Re: Fram filter ID
[Re: mccannix]
#104314
07/13/09 09:49 PM
07/13/09 09:49 PM
Posts: 5,363 Rancho Cordova, California (Sa...
hemi71x
Jim Do you by chance have the measurements of that single 4 airceaner elememt. I picked up a similar Fram one and there are a few NOS cases still at an old speed shop I know of. I beleive they say FRAM HPA-1 and TOP on the inside..13 3/4 inside dia, 3'5 high. Not quite wide enough for the 66-69 hemi aircleaner. Just wondered if they are worth going back for. Thanks
Terry. I dug out the cowl induction air cleaner and took measurements of the air filter element that's in it. Mine says NAPA 2092 on it, but i have no idea if it's an totally original to the unit or not. Mine measures at 13 3/4 inch inside diameter, but 3 inches in height. It looks like a 3 1/2 inch one should be in there, instead of the 3 inch one. The one that your describing to me appears to be the absolute correct one, in my opinion. I guess it would be a good thing to grab the other filter elements if you could get them at a decent cost. Jim V.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Fram filter ID
[Re: hemi71x]
#104315
07/14/09 12:01 AM
07/14/09 12:01 AM
Posts: 4,785 Ontario, Canada
mccannix
Ontario, Canada
Thanks Jim for the info. I too wondered if Fram could possibly have been the orginal supplier. I will put the old speed shop on my list of places to get back to in the near future.
Re: Fram filter ID
[Re: feeeighteefee]
#104318
12/05/14 04:37 AM
12/05/14 04:37 AM
Posts: 1,844 South Bend
John Brown
South Bend
NAPA 2092 fits 58 and 59 Oldsmobile with a single 4 barrel carb as I recall. Probably a few others too.
