Re: JOSS ENGINES 468ci. W2 Small block. What will it make??
[Re: Dragula]
#1043530
07/31/11 12:48 PM
07/31/11 12:48 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
647 hp, I'll be (pleasently) suprised if you have enough head on it for more, even with the big cam. With those cubes and still smallish ports the torque will be legendary...the kind Vikings write poems about My question is, why only the 2.02" on such a big cube motor? Also from my experience the econo's don't seem to rev as high as the billet pedestal W2's when you're dealing with high RPM roller spring pressures.
[Re: Streetwize]
#1043532
07/31/11 11:31 PM
07/31/11 11:31 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
Although, this isn't really a "budget build" In a way it still is. The W2's with 2.02" was the top end I have, and if I want to race this year, that's all the budget allows for.
Ideally, If money was no object, and time wasn't my enemy, you would see a set of CFE W8's on this thing! But, again, this makes for a differnt build still, and kind of an out of the ordinary build. My Aspen still has an 8 3/4 with stock everything in it, so, the car isn't really ready for a whole ton of power anyway.
-Kenny
[Re: StrokerAspen]
#1043533
07/31/11 11:44 PM
07/31/11 11:44 PM
Posts: 52,972 Romeo MI
MR_P_BODY
-Kenny
I'm with Wise and a few others... that thing will make a TON of torque(watch out for your 8 3/4) but the cross section of the port isnt anywhere near enough... so with all that torque I sure hope you dont have steep gears
[Re: MR_P_BODY]
#1043535
08/01/11 12:28 AM
08/01/11 12:28 AM
StrokerAspen
Alberta Canada
-Kenny
3.23's set up with hopes and dreams of it hanging together!
[Re: MIKES_DUSTER]
#1043538
08/01/11 12:58 AM
08/01/11 12:58 AM
StrokerAspen
Alberta Canada
Is it going into your Aspen???
It will be until the other car is ready for an engine. The other car is a 1967 Plymouth Valiant that I just bought. That car will have a Jerico DR4 and a Dana 60.
[Re: Stroker Scamp]
#1043539
08/01/11 01:16 AM
08/01/11 01:16 AM
StrokerAspen
Alberta Canada
That specific eh? remember, we are using a manual operated Stuska brake. Haha. That means, we read the number off of the dial and at what RPM it comes off at, then we calculated the power by hand. So, it wont be that specific.
[Re: BradD]
#1043543
08/01/11 12:08 PM
08/01/11 12:08 PM
Posts: 2,128 sweden
sshemi
sweden
[Re: thedriver]
#1043545
08/01/11 02:56 PM
08/01/11 02:56 PM
Posts: 325 Greenville, WI
Big B
Greenville, WI
8 billion hp
He would probably break the speed of light with that much power!
[Re: Big B]
#1043549
08/01/11 11:17 PM
08/01/11 11:17 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
8 billion hp
Only if he can get traction...
