Re: Stuck brake drum - any tricks
[Re: None2Slow]
#1042473
08/10/11 06:39 PM
08/10/11 06:39 PM
Posts: 923 Missouri
convertriple
super gas
super gas
Missouri
Are these rubber lines? I would make a heat shield or some kind of wrap to keep the heat off.
No, these are the steel lines on the truck that run inside the frame to the rear axle. They have a tendancy to rust through, while the fuel line that runs parallel is somehow treated to not rust. Wish they would have used the same material on the brake lines.
