Page 9 of 12 1 2 7 8 9 10 11 12
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044685
03/16/14 04:59 PM
03/16/14 04:59 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
And the driver's side
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044686
03/23/14 09:56 AM
03/23/14 09:56 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Intercooler tubes are finished and installed
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044687
03/23/14 09:57 AM
03/23/14 09:57 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
The intake side
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044688
03/23/14 09:58 AM
03/23/14 09:58 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Winch is installed
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044689
04/19/14 07:52 PM
04/19/14 07:52 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Tom has been making some headway with the wiring while I have been making progress on the cage.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044690
04/19/14 07:53 PM
04/19/14 07:53 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
front side of the cage
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044691
04/19/14 07:54 PM
04/19/14 07:54 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I managed to get some more side bars in before calling it a day. Tomorrow I will make the roof bars.
BTW, Tom says hi
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044692
04/19/14 09:43 PM
04/19/14 09:43 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
looking good! are you sure tom is using all 5 fingers, waving at me?
Re: "TastyKake" - Willys Wagon Build [Re: Golden-Arm] #1044693
04/19/14 10:40 PM
04/19/14 10:40 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I am not authorized to release that information.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044694
04/20/14 10:48 PM
04/20/14 10:48 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I only got a few bars done today. I made the rear bars between the windows
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044695
04/20/14 10:49 PM
04/20/14 10:49 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
and the two front roof bars. I only have the rear roof x to make before I pull the cage off to finish welding it and then do gussets.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044696
05/03/14 06:25 PM
05/03/14 06:25 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I pulled the cage off today so I could weld the underside. While I had it on the floor I made the roof rack for luggage when going on road trips.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044697
05/03/14 06:26 PM
05/03/14 06:26 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I used 3/4" 13ga. expanded sheet
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044698
05/03/14 06:27 PM
05/03/14 06:27 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
with 1" angle iron along the sides for support and ratchet strap attachment points made out of 3/8" bar
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044699
05/03/14 06:29 PM
05/03/14 06:29 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I also made a gusset for between the two bars that come up from between the rear windows
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044700
05/06/14 06:56 PM
05/06/14 06:56 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Painted the underside of the cage before putting it back on the Wagon
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044701
05/06/14 07:02 PM
05/06/14 07:02 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Cage was reinstalled and welded on for the final time. Gussets were also welded on
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044702
05/06/14 07:02 PM
05/06/14 07:02 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I also made the hinges for the tire carrier
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044703
05/06/14 07:03 PM
05/06/14 07:03 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
The white cage helps hide it against the white body
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044704
05/12/14 08:56 PM
05/12/14 08:56 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Side steps are made and welded on.
