Re: 383 Sonoramic Twin Turbo [Re: gdonovan] #1041647
08/25/11 11:55 AM
08/25/11 11:55 AM
IL
furious70 Offline
furious70  Offline
IL
I think 'negate' is a very poor word here. The more appropriate word IMO is 'override'. The turbos will override any ram effect with their greater ability to create increased pressure.
Based on what I know from turbocharging 2.2 and 2.5 engines I can assure you even at high boost pressures the runner tuning still impacts the engines operating range.
If anything it tends to magnify the effect.
Would be interested in hearing more here, have you done custom intake work that revealed this? I have not so I can't disprove, but on the surface it would seem easy to make a turbine sizing choice that would completely override any tuning in the intake (i.e. stick a bigger turbine side on this theoretical engine we are using and the manifold may still produce a low rpm TQ bulge the bigger turbo is going to cause a mountain of TQ above that range)
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 383 Sonoramic Twin Turbo [Re: furious70] #1041648
08/25/11 02:29 PM
08/25/11 02:29 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
completely override
And the previous use of the word "negate" is what is causing the confusion and derision here. An analogy here would be like saying replacing a 10 guage wire with a 2 gauge wire would "completely" reduce any wire resistance. It of course it would not, it would only reduce resistance. However the poster who has experience with turbo motors and tuning and was favorable in turbo manifold tuning results, and the across board fact that nearly every well designed turbo motor has a tuned/ram effect intake for its intended rpm range, I still stand behind my previous statements here.
Re: 383 Sonoramic Twin Turbo [Re: jcc] #1041649
08/25/11 11:31 PM
08/25/11 11:31 PM
IL
furious70 Offline
furious70  Offline
IL
well, if you like to nitpick, the 2g wire, depending on the application, can reduce the resistance to a point of negligibility.
To use the non-word you chose , irregardless it would be very interesting to see actual testing results from this rather than the conjecture most of us have to offer. Tom Vaught over on TMF would be a good guy to ask about this, being a career boost engineer.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 383 Sonoramic Twin Turbo [Re: furious70] #1041650
08/28/11 11:57 PM
08/28/11 11:57 PM
duluth mn.
dragula426 Offline
dragula426  Offline
duluth mn.
" irregardless it would be very interesting to see actual testing results from this rather than the conjecture most of us have to offer. "
i agree.... a friend of mine and myself are working on a similar build right now. keep us posted on your build.
