11 01:20 PM
08/03/11 01:20 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
If you are interested in an Ultimate converter, I have an 8" for a 727 I've tried selling in the "Race Parts" with no takers. It may be a little loose for you now. It flashed about 5900 behind a 13:1 340. I'll have to check my log book but, believe it has less than 20 passes on it. PM me if so.
EDIT: 21 passes TOTAL
[Re: '72CudaRacer]
#1046346
08/04/11 12:42 AM
08/04/11 12:42 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Thanks for the replys. I have had Junk, cheap converters in the past (long time ago) and have been real pleased with my TA "J". Just wanted to know if there was something else better, but it works well enough now that I'm almost afraid to change it. I'd really hate to spend $900-$1200 and not see an improvement. I guess I was hopeing to hear about a new, one size fits all, magic bullet. Thanks again, Brian Dunnigan
You arent far off so there isnt going to be a magic bullet thats going to give you a 1/2 second..... MAYBE a .1 and I doubt you would see that.... your ET and MPH are in line SO its time to do a little work on the engine.........JMO ![](/ubbthreads/images/graemlins/wave.gif)
[Re: '72CudaRacer]
#1046348
08/04/11 06:41 PM
08/04/11 06:41 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
This car is a true footbrake racer, running 1/8 & 1/4 mile, best time of 6.4X, 105.xx and 10.39, 127.xx. I welcome all sugestions,
Thanks, Brian Dunnigan
IMO, Your numbers indicate a problem on the second half track. Your only gaining 22 MPH from the 1/8 to the 1/4. You should be gaining another 24 to 26 MPH. Further your 6.45 ET 1/8th equates to around a 10.20 1/4, not a 10.39
Whats your 60ft. numbers, if they are stellar 1.35,s or so that might explain the hard first half vs the slower second. Typical, numbers for that 10.39 et would be low 1.4,s 1.41 to 1.43
Your slippage numbers dont look bad. I wouldnt consider a vert change until you can get the numbers more inline. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: '72CudaRacer]
#1046349
08/04/11 08:25 PM
08/04/11 08:25 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
IMHO, I really think you'll have a hard time improving on what you already have.I know I wouldn't take a $9-1200 gamble.As most know when it comes to converter posts,I always will suggest Turbo Action.Our first TA 3800 was purchased in 1977 and it still works great to this day and has never been back to TA or anyone else for a freshening.I can honestly say that the converter and the Dana 60 are 2 things I never worry about in the car.I have found Turbo Action products to be very good quality and we've never had any problem with their stuff.
[Re: gregsdart]
#1046351
08/04/11 10:04 PM
08/04/11 10:04 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
www.lofgrenauto.com Chuck has been talking about 3 percent slip converters. Great guy to work with. Has been in the transmission biz for over 25 years.
Unless things have changed, Lenny (ultimate converters) has been Chucks "go to" guy. Chuck recommended him to me back when he was TCT. We have a 904 Chuck built and the 727 in my car was originally out of his "shop" when it was still his house in Coon Rapids. Good guy!
[Re: Voluster]
#1046354
08/05/11 11:59 AM
08/05/11 11:59 AM
Posts: 3,210 robin hood country
deaks
robin hood country
What is your combo, did you change anything else,what stall was on the J and what stall was on the ultimate. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Voluster]
#1046355
08/05/11 12:30 PM
08/05/11 12:30 PM
MR_P_BODY
Lenny is the man
I called him and told him what I had and what I was doing.
Pulled my j converter and put his in car went from 10.28at 130mph to 9.88 at 136
That just sounds like your conv was way off before... whats the difference in RPM at the traps ![](/ubbthreads/images/graemlins/wave.gif)
[Re: moparacer]
#1046357
08/05/11 08:55 PM
08/05/11 08:55 PM
Sport440
Canton, Ohio
i worry more about consistency, than max et or mph. got a looser one coming to try out.
Now yer thinkin!
But the OP, Brian, is looking for a improvement in ET. On anther thread, he also implied he was looking for more consistancy. ![](/ubbthreads/images/graemlins/devil.gif)
[Re: deaks]
#1046360
08/05/11 11:01 PM
08/05/11 11:01 PM
Posts: 550 Ma
Voluster
Ma
I didn't change anything but the converter the J converter was way to loose or slipping car hit the limiter on the big end. was an old school unit Put lennys converter in there and it picked up in the 60 and all the way down the track lenny said somewhere in the 3800 on the motor and 5200 on the juice. I don't know where it stalls I was to busy driving ![](/ubbthreads/images/graemlins/drive.gif)
[Re: moparacer]
#1046361
08/05/11 11:31 PM
08/05/11 11:31 PM
Posts: 2,056 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Thanks for the replys and insite guys. My TA "J" converter is on the big brown truck, heading to Paul Forte (Turbo Action), to let him have a look at it. This converter has approx 800 passes on it since it was last freshened up. The REAL problem I have been dealing with is ocasionally the air shifter would go to 2nd gear on time, but the air cylinder would keep the shifter pulled back (B & M Pro Ratchet) and I would have to "burp" the throttle to get it to release. When I would burp the throttle, the shifter would go back to center position and then immediately go to high gear. The next time it would function normally. It appears that the RPM's were not droping back far enough when it shifted to release the RPM switch. It did it so randomly that it was hard to pinpoint a pattern, but seemed to do it when it was hot, usually when going "round robin". Paul thinks that possibly the sprag in the converter is slipping when it gets hot?? We will know soon. I do know that it has cost me at least two races, one of which was the final of the mid season shoot out. I like what I have with my Turbo Action converter, just wondering if I can improve upon it. ![](/ubbthreads/images/graemlins/tsk.gif) And if anyone thinks my car isn't consistant... lets just say my car has been called a Zerox machine more than a few times. ![](/ubbthreads/images/graemlins/biggrin.gif) Thanks again, Brian Dunnigan
