Correct carb for 440 4bbl Superbird #1042248
07/28/11 04:31 PM
07/28/11 04:31 PM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
What's the correct carb for a 4bbl Superbird?
Does it differ from auto to 4 speed, or only the linkage?
Are they readily available and what are they going for these days?
Re: Correct carb for 440 4bbl Superbird [Re: MONC] #1042249
07/28/11 05:21 PM
07/28/11 05:21 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
This one,4 spd,4737S
Expect to lay out at least $800 for one done,probably more if it includes the correct solenoid.It is the most sought after AVS there is,and "not" readily avaliable..
Re: Correct carb for 440 4bbl Superbird [Re: 62maxwgn] #1042250
07/28/11 06:40 PM
07/28/11 06:40 PM
MONC Offline OP
MONC  Offline OP
Thanks Bill, I was hopin you would reply
What about rebuildable ones?
If available a couple a hundred bucks?
Re: Correct carb for 440 4bbl Superbird [Re: MONC] #1042251
07/29/11 10:08 AM
07/29/11 10:08 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Joe, I have never found one for less than $300-350. And that was in the early '90's when I needed one for a U-code 'Cuda I owned! I truly doubt they are worth any less now...
