Re: MAX WHEEL AND TIRE COMBO USING INBOARD SPRING KIT???
[Re: Labratt]
#1037373
07/21/11 06:08 PM
07/21/11 06:08 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Randy,It's your car,but I wouldn't cut that GTX at all.Our 70 Road Runner used a 10" wheel with a 5" offset,and we had 10.5x29.5 Firestone(Phoenix) in that car with a bit of trimmimg of the front edge of the wheelwell.Lips were trimmed too.I don't think you'll gain a whole lot by going to a larger tire that you have in mind.In fact,on my A-body,I'm going smaller after I have the car painted.From 31.8 to a 29.5 tall tire.
[Re: Labratt]
#1037374
07/21/11 06:29 PM
07/21/11 06:29 PM
Posts: 793 Utah
topbrent
Utah
This isn't necessarily a direct answer to your question, but it is more of an response that may have you looking at other areas of your car. What are the particular specs of your suspension package. - Front and rear. Do you run Cal-Tracs and Monoleafs? For a good example of hooking a 540 stroker B-body using a small tire, look at ActionAnge. He hooks his 3750lb 1967 Belvedere to the tune of 10.27 @ 132 with a 1.44 60ft, using a 9x28 slick on an 8" wheel.
[Re: Labratt]
#1037376
07/21/11 06:59 PM
07/21/11 06:59 PM
Posts: 608 TN
1DGEMAN
TN
Why do you need bigger tires? Just want the look? Many NHRA stockers and Super Stockers go into the 9's on 9 inch tires.
Real Men shift for themselves
[Re: 67_Satellite]
#1037383
07/21/11 11:21 PM
07/21/11 11:21 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I have a 67 b body with a stock width 8 3/4 and run a 28x14.50 quick time pro on a 12" wheel with 6 1/2" of backspace. If I went to a 7 1/2" back space I could go with a wider tire, There is alot of room behind the tire to the spring due to the stock width rear end. Uploaded with ImageShack.us
67' charger 499 RB
10.57 at 127
[Re: Labratt]
#1037385
07/22/11 10:33 AM
07/22/11 10:33 AM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
Brent...that's one impressive Belvedere AA has! I see he uses Cal-Tracs out back. Do you know what else he's done to the suspension to make it hook so well? My 3500 lb. GTX has NO front sway bar,.840 Race T-Bars...and Calvert Racing 90/10's..which work GREAT! Out back are 002-003 A-Body Super Stock springs,as used on the '68' Hemi Darts and Barracudas. The shocks are Rancho 9000 9-way adjustables. Rear gear is a 8 3/4..4:56 ratio. I believe the pinion angle is 5* angled down. Thanks for the info! Randy B.
Ok here's my easy to use setup. QA-1's in front and rear, .840 t bars and Caltrac mono's in rear. Get 5-7 inches front end travel. You can adjust as you go on any given day or track. My air pressure is always between 18 and 19 lbs. Don't want to crush the sidewall and lose contact patch. Caltracs in bottom hole- less violent- with 2 "flats" preload on pass side. Drv side has space the thickness of a nickel between spring and lever. This is with driver in car. I don't leave at high RPM- no need with all the torque. Use a built for my combo converter from Lenny at Ultimate Converter Concepts. Made specifically for my setup not a cookie cutter by an order taker tech clerk at other companies. Other reasons to use a smaller tire: cost less, less drag once you're in high gear. Best reason- it freaks people out wondering how you can go so fast on them... Thanks to topbrent for using my car as an example
[Re: Labratt]
#1037386
07/22/11 11:32 AM
07/22/11 11:32 AM
Posts: 17,865 S.E. Michigan
ZIPPY
S.E. Michigan
The bolt on inboard spring hangers won't even bolt on!
The front hangers are already right next to the frame rail on your/our car. There isn't anywhere to go, no wasted space to use up.
The bolt ons work much better on an A body, but you still have to punch a hole in the frame to clear the fasteners with those.
The weld-on spring relocation kit, which is the only mp setup that will do much of anything on your/our car(s) requires chopping a chunk out of the frame rail to weld in the mounting boxes. Then after the spring is relocated, the next obstacle is the wheelhouses....
If you only relocate the springs and don't relocate the inner tubs, you're only going to gain about 1" of tire even though you moved the spring 3", which is not a very good payback for the effort.,,,,but it could be done that way if a guy wanted?
Since the quarters and various other sheetmetal needs to be cut off mine anyway, being rusty junk....and the frame rail is already cut for the subframe connectors, I'll probably go the extra mile with it when it's time to replace the quarters. It would be kind of a shame to cut yours, but I wouldn't blame you if you did!
I also like the look....big car, big tire...why not
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1037387
07/22/11 01:38 PM
07/22/11 01:38 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I think cutting the frame is not so bad if it's done well, as it's not easily seen but i wouldn't cut the body on your car for bigger tyres. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
