Re: W8 vs. W9 Engines: What are the major differences?
[Re: charger410]
#1045843
08/07/11 07:23 AM
08/07/11 07:23 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I run a dry sump and using a bracket the same or similar as mentioned above with the factory k member. The pump and oil lines have about 5mmm clearance.
And just for comparision my w9 headed 410 made 875hp at 7600rpm and 651fbs at 5400rpm.
Care to give us some specs on your 410... is that a alky engine
[Re: MR_P_BODY]
#1045844
08/07/11 09:27 AM
08/07/11 09:27 AM
Posts: 159 australia
charger410
australia
LA360 Originally put the car together to mainly use on the street and hence the large fuel tank 150liter but much more fun just to go racing with it so I'll be putting a 50liter in.
MR P Body Yes methanol. The engine originaly came from a US sprint car team Mopar alloy block 4.15 bore Bryant crank 3.8 stroke W9 heads with titainium valves Jesel rockers solid roller cam 268 at 50 with roughly 800lift CP pistons 15-1 comp Kinsler injector stacks Barns 4 stage dry sump system Custom alloy pan which sits only 6-7mm from the crank so the engine can sit as low as possible in the engine bay, with factory K member Stepped headers 1 7/8 to 2inch 3inch collectors
If you dont mind MR P Body what sort of combo are you running?
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
[Re: charger410]
#1045847
01/25/12 10:08 AM
01/25/12 10:08 AM
MR_P_BODY
Mine is a 405ci 48* 9.2 deck 4 stage dry sump 3.79 billet crank Eagle H-beam 6.125 chevy CP pistons at 14.1 4.125 bore CNCd W-9s with 2.18/1.625 valves TD rockers 276/282 .700/.695 cam 50mm tunnel 1050dom on e-85 420 intake milled to take the 1050 dragster pan .... it doesnt make anywhere near the power you have
[Re: WO23Coronet]
#1045849
01/25/12 06:20 PM
01/25/12 06:20 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Arrington heads were the used in off road racing and ARCA. Some were used for a couple races in Craftsman truck. Very shortly after that the W7 was out and running. Some teams may have had them in the beginning of truck. I remember seeing pallets of these heads at Arringtons to be CNC'ed. Some of the very late W7 heads had 18 head bolts.
Then the W8 came out which had some changes like a wider valve cover a Lazy W bolt pattern for the rocker bars, and more room for larger ports. CFE did the majority of the Pro Stock truck heads and Chapman did a lot of the Round d round heads. Roundy rounds had 2.18-2.20 intake valves with a 1.6-1.625 exhuast. The drag race CFE heads had 2.250" intake valves and 1.55" exhaust on the few I have seen.
The sprint car guys wanted a lighter head and the Craftsman truck guys wanted more water from what I have been told. The W9 was the answer to these issues.
This is my understanding from the guys like Joey Arrington, Bob Dowling, Kent Ritter and many others who knew a lot more than I did about the subject. It is all from memory. I have talked in debt with CFE's Carl Fultz about the drag race version W8 and a few W7 and W9 heads. In their opinion the W8 is preffered although their are some W9 head high ports that people have tried to be competitive with. There was just not as many done as the W8 so the R&D comes up short. In some applications like power adder combos the W9 may prove to be a good candidate but, most of the head porters I know have just not been able to get comparable results. All of the beforementioned heads will kick the snot out of all previous wedge designs for small blocks.
Leon
[Re: Leon441]
#1045851
01/25/12 09:43 PM
01/25/12 09:43 PM
Posts: 4,280 Canada
WO23Coronet
Canada
Leon
So what were the original Arrington heads you first mentioned, W5's? Which heads will work on a 59 degree block? I know W2's will but I'm not sure about the rest, although I'm pretty positive the W8's and 9's wont. Sorry for all the questions but I'm a real NOOB with the W series of heads. It seems the W8's are as good as anything and then some compared to the wedge designs that the phORD and chIVY boys have.
[Re: WO23Coronet]
#1045853
01/25/12 09:56 PM
01/25/12 09:56 PM
Posts: 3,416 Pa
Hot 340
Pa
Here's some basic info from Ryan J's site.. http://www.shadydellspeedshop.com/faq.htm
[Re: MR_P_BODY]
#1045855
01/25/12 10:09 PM
01/25/12 10:09 PM
Leon441
Lynchburg, VA
Arrington had his own head.
He had one he referred to as a Vintage that worked on 59 degree blocks but had a really high intake runner like W7 and up.
Then there was the Arrington wich was very similar to W7's. In fact their are a few people who actually had Arringtons and called them W7 heads. The ones I had used a chevy stand that was cut and spaced then welded together. The intake bolt spacing was also the same as W2 and W5 heads. This made Using a W7-9 intake a challenge. A lot of guys including myself modified a 18 degree Chevy intake to work. Now Chevy guys want the W8 intake manifolds.
Leon
