Willys Wagon Build
#1044525
08/01/11 10:33 AM
08/01/11 10:33 AM
Posts: 15,633 Norwich CT USA
moparts
Norwich CT USA
Lets start with , I have a 57 Willys wagon with a rusty frame, So doing some looking around I figure that I should be able to mount the Willys wagon onto a CJ8 frame with out too much problem. Using an after market ( stronger than stock ) CJ8 frame, And most of the parts from a CJ7 that I stripped, I should be able to complete this project with out excesses expense Now the problem, with fuel prices going up, I want to get a good MPG with this rig. First thought rebuilding the 4.2 6 cylinder and keeping the all jeep drive train, but thinking a diesel is the way to go. Price on a 4BT is just too much, So thinking of tiring to fit a 6BT as in Dodge Truck Diesel into the CJ8 frame and boxing the firewall on the Willys Wagon. Thoughts on this build or are there other diesel engines that I should be considering?
Re: Jeep Build - For Off Roading and MPG
[Re: ahy]
#1044529
08/02/11 07:47 AM
08/02/11 07:47 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I think I'd go in the archives and copy hotroddave's "super duper gas mileage 318" build and toss that in there...high compression, tight quench, very short solid cam and a t-quad...
[Re: moparts]
#1044531
08/03/11 01:27 AM
08/03/11 01:27 AM
Posts: 1,665 Milwaukee, WI
Prince_Valiant
Milwaukee, WI
it's not quite "mopar" but perhaps consider a Volkswagon 1.9 TDI?
There was someone who has swapped one into a later jeep with much sucess. Near 30mpg iirc.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph 1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD) 1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD) 1989 Shelby CSX #500/500
[Re: ahy]
#1044533
08/03/11 02:42 AM
08/03/11 02:42 AM
DaytonaTurbo
Manitoba, Canada
I know the 4.0 can be pretty thrifty when matched up to a manual transmission.
You're the first person I've ever heard refer to the 4.0 as "thrifty"!
[Re: RodStRace]
#1044535
08/03/11 03:29 PM
08/03/11 03:29 PM
Posts: 403 Portlandia
wimcle
Portlandia
Don't forget that the jeep is less aerodynamic than a brick! On the highway, there is a mpg limit you will hit no matter how efficient a motor you have. On the trails, bouncing over rocks, creeping around in 2-lo, and etc. I find that I give out long before the gas tank does. My opinion, pick a motor, then gear it to match. It's not going to make too much of a difference in the long run. PS: Going down hill from vail pass, I have to give it gas to keep up to the speed limit, thats pathetic aerodynamics
'00 cbr929rr -- '98 Ram SS/T -- '67 Dart Conv. --'05 Neon -- '09 Wrangler
[Re: DaytonaTurbo]
#1044536
08/03/11 09:50 PM
08/03/11 09:50 PM
Posts: 7,664 IN
ahy
IN
I'd go so far as to call it "perky" also! It just made a 2200 mile/2 1/2 day trip from Illinois to San Diego by the southern route loaded to the roof and pulling a trailer. Not one problem. Didn't even blow a trailer tire... probably because we had 2 spares.
[Re: moparts]
#1044537
08/04/11 07:09 AM
08/04/11 07:09 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
The 1984 Lincoln Mk coupes had an option for a BMW built diesel. http://carscoop.blogspot.com/2010/10/rare-find-1984-lincoln-continental-with.htmlI had a mining engineer friend who had one in a Mark VII coupe and he got 32 to 34 MPG consistently on frequent trips from Whitesburg KY to Lexington KY I did that same trip many times in a 1984 Ford Thunderbird gasoline V6 and typically got 24 MPG. My brother had a 1986 Mercury Cougar turbo 4 and would get 26 MPG on the same exact trip. It would be a relatively rare car to find in a salvage yard, but about the right size for Jeep duty. The air cooled Deutz diesel used for portable pumps is a great design, and I have read where it has been retro-fitted into trucks. If you wanted to stay with a newer design consider the Motori diesel in the Jeep Liberty or a VW TDI, including a 5 cyl TDI
[Re: Defbob]
#1044539
08/07/11 06:05 PM
08/07/11 06:05 PM
moparts
Norwich CT USA
Yes, just about to buy a wrecked Dodge 4X4 Diesel for the engine and trans. But the 4bt in the bread truck showed up on Craigslist yesterday. Should have it on Monday Night And the bread truck was cheaper also
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: dynotune440]
#1044541
08/08/11 12:14 PM
08/08/11 12:14 PM
Posts: 522 Lenox Iowa
MMiller
Lenox Iowa
I know that my 5.9 cummins in my 90, will go anywhere any of my other full size gasser friends trucks will go. It will wind in the mud with any bigblock for trail duty, and I can wheel a whole weekend on a few gallons of diesel. My buddy's with big blocks, and even small blocks, they are dumping gas in every night, sometimes even in the afternoon to finish the day.
After seeing mine work, and wheeling friend took his BBC out and will never go back. His tuned 5.9 cummins has never been a slouch to his BBC.
All that being said, I think a 5.9 is going to be a little much for the above said chassis. I think the 4 cylinder B will be sweet.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
[Re: moparts]
#1044543
08/08/11 07:09 PM
08/08/11 07:09 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Way to go, Tom! That has got to be better than a 6 for your use. Don't plasmacut, that's blowing money on the ground! Haul it down whole. Heck, you could sell sheets as "Official Moparts Lightweight Patch Panels"... At least cut out the signage and Ebay it as vintage and rare!
