Re: HP for $$$
[Re: 1Fast340]
#1037606
07/26/11 10:03 PM
07/26/11 10:03 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
That was going to a engine builder(Andy Jensen) with a idea and leaving with a complete motor.Dart block,callies crank,je pistons, manley rods,jesel rockers,dart pro 215 cc heads etc, he took nothing to the machine shop!!
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: HP for $$$
[Re: d-150]
#1037608
07/26/11 10:55 PM
07/26/11 10:55 PM
1967dartgt
Hilltown Pa
Oh yea 9.50 on a real pass and pump gas.
Re: HP for $$$
[Re: 1967dartgt]
#1037609
07/26/11 10:56 PM
07/26/11 10:56 PM
1967dartgt
Hilltown Pa
And I forgot you guys like those junk yard builds that make ten passes and blow up!!!lol
Re: HP for $$$
[Re: pittsburghracer]
#1037612
07/26/11 11:28 PM
07/26/11 11:28 PM
1967dartgt
Hilltown Pa
The guy said he would drag this car down the track and since it makes around 850 hp I figure you will need about 900hp. Thats my new math!!
Re: HP for $$$
[Re: 1967dartgt]
#1037613
07/27/11 08:38 PM
07/27/11 08:38 PM
1967dartgt
Hilltown Pa
So where are the 10,000 dollar pump gas motors that make 850 HP?
Re: HP for $$$
[Re: 1967dartgt]
#1037614
07/27/11 08:59 PM
07/27/11 08:59 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i dont have one but with a modern cnc'd ported procomp head i think it could be done
low deck 511 short block $4k procomp cnc'd heads and springs $2k cam, lifters,chain,push rods and gear $1700 oil pan, pickup, and pump $500 intake and carb $1k(i never buy new for a carb or intake) rockers hughes or harlands $600-$1k
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: HP for $$$
[Re: 1967dartgt]
#1037616
07/27/11 09:21 PM
07/27/11 09:21 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
easy if you have a BB. all it takes is a little bit of boost and maybe 500 cubic inches. A stock stroke 440 that was making around 470 was toped with a BDS 671 and 8psi of boost and it made over 700. Doesn't take much. But go ahead and keep trying with that small block.
Re: HP for $$$
[Re: d-150]
#1037623
07/27/11 10:39 PM
07/27/11 10:39 PM
Mr.Yuck
Brookeville, Md
hey mryuck have you seen that stock 440 cast piston motor the supercharger store built, : wait bolted on. i think it made like 800 horsepower see you do not have to be a rocket scientist to build a big block just a socket set
Nope, but there was a member that had a 61-62 dart w/ a junk yard cast crank/piston 440 w/ a 671 that ran high 10's with nothing fancy...
