What is the best option for A body to 4.5" bolt pattern
#1042144
07/28/11 12:22 PM
07/28/11 12:22 PM
Posts: 2,489 Tracy, New Brunswick, Canada
magnumcharger
I have a 1968 Plymouth Barracuda. I'm planning on replicating the Super Stock appearance with this car. When the S/S cars were built, they had their own "special" spindles and hubs, quite unlike anything else found on an other A body.
My plan WAS to change over to a pair of 1973 Dart spindles, upper A-arms and disc brakes.
Recently I've found out that by doing this, the front track is increased significantly. This is not the look I'd like to have.
Has anybody done any other swap that keeps the track width at stock? (Like the S/S package)
Re: What is the best option for A body to 4.5" bolt pattern
[Re: magnumcharger]
#1042146
07/28/11 09:22 PM
07/28/11 09:22 PM
Posts: 4,323 NY NY
340duster340
NY NY
How significant is the difference? Is out not something that a different back space wheel couldn't fix?
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
[Re: 340duster340]
#1042147
07/28/11 09:26 PM
07/28/11 09:26 PM
Posts: 5,337 the house on the left.
cogen80
isn't it only like 3/8 of an inch?
[Re: cogen80]
#1042148
07/28/11 10:23 PM
07/28/11 10:23 PM
Posts: 1,074 So Cal, USA
Fab64
So Cal, USA
No, it's closer to 7/8" on each side:
See this linky
[Re: Fab64]
#1042149
07/28/11 10:44 PM
07/28/11 10:44 PM
Posts: 1,894 Mira Loma, CA
69B3GT
Mira Loma, CA
See this linky
I need to ditch my SBP disc then, My headers are close to the tires That 7/8" would go a long ways on my car
[Re: magnumcharger]
#1042152
07/29/11 12:39 AM
07/29/11 12:39 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
the wider track is better for handling and the extra width isnt really significant...
I am truckless..
[Re: magnumcharger]
#1042153
07/29/11 02:34 AM
07/29/11 02:34 AM
Fab64
So Cal, USA
Although you are happy with the result of this swap on your '67 Barracuda, for me that is just too much offset.
Actually, I'm not satisfied with it. That's why I'm looking to possibly go to a narrower front wheel, with more backspacing, so it will pull them in a bit. Still not sure what I'll do.
[Re: Fab64]
#1042155
07/29/11 08:37 AM
07/29/11 08:37 AM
magnumcharger
So I'm wondering...maybe by looking up the front bearing specs, and maybe the part number, there might be a possibility of finding another hub of similar dimensions that could fit onto the stock spindle? Maybe something from a Mustang, or an Explorer, or a Dakota, or ???
Or maybe - would it be possible to redrill the hub for a larger bolt pattern?
[Re: magnumcharger]
#1042156
07/29/11 09:00 AM
07/29/11 09:00 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I think so...and I *think* a similar era mustang K-H rotor has the same hearings/offset but larger bolt pattern....
[Re: patrick]
#1042157
07/29/11 11:01 AM
07/29/11 11:01 AM
Posts: 155 Tulsa oklahoma USA
2734bbl
Tulsa oklahoma USA
On my 67 Dart it moved the wheels out far enough with my 3.5" skinnys that it limits me to a tiny 24.5" tall tire. I would like to run a 26" tire to offset my 275/60 DRs that are 28".
I dont much care for the stink bug look nor a ton of fender gap in the front which also BTW limits front end travel.I dont really want to clip the inside of the front fenders as I have seen on some cars.
I've looked without succes in finding a wheel with enough offset to clear the fenders. I did look at some billit wheels on a Mustang that looked as if a guy might be able to machine the hub of the wheel to create more backspacing and stil be plenty safe. The center of the wheel was nearly 2.5 inches thick.
[Re: mopfried]
#1042159
07/29/11 02:50 PM
07/29/11 02:50 PM
2734bbl
Tulsa oklahoma USA
I would be interested in where this kit is avaliable. My 69 dart has disk front but the small bp. I would like to go to the 4.5 bp....
You can get disc brake kits that will use your stock spindles and are bbp.
I've also heard that you can take your SBP rotors and have the holes filled/redrilled for BBP from Moser or the like. I would think this would be the best and cheapest option.
[Re: rt66jim]
#1042161
07/29/11 03:17 PM
07/29/11 03:17 PM
Posts: 438 Great Lakes Region
abodiesonly1
Great Lakes Region
You can use 68-69 B-body frt spindles and 73 A-body disc brk upper control arms. If you don't mind using drum brakes up front.
For that matter, if you can stand to use the drum brakes, I drilled the hubs and drums to 4.5 pattern on my Dart. Drums slip on and off now also.
[Re: magnumcharger]
#1042162
07/30/11 01:52 PM
07/30/11 01:52 PM
Posts: 7,798 Lyons, CO
MileHighDart
Lyons, CO
What do you have now, drums, or the sbp KH disks ?
I just recently converted my car from sbp disks to bbp.
I kept my Kelsey Hayes disk setup (spindles, calipers, pads,) but used a 67 Mustang unicast hub/rotor which is of course 4.5" bolt pattern. There is some machining of the hub and rotor that has to be done. The machine work cost me $200 but it worked out great. There is a thread over at forabodiesonly . com in the brake section. Lots of good info there about this swap complete with pics. But read carefully cause some if the info can be a little confusing and there is some contradicting info. The mustang hub and the sbp mopar disk hub use exactly the same bearings, but spacing between the two bearings is different and the seal is different. The hub has to be cut where the rear bearing race fits, so that the bearing sits deeper into the hub. THis lets the hub slider farther up onto the mopar spindle, this will get the disk to be centered in the caliper. The disk diameter will also need to be cut down a little. The mustang disk is 11.25" or so and it needs to be 11" or slightly less to fit inside the mopar caliper.
I have heard that Moser no longer does the "redrilling" thing with sbp rotors, they got rid of the machine they used to use for this.
[Re: MileHighDart]
#1042164
08/02/11 03:52 PM
08/02/11 03:52 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
I got a mustang rotor and mocked it up , someday I may go this route.
I also have a set of hubs and rotors that were drilled for the larger bolt pattern I bought from a board member, he did it himself and it does have some runout so he says, I haven't run it yet but I will probably just switch them over to the smallbolt pattern .
