W8 vs. W9 Engines: What are the major differences?
#1045783
08/02/11 02:56 PM
08/02/11 02:56 PM
Posts: 577 Arkansas
Adrielp
Arkansas
Also, which will make more power? Kind of curious on the differences between the two engines.
Adriel Paradise Substation Design Engineer III
Re: W8 vs. W9 Engines: What are the major differences?
[Re: Adrielp]
#1045784
08/02/11 03:34 PM
08/02/11 03:34 PM
Posts: 1,019 Finland
mafo
Finland
w8 heads have more meat, just more to work with when making all out heads, w9 are lightweight castings I guess w8 s make more power if you know what you are doing ![](/ubbthreads/images/graemlins/thumbs.gif)
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: fishy340]
#1045786
08/02/11 03:56 PM
08/02/11 03:56 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
w8's are more exotic $ there basicly chunks of aluminum that resemble heads..make more power yes in the right hands,,w9 just an awesome head...cheaper,lighter and will make power..w8 is awesome,but requires good amount of work
Correct....
You can score a Craftman Truck head ready to go, but it will not have the capability of say a CFE 10* deal.
We have a Coleman/Arrington 15* that makes nice power, but the heads that we're sending to CFE for a future build are so raw, there isn't even a spark plug hole.
The 8s have more meat than a 9 and I doubt a killer program for an 8 can be applyed to a 9......but I'm not positve about that.
[Re: Adrielp]
#1045787
08/02/11 04:17 PM
08/02/11 04:17 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
i forgot to say engines are the same 48* block! hope it answer ur question.
[Re: Adrielp]
#1045789
08/02/11 06:39 PM
08/02/11 06:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
A W-8 needs a ton of work to make them a usable head in most cases but has more potential flow over a W-9... a W-9 is a combination of a W-7 and W-8 but in a light weight version... a maxed out W-9 will flow right at 365 @ .700(thats what both sets I have did)... 1 set was CNC ported and the other was hand ported by Ryan... W-9 is much easier to come by now days ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Adrielp]
#1045790
08/02/11 06:59 PM
08/02/11 06:59 PM
Posts: 2,410 Ambridge, Pa.
rickraw
Ambridge, Pa.
ryan did my w9's. flowed 359.6 @ 700. 48* r3, 440 sb. pump gas. 9.65@137.53. street driven often.
[Re: rickraw]
#1045791
08/02/11 10:03 PM
08/02/11 10:03 PM
Posts: 437 south central pa
bdaz smblk
south central pa
I had w-9's on my short block before I put the pro stock truck w-8's on.My 9's only flowed 357@900 and the 8's flow well over 400@900 and the car only runs a tenth faster. Flow numbers don't mean as much as what people make them out to.About the only major difference is w-9's don't take a special valve cover.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: 340_Dart]
#1045792
08/02/11 10:52 PM
08/02/11 10:52 PM
jim sciortino
Trumbull,CT.
[/quote}We have a Coleman/Arrington 15* that makes nice power
What's that motor just out of curiousity...
417ci, 9in deck R3. The heads have been on a couple bench including MBE and without the paperwork in front of me IIRC, 297cc intake and 403cfm @.800. Really good for a truck head, I'm told.
We built it to take oxide, but are going to run it NA. It has a ported 420 and an SV-1. On Precision Automotives inertia dyno, it made 894hp @ 8200 and 657tq @ 6700. The car it's going in (70' Dart) is getting paint and should be ready for an ATCO rent day by late September.
[Re: jim sciortino]
#1045793
08/02/11 11:07 PM
08/02/11 11:07 PM
bdaz smblk
south central pa
Hey man I haven't forgot about calling u.I have just been crazy busy at work and my two little girl's when home.Good luck with your car and keep us posted.Kenny
[Re: bdaz smblk]
#1045794
08/03/11 12:28 AM
08/03/11 12:28 AM
jim sciortino
Trumbull,CT.
Thanks Kenny....
[Re: jim sciortino]
#1045795
08/03/11 01:20 AM
08/03/11 01:20 AM
Posts: 2,172 Ohio
theclutcher
Ohio
Would love to see a pic of them. Have any more?
[Re: theclutcher]
#1045797
08/03/11 08:56 AM
08/03/11 08:56 AM
jim sciortino
Trumbull,CT.
No pics, but when I get a chance I'll have somebody with a camera snap a few and post em' up. I'm a cameraless bum. ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: jim sciortino]
#1045798
08/03/11 09:17 AM
08/03/11 09:17 AM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
The W8 just have alot more meat to work with.I think you could make a honest 900 hp with a really good set of W9 s in the right hands.The W8 stuff is also very hard to come by and if you do find some usually will cost you a bundle.But hands down The W8 will make some killer power.Foltz at CFE still says it is the best small block wedge head out there..
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
[Re: FASTFISH420]
#1045799
08/03/11 09:19 AM
08/03/11 09:19 AM
jim sciortino
Trumbull,CT.
Makin' any headway with your killer???
[Re: bdaz smblk]
#1045800
08/03/11 09:51 AM
08/03/11 09:51 AM
fishy340
LONG ISLAND
I had w-9's on my short block before I put the pro stock truck w-8's on.My 9's only flowed [Email]357@900[/Email] and the 8's flow well over [Email]400@900[/Email] and the car only runs a tenth faster. Flow numbers don't mean as much as what people make them out to.About the only major difference is w-9's don't take a special valve cover.
i agree 100% my indy's flowed 323@700 lift and my car is mid 9'r
[Re: FASTFISH420]
#1045802
08/03/11 11:18 AM
08/03/11 11:18 AM
jim sciortino
Trumbull,CT.
Makin' any headway with your killer??? [/quo
The motor is at Uratchko's.He's done some head work and intake work,had the cam reground.changed the rockers,I cracked the Mohawk rockers,they were flexing way to much and killing my lift.so we had to go another route there.
He's just messing with it when he has the time.I had to take a break from it for awhile.The car is ready to go to Holts to 25.5 it also...
Nice..... ![](/ubbthreads/images/graemlins/thumbs.gif)
