Page 5 of 12 1 2 3 4 5 6 7 11 12
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044605
08/24/13 05:24 PM
08/24/13 05:24 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
You can never have too big of a d-ring...
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044606
08/26/13 04:04 PM
08/26/13 04:04 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
the d-rings should be sturdy enough to be able to lift the truck off the ground, using them.
awesome looking work. waiting to see whats next.
Re: "TastyKake" - Willys Wagon Build [Re: Golden-Arm] #1044607
09/08/13 03:37 PM
09/08/13 03:37 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
body off the old frame
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044608
09/08/13 03:38 PM
09/08/13 03:38 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Some wrecker drivers saw I was in need of a hand and stopped to help
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044609
09/08/13 03:38 PM
09/08/13 03:38 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Body plus new frame
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044610
09/08/13 03:39 PM
09/08/13 03:39 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
just looks so bad
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044611
09/12/13 06:41 AM
09/12/13 06:41 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
All 4 tires are on the wagon now
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044612
09/12/13 06:43 AM
09/12/13 06:43 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I will have to remove the tubs and make new ones for the slightly altered wheelbase.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044613
09/14/13 05:32 PM
09/14/13 05:32 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Front frame horns are done. I need to grind off the lower weld and redo it, the trigger was messing up and an caused erratic bead.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044614
09/14/13 05:35 PM
09/14/13 05:35 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
driver side frame horn.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044615
09/14/13 05:35 PM
09/14/13 05:35 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
back view of frame horn.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044616
10/06/13 09:16 AM
10/06/13 09:16 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I needed to get some more weight in the chassis before continuing with some more items. So I started making the motor mounts.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044617
10/06/13 09:17 AM
10/06/13 09:17 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I figured if leaf spring bushings can withstand offroading, they can tolerate a little 4BT
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044618
10/06/13 09:18 AM
10/06/13 09:18 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
This is how the motor looks in place
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044619
10/06/13 09:19 AM
10/06/13 09:19 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Lots of oil pan clearance
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044620
10/06/13 09:21 AM
10/06/13 09:21 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
skid plate assembly will hang about 6" below the frame rail to clear the transfercase
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044621
10/06/13 09:22 AM
10/06/13 09:22 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Now that the motor mounts are made, I was able to make the tranny mount which will be separate from the skid assembly. I had to make it swoop down in order to clear the driveshaft at full droop.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044622
10/13/13 12:51 PM
10/13/13 12:51 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Seats came in from Corbeau. They are heated Baja RS suspension seats.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044623
10/13/13 12:53 PM
10/13/13 12:53 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Intercooler came in as well. I got one that will be small enough to fit inside the grille.
Re: "TastyKake" - Willys Wagon Build [Re: Defbob] #1044624
10/13/13 12:54 PM
10/13/13 12:54 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I also got the rock sliders welded on. The whole exo-cage and front fenders will be based off of them.
