Page 3 of 4 1 2 3 4
Re: W8 vs. W9 Engines: What are the major differences? [Re: 340_Dart] #1045823
08/04/11 12:50 PM
08/04/11 12:50 PM
nc
cold85 Offline
cold85  Offline
nc
If I Remember Correctly
Now back to W8 and W9 talk please
HAHA I was thinking some edition!!
Re: W8 vs. W9 Engines: What are the major differences? [Re: 340_Dart] #1045824
08/04/11 12:51 PM
08/04/11 12:51 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Has anyone ran a w8 or w9 motor at small ci? I've got a complete 358 w8 craftsman truck motor that came from brad Kezlowski that I eventually want to get into my valiant... I'm debating on trying to convert it from a dry sump motor to a wet sump motor though... Any recommendations on doing this?
Re: W8 vs. W9 Engines: What are the major differences? [Re: 340_Dart] #1045825
08/04/11 01:07 PM
08/04/11 01:07 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Single-stage belt driven pump with a swinging pick-up.
(I saw your engine before you did.)
Re: W8 vs. W9 Engines: What are the major differences? [Re: 340_Dart] #1045826
08/04/11 01:43 PM
08/04/11 01:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If its a dry sump now I would leave it dry sump...
plus the pump pulls a vac... my pump pull about 12"hg
Re: W8 vs. W9 Engines: What are the major differences? [Re: MR_P_BODY] #1045827
08/04/11 02:17 PM
08/04/11 02:17 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Mike,
The issue I'm afraid I'll have is that I won't have room for the pump with my stock steering and k-member.
Re: W8 vs. W9 Engines: What are the major differences? [Re: 340_Dart] #1045828
08/04/11 02:55 PM
08/04/11 02:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mike,
That could be a issue... not many places you can hang
a belt driven pump
Re: W8 vs. W9 Engines: What are the major differences? [Re: 340_Dart] #1045829
08/04/11 04:12 PM
08/04/11 04:12 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Are you running it "as is", or are you changing the cam???
Re: W8 vs. W9 Engines: What are the major differences? [Re: jim sciortino] #1045830
08/04/11 04:20 PM
08/04/11 04:20 PM
Finland
mafo Offline
mafo  Offline
Finland
you need one of these...let you move the pump to the other side
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: W8 vs. W9 Engines: What are the major differences? [Re: mafo] #1045831
08/04/11 05:37 PM
08/04/11 05:37 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Where can I get one of those relocation brackets?
Jim, Brett Miller (W5DART66) put me onto this motor last year. We originally talked about making the necessary changes to make the motor run in the car and run it "as is" and then changing the cam later on.
Is there a reason you ask?
Re: W8 vs. W9 Engines: What are the major differences? [Re: 340_Dart] #1045832
08/04/11 05:57 PM
08/04/11 05:57 PM
Finland
mafo Offline
mafo  Offline
Finland
bracket was made by my "crewchief", fits a moroso 5 stage, not sure if it fits other moroso pumps
If you need one I m sure it can be arranged but since we don't have a cnc mill of our own it will take some time
you asked about small engines, I have a 357 with only 3.19 stroke and it did not really perform as I expected, I guess you need to get the converter 100% right or go with a 5 speed/clutch..or maybe I m not smart enough
Re: W8 vs. W9 Engines: What are the major differences? [Re: 340_Dart] #1045833
08/04/11 08:22 PM
08/04/11 08:22 PM
Trumbull,CT.
Trumbull,CT.
I've heard there is ET in a cam change vs the truck cams. It's like anything else though, as it depends on other areas.....heads, induction, clearences, etc.
Re: W8 vs. W9 Engines: What are the major differences? [Re: jim sciortino] #1045834
08/04/11 11:12 PM
08/04/11 11:12 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
So what's the minimum bore a W8 or W9 head can be ran on?
Re: W8 vs. W9 Engines: What are the major differences? [Re: 340_Dart] #1045835
08/04/11 11:24 PM
08/04/11 11:24 PM
Trumbull,CT.
Trumbull,CT.
Not sure about the minimum, but ours is 4.185 w/2.19 valve.
Re: W8 vs. W9 Engines: What are the major differences? [Re: 340_Dart] #1045836
08/04/11 11:31 PM
08/04/11 11:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Depends on the valve size... the W-9 comes with a
couple different intake sizes... I'm at a 4.125 bore
but I wish I would have gone 4.185... I have a 2.18 valve
Re: W8 vs. W9 Engines: What are the major differences? [Re: 340_Dart] #1045837
08/05/11 12:39 AM
08/05/11 12:39 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Comp Eliminator guys will run on around a 4.06" bore in classes like C/ED. They run around a 1.5" exhaust valve with a 2.18" intake valve from memory. I haven't heard of a W9 being run in Comp, but I haven't been paying too much attention to it in the last few years. The W9RP were tried, but weren't really suitable
Alan Jones
Re: W8 vs. W9 Engines: What are the major differences? [Re: LA360] #1045838
08/05/11 08:27 AM
08/05/11 08:27 AM
australia
charger410 Offline
charger410  Offline
australia
I run a dry sump and using a bracket the same or similar as mentioned above with the factory k member. The pump and oil lines have about 5mmm clearance.
And just for comparision my w9 headed 410 made 875hp at 7600rpm and 651fbs at 5400rpm.
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
Re: W8 vs. W9 Engines: What are the major differences? [Re: charger410] #1045839
08/05/11 07:27 PM
08/05/11 07:27 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
im hopeing to build something like that,soon
Re: W8 vs. W9 Engines: What are the major differences? [Re: charger410] #1045840
08/05/11 07:46 PM
08/05/11 07:46 PM
LA360 Offline
LA360  Offline
Straight out of a Sprint Car?
Alan Jones
Re: W8 vs. W9 Engines: What are the major differences? [Re: LA360] #1045841
08/06/11 10:57 PM
08/06/11 10:57 PM
australia
charger410 Offline
charger410  Offline
australia
Just about. With the oil tank in the boot
Re: W8 vs. W9 Engines: What are the major differences? [Re: charger410] #1045842
08/07/11 04:33 AM
08/07/11 04:33 AM
LA360 Offline
LA360  Offline
Your braided line guy would have loved you! lol
How many litres is that petrol tank??
Alan Jones
Page 3 of 4 1 2 3 4
