Re: where and which 509 cam to buy? [Re: shoebox] #1042358
07/30/11 04:54 PM
07/30/11 04:54 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
If you want a hydraulic, call Hughes.
Re: where and which 509 cam to buy? [Re: justinp61] #1042359
07/30/11 05:27 PM
07/30/11 05:27 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
hughes engines will not get a penny of my money
74 dart sport 440 www.Csucarbs.com
Re: where and which 509 cam to buy? [Re: shoebox] #1042360
07/31/11 01:30 AM
07/31/11 01:30 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The Isky mega cam 292! That that you referred to on your other post or thread. The 509 is so so performance wise.
73 Sport 440, 509 cam w/Eddys 3.91 and 28.1"/27.3 tire. Et. 60 ft. 1.435, 1/8th. 6.61 @ 101.80 mph. 1/4. 10.472 / 127.78 mph. 2950# race/with me,and pump gas.
Re: where and which 509 cam to buy? [Re: shoebox] #1042361
07/31/11 02:09 AM
07/31/11 02:09 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
i have had 100% good luck and customer service with Hughes. I have their shelf solid in mine.
What happened?
Re: where and which 509 cam to buy? [Re: 493_DART] #1042362
07/31/11 09:29 AM
07/31/11 09:29 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My 408 has their solid, my pump gas 340 with one of their hydraulics ran 7.24 in the 1/8 at 3300#.
Re: where and which 509 cam to buy? [Re: justinp61] #1042363
07/31/11 02:06 PM
07/31/11 02:06 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
I had a bad experience on thephone with them and because of that
I choose to shop elsewhere
Re: where and which 509 cam to buy? [Re: shoebox] #1042364
07/31/11 02:11 PM
07/31/11 02:11 PM
tboomer Offline
tboomer  Offline
I have had great luck with Hughes..I didn't buy much from them but Kevin on the phone was a real pleasure to deal with!
Re: where and which 509 cam to buy? [Re: shoebox] #1042365
07/31/11 07:08 PM
07/31/11 07:08 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
If you go with the 509 get the 108 LS cam and not the 112.
If it were me I would use the solid you have now
With Either cam, I would still want the adjustable rockers. So thats a given IMO. Ive tossed pushrods with the stock rockers with the smaller MP 484 cam.
10.8,s are easily doable in a A body with your current cam, 10.5 comp, 4000+ stall, 3.91 or 4.10 gear.
Re: where and which 509 cam to buy? [Re: Sport440] #1042366
07/31/11 07:37 PM
07/31/11 07:37 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: where and which 509 cam to buy? [Re: HYPER8oSoNic] #1042367
07/31/11 09:58 PM
07/31/11 09:58 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
108 is the only choice. It's the adjustable rockers I would want
To get away from. That's the point of this whole idea!
Re: where and which 509 cam to buy? [Re: shoebox] #1042368
07/31/11 10:08 PM
07/31/11 10:08 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I hear you, . But I would still recommend them.
Re: where and which 509 cam to buy? [Re: Sport440] #1042369
08/03/11 11:19 PM
08/03/11 11:19 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
just shove the 509 in and give it a go - you know you want to
they make the power when packeged right
my Satellite just dropped into the teens last night at a street meet
11.189@119.00 and 11.187@118.95
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: where and which 509 cam to buy? [Re: tex013] #1042370
08/04/11 07:55 AM
08/04/11 07:55 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I think you should use the solid cam, i use iron rockers and have only adjusted them once this year.
What rockers do you intend to run and what is the rest of your combo.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: where and which 509 cam to buy? [Re: deaks] #1042371
08/04/11 01:43 PM
08/04/11 01:43 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
3500lbs w me dart sport
440 11.0cr
Cast crank ly rod shortblock
2295s stealth heads ported to 300+
My comp solid 250/255 530/540 108 OR 509 type hyd
6-6200 rpm limit with ethier
Torker2 800 Holley
Pro parts 2 in
TA 3800++ stall (is going in for upgrades can be 4xxx stall)
370 gear 26 in tires for now Probably go 410 28
Adjustable rockers- I'd like some affordable 1.6s. 200-650 bucks VS
100 dollar Mopar HD stamped rockers. I know the solid would be
Better.... There is no question. But I just can't help but think
The lil ol 509 will get the10.90 goal met !
Re: where and which 509 cam to buy? [Re: shoebox] #1042372
08/04/11 02:02 PM
08/04/11 02:02 PM
tennessee
mike54 Offline
mike54  Offline
tennessee
a friend of mine has a 70 ebody with a 440...509 cam..pocket ported 452 heads.flat top ross pistons..adjustable rockers..rpm intake..850 holley...t/a 10'' converter.s/s springs..bfg drag radials..car weighs 3500 ibs. hensley built the engine..12.36 @ 109 at bristol...lots of street driving and abuse..lol
Re: where and which 509 cam to buy? [Re: mike54] #1042373
08/04/11 06:30 PM
08/04/11 06:30 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I dont think your car will go 10's with the .509, carb is too small, converter needs more stall and it's too heavy.
I reckon 11.20-30
JMHO Mick
best 60ft 1.36
Re: where and which 509 cam to buy? [Re: shoebox] #1042374
08/04/11 08:27 PM
08/04/11 08:27 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yes, it will be tough! I didnt know the combo was that heavy. If I added 550# to my 2950# combo, it would slow it down from a 10.47 to 11.10 or so.
My verts not the best, 4200, but with a new 5000 stall, it might hit a 10.98 with that added weight.
Re: where and which 509 cam to buy? [Re: Sport440] #1042375
08/04/11 08:36 PM
08/04/11 08:36 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Well if it were 11.1s at 3500 illwhittle it away somewhere to get that 10.9!!!!
My bench seat is 100lbs I think!!
